![]() OCAU News - Wiki - PC Database - QuickLinks - Job Search - Pix - Sponsors |
Sign up for a free OCAU account and this ad will go away! |
Thread Tools |
#1 |
Storm Father
Been working on a little graph of late to better help me to select the pumps that I want to target, and thought that this sort of information would be quite useful for the forum as a bit of a guideline.
Here's the graph: ![]() Some notes: *) The Danner Mag 3 line is my personal interpretation of a best fit line given the data presented at their website. Their data produces a line that is not even remotely smooth, so I look the liberty to smooth it out somewhat. If anything, I may have overestimated slightly. The in-line heat figure is another approximation drawn from reading about people's experiences. I believe it to be somewhat close. *) The Swiftech MCP600 in-line heat is another approximation, based on motive pumping power which must be ultimately converted as frictional heat into the water, and some heat from the motor itself. *) The Johnson pump may be obtained for the price stated from www.depcopump.com. The in-line heat value is an approximation based on my experiences with the Davies-Craig EBP, with both pumps sharings a similar design. *) The Davies-Craig price quoted is an over-the-counter cash price direct from Davies-Craig. The on-line order price is $201. *) The Eheim pumps voltages/frequency is not given as Eheim release correctly spec'ed models for whatever country they are targetted for. This means that so long as you buy the Eheim pump that is correct for your country, you should see the performance stated. The Eheim PQ curves on the literature did not have uniformally placed graph lines. The PQ curves given are based on an interpretation of the graphs using the global min-max scale of the graphs presented, and then following the points on the curve. I believe that this actually eliminates some of the discrepencies with the visual interpretation of the Eheim PQ curves that people have occasionally reported on. *) The block flow/pressure resistance curves presented are for the blocks themselves only. They do not include additional resistances that may be introduced by a radiator or other heat-transfer device.
Motherboard / CPU / Memory: Asus P5WDG2 WS Pro / Conroe E6600 / 2 x 1GB Patriot PDC22G8000+XBLK Cooling: Little River Storm/G7 CPU WaterBlock / Iwaki RD-30 Pump / Huge 24x30cm single-pass Radiator Media: 320GB Seagate Barracuda 7200.10 / Samsung SH-S182M DVD Writer Video Card: 1 x 512MB ATI Radeon X1950XTX Crossfire Case / Power: Antec Tower Case / Silverstone ST65ZF PSU (fan modded) Peripherals: BenQ FP937S+ 19" 8ms LCD Monitor Last edited by Cathar; 18th January 2004 at 1:22 PM. |
#2 | |
![]() see overclockers forum thread are there no 240v danner's? - seems fantastic bang for the $.... |
#3 | |
Storm Father
Yes, the Danner Mag 3's are an amazing price/performance mix. I am not aware of any 240V/50Hz models, only 115V/60Hz.
Motherboard / CPU / Memory: Asus P5WDG2 WS Pro / Conroe E6600 / 2 x 1GB Patriot PDC22G8000+XBLK Cooling: Little River Storm/G7 CPU WaterBlock / Iwaki RD-30 Pump / Huge 24x30cm single-pass Radiator Media: 320GB Seagate Barracuda 7200.10 / Samsung SH-S182M DVD Writer Video Card: 1 x 512MB ATI Radeon X1950XTX Crossfire Case / Power: Antec Tower Case / Silverstone ST65ZF PSU (fan modded) Peripherals: BenQ FP937S+ 19" 8ms LCD Monitor |
#4 |
(Banned or Deleted)
Very useful guide. could you do one up for Ba's/LA's and whatever else?
would be good for aproximations.. -Matt |
#5 |
very useful guide. Cheers.
just a little hard to read. Damn colour blindness. |
#6 | |
Storm Father
The rest of the boxes start with the highest pressures on the left and go down from there. That way you can match the box/pump position to the curve starting from the left hand side.
#7 |
Storm Father
A further aspect to the data to consider is the nominal in-line heat that each pump adds to the cooling loop when running.
This is fairly important. Just because one pump gives higher flow rates doesn't necessarily make it better. For example, let's compare the Eheim 1048 to the Danner Mag 3. The Danner Mag 3 is, on average, going to add 16W more heat to the cooling loop. Let's say we were using a DTek Pro core with a decent fan running at a quiet 7V, and this corresponding radiator setup has an inherent C/W of 0.06, meaning for every watt of heat that enters the water, the water will heat up by 0.06C. Now with the Mag Drive 3, the water will be 16 x 0.06 = 0.96C warmer than with the Eheim 1048. With the Mag 3 & the WW, we would expect about an 8.3LPM flow rate (not accounting the radiator). With the Eheim 1048, about a 5.6LPM flow rate. Now let's look at the White Water flow vs performance chart here: ![]() At 5.6LPM, we see a C/W of around 0.183, and at 8.3LPM, a C/W of around 0.173. i.e. a 0.01C/W difference. Now if the CPU were emitting a real 100W of power, then the extra flow rate of the Danner Mag 3 would mean that it would be 0.01 x 100 = 1C cooler. However, the water is 0.96C warmer due to the extra heat of the Mag 3, therefore all that has really been gain is 0.04C, or basically nothing. If the CPU was dumping an unrealistic 150W, then it would be about 0.5C cooler with the Mag3. If the CPU were dumping 100W, but we had a better radiator setup giving a C/W of 0.02, then the CPU would be 0.7C cooler with the Mag 3 over the 1048. This is why it is quite important to match the radiator setup with a pump.
#8 | |
(Banned or Deleted)
. after about 1 year of waiting and will dump it on the system and test it. for Data collection of people figures, a generalised rounding would work to a point would be more then sufficiant enough yes? I could flow test my setup as is and report back with my specs.could be worth it. -Matt |
#9 |
ok unfortunately for me i'm confused.
so what relation do the blocks have to the pumps? and let me see if i can decipher this. at 1m worth of pressure the cascade has 4.5lpm flowing through it? And at 3m worth of pressure the johnson CM30p7-1 moves 10.5 lpm? SSoooo... to get the cascade flowing at 7lpm withour anything else a danner mag drive 3 would do it? Is any of that right or do i need to do some research?
sorey four ne gamma and spealing miscakes. |
#10 |
Can't see your graph for looking Cathar
Water COOLED Q9550@3.8ghz & 4870@790Core/995Memory OCAU Extreme Cooling Club H2O Member OCAU Extreme Cooling Club Peltier Member |
#11 | |
Storm Father
#12 | |
Storm Father
So the trick here would be to plot a curve of Pressure = 0.7 x (Flow / 10)² for the BA radiator. You then add that curve to the curve for the block and the resulting line is what you'd use. We can guess at it though. For example, with the Cascade, a BA, and an Eheim 1048, the Cascade intersects the 1048 line at 4.7LPM/1.15mH2O. The pressure drop for the BA at 4.7LPM is 0.7 x (4.7/10)² = 0.15mH2O Adding the two together we get 1.3mH2O at 4.7LPM Let's predict 4.5LPM => 1.3 x (4.5 / 4.7)² = 1.2mH2O We look at the graph and see that the Eheim 1048 does indeed supply pretty close to 4.5LPM at 1.2mH2O, so that would be the predicted flow rate.
#13 | |
Storm Father
With a BA rad + the Cascade + the Danner Mag 3. Expanding from the post above. At 7LPM the BA rad has 0.7 x (7/10)² = 0.34mH2O PD The Cascade has 2.3mH2O PD at 7LPM The total PD at 7LPM for the Cascade + BA = 2.64mH2O That's more than the Mag 3 provides, so let's predict something less than 7LPM. Let's try for 6.7LPM PD at 6.7LPM = 2.64 x (6.7/7)² = 2.42mH2O Looking at the PQ curve for the Mag 3 again, we see pretty much bang on 2.42mH2O for 6.7LPM for it. So we'd predict 6.7LPM with the Mag 3 + Cascade + BA rad.
#14 |
Cathar, not to nitpick, but it seems your nominal in-line heat rating may be a bit off on the Mag 3 and/or the MD-15R. The Mag 3 consumes 35W, the 15R 31W. You have the nominal in-line heat rating for the Mag 3 at 20W and the 15R at 21W. Another oddity is the 1250 with it's 28W consumption, yet you only rate it at 11W for the nominal heat rating? Confused is all.
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:* E6700 @3.65 / P5W DH Deluxe / 2GB 667 TeamGroup / 1900XTX PC Power & Cooling Turbo 510 Deluxe Mountain Mods U2-UFO Cube Storm G5 --> MP-01 --> PA 120.3 --> 2x DDC Ultras in Series --> Custom Clear Res "Artificial intelligence is no match for natural stupidity." 1,223,460+ Ghz Folding@Home aNonForums *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:* |
#15 | |
Storm Father
The Eheim is a measured value. The Mag-Drive is a guess based on people's experiences. The Iwaki MD15 value is an extrapolation of the MD30.
| Bookmarks |
| Thread Tools | |
