Go Back   Overclockers Australia Forums > Specific Hardware Topics > PC Audio
Old 11th August 2017, 4:41 PM   #6061
BuZeR
BuZeR's Avatar
Any recommendations for headsets (mainly used for gaming) to pair with my current Xonar D2?
From what I have been reading the Audio-Technica ATH-ADG1X seems to be the most recommended cans here. How do they compare to the ASTRO A40TR? As I have the Xonar I am assuming I wouldnt need the DAC or and Amp for the A40's?
Or should I just keep my current Creative Aurvana Live Headphones (around 5 years old) and just buy a boom mic?
|| Intel Core i7 3770 || Gigabyte P67A-UD7-B3 || Kingston HyperX Predator 16GB || Gigabyte Radeon RX 580 4GB || Kingston SSDNow UV400 480GB SSD & G.Skill Phoenix Pro Series 120GB SSD || Corsair RM850 Gold 850W || Asus Xonar D2 Ultra ||
BuZeR is offline   Reply With Quote
Join OCAU to remove this ad!
Old 11th August 2017, 6:33 PM   #6062
Matthew kane
The CAL is actually pretty good and decent and one of the few headphones on the market to have a biocellulose structured dynamic driver. It is quite old though but old doesn't mean less good. The ADG1X has a different sound presentation.
Intel i7 3960X @ 4.7GHZ - Noctua NH-D14 | 16GB OCZ Platinum Series DDR3 1600MHZ | Asus Rampage IV Extreme (4901 bios) | Zotac AMP! Edition GTX 980 Ti | PNY GTX 465 unlocked to 470 | Creative X-Fi Titanium Fatality Pro with LME47920's opamps | OCZ Vertex 3 240GB | OCZ Vertex Plus 120GB| 1TB WD Black, 2TB WD Green, 4 x 2TB Seagate LP | Enermax Revolution 85+ 1250watt | Antec P280 + Veris Elite | LG BD Rewriter
Matthew kane is offline   Reply With Quote
Old 11th August 2017, 8:12 PM   #6063
BuZeR
BuZeR's Avatar
Thanks for the reply, I did Google biocellulose, very interesting tech. Thanks for the info The biggest issue I have with these headphones is that the PE leather is pealing from the head/ear pads. While not the best, I managed to salvage a set of earpads from some TB P11's (exactly the same diameter!) which happened to be laying around, so maybe they do have a bit more life left in them
I have also been doing a bit more research on the ADG1X. Is it fair to assume they are based on the ATH-AD700X or the ATH-AD900X? From what I could read the ATH-AD700X appears to be a less superior headset, the limitations actually are more suited to gaming. So it makes sense that the ADG1X is based on this cheaper version.
Assuming that they are based on the ATH-AD700X, are the ADG1X worth the extra $100? Seems a ATH-AD700X with a mic mod and some cable sleeving would be a cheaper alternative. Or am I missing something?
Old 11th August 2017, 8:15 PM   #6064
Suopermanni
Thanks for the reply, I did Google biocellulose, very interesting tech. Thanks for the info The biggest issue I have with these headphones is that the PE leather is pealing from the head/ear pads. While not the best, I managed to salvage a set of earpads from some TB P11's (exactly the same diameter!) which happened to be laying, so maybe they do have a bit more lift left in them
I heard it is based off the Ad900x but I could be wrong. It certainly uses the AD900x pads. That much I know for certain.
Intel i7 6700K @ 4.4Ghz/ GigaByte Z170x SOC FORCE/ 32GB Kingston 2666Mhz DDR4 RAM/ Gigabyte GTX 980ti G1 Gaming SLI/Seasonic XP1200W Platnium/4TB WD Black x 3/Samsung 850 Pro 512GB/ ???/Pioneer Blu-Ray Drive/Random DVD RAM Drive/
Suopermanni is offline   Reply With Quote
Old 11th August 2017, 9:15 PM   #6065
Matthew kane
From what I know based off my Japanese sources the ADG1X is similar to the AD900X but with a slightly different tuned driver. The sound balance leans more towards the old AD900 which isn't far off to the revised AD900X then it is to any of the AD700 family headphones.
Old 12th August 2017, 10:15 AM   #6066
BuZeR
BuZeR's Avatar
Thanks for the advice! I'm in Canberra at the moment so no places I can pick a set of ADG1s up besides JBHifi (399!). Gave them a ring and they were happy to pricematch PCCaseGear at 279, so happy with that. Not s good as the $239 deal they had the other month, but close enough.
I'll try get out to JB and pick them up today. Will post back with my thoughts soon. Hopefully i don't end up needing an amp..
Old 12th August 2017, 12:42 PM   #6067
Matthew kane
I think you'll enjoy them. Plenty of good earpad alternatives for your CAL which takes a huge hit to the sound quality once the default pleather pads flake and wear out.
Old 12th August 2017, 5:26 PM   #6068
BuZeR
BuZeR's Avatar
Really enjoying the ADG1X (Open cans) so far, JBHifi also let me pick them up for $239
There are only two real negatives I have identified so far, but both relatively minor. First one was that the bottom of the drivers were pushing into my face a little too much, but bending the rods slighty out by hand fixed that issue. The only other niggle is that the mic does not sit flush when in the upright (out of the way) position. As such it is looming in my peripheral vision and is a little distracting.
Think it will take a few days for me to adjust to the lightness of the headphones. Almost feels like they are about to fall off my head - but think that is more of a reflection of how tight my old ones were.
But more importantly first impressions are the sound quality is noticeably clearer. Both when set the music or playing PUBG (only one I have tried so far). Also I don't think they need an amp, happy with the volume output and currently have them on around 30% when listening to music.
Thanks Matthew and Suopermanni for the input, made the process easier
Old 13th August 2017, 5:10 PM   #6069
mixsetup
Yeah I have Plantronics Rig 500HD sound is Brilliant better than at the radio station I work at. And I have the mid range ones.
https://ebgames.com.au/pc-212138-Pla...s-Rig-500HD-PC
AMD FX-9590, ASRock 990fx Extreme9 Motherboard,MSI R9 280X GAMING 3G , GeIL 16GB Kit DDR3 Evo Potenza @ 2400MHz, Sandisk Ultra II 240GB SSD, 2 X 2TB SATA3 HDD, 2TB NAS , 1TB SATA3, 2 X 2TB external HDD, LG Blu-Ray RW
mixsetup is offline   Reply With Quote
Old 14th August 2017, 3:22 PM   #6070
ska'
ska''s Avatar
Picked up some Audio-Technica ATH-R70x's this morning.
Loaded up the calibration with sonarworks software package, instantly prefer the sound signature coming from long term use of AKG K702's..
Bloody good!!! Driving them very easily with my Audio GD NFB- 5.2 DAC / AMP.
Intel i7 6600k | Gigabyte GA-Z170N-Gaming 5 | G-Skill RipJaw V 16GB | MSI 1070 Gaming X | SilverStone Strider 1200w Gold | Intel 535 480gb | Intel 530 240gb | Intel 530 120gb | WD Black 1Gb | Corsair 250D | Silverstone Tundra TD02-E | Deathadder Black | Filco 10KL | ACER XB271HU | AKG K702 |
ska' is offline   Reply With Quote
Old 14th August 2017, 4:08 PM   #6071
supasaiyan
supasaiyan's Avatar
do headphones that use either 3.5mm OR Bluetooth exist? I'm using an old ipod that uses 3.5mm, but i want to also sometimes connect to my IP7 (without the cable)
supasaiyan is offline   Reply With Quote
Old 14th August 2017, 4:19 PM   #6072
Copie
Copie's Avatar
Qc35's.....
My Solar stats
Trump 2016
Make America Great Again!
Copie is offline   Reply With Quote
Old 15th August 2017, 10:55 AM   #6073
supasaiyan
supasaiyan's Avatar
Originally Posted by Copie View Post
Qc35's.....
omg.. how the hell did i not realise that. Thanks!
Tags
audiofx, beyerdynamic, creative, earphones, etymotic, headphones, headphonic, logitech, plantronics, razer, sennheiser, tdk, ultimate, zalman
