Go Back   Overclockers Australia Forums > Specific Hardware Topics > Video Cards & Monitors
Old 11th September 2017, 5:10 AM   #61
maxrig
Originally Posted by HobartTas View Post
Sure its no issue getting the cards to run without problems but I've got two GTX1070's in SLI and for Battlefield 4 the second card gives me about an 80% increase in frame rates but for Battlefield 1 its mostly wasted as I get about 10%-20% more if that, so if the new games can't utilise a second card then what's the point of having one. I'll see what happens when Battlefront 2 comes out and the GTX1080ti's successor comes out in "Early 2018" to decide whether to upgrade my cards or not to just one big card.
How are you getting 10%-20% Gpu utilisation in BF1 with x2 1070? This benchmark shows good scaling in BF1 with x2 1080's.
https://www.youtube.com/watch?v=MTaCpmvhT-I
maxrig is offline   Reply With Quote
Old 11th September 2017, 3:06 PM   #62
jpw007
jpw007's Avatar
Originally Posted by mad_mic3 View Post
personally i wouldn't run sli on any power supply less than 1000w
I meant to respond to this a few days ago, but i've got 2x Strix 1080Ti's. Running them both at 110% power limit, full load, my system draws ~700watts.
These things have a power rating of 250W in FE. Strix has iirc 280 or something. The 1080 is only 180W in FE form...They use 1 8 pin, Ti's use at least an 8+6, or in the case of aftermarket ones they use 8+8.
1000w is in no way needed for most cards these days in SLI
| Asrock z170 Extreme7+ | i7 6700k | 32GB Corsair Vengeance LPX | 2x Strix 1080 Ti OC | 1x 500GB 850 Evo M.2 + 2x 1TB MX300 M.2 | HX850i | EKWB Custom Loop | X34 |Caselabs S8
Custom White w/ Red Internals
jpw007 is offline   Reply With Quote
Old 11th September 2017, 3:15 PM   #63
WJR
(Banned or Deleted)
Those Galax 1080 EX OC cards are great value, I just picked one up from MSY. Runs pretty cool and is quiet.
WJR is offline   Reply With Quote
Old 12th September 2017, 11:18 AM   #64
roamin
roamin's Avatar
yep, psu requirements are not what they used to be. i got an ax1200i in my system but with what i have in my system i could run it on a 650w.
Caselabs S8, I7 6700k @ 4.6ghz, giga Z170x Designare mobo, 32gb Corsair ddr4, 2x Evo 850 1TB in raid0, 1080ti Founders Edition with EK block, Creative G5 amp/dac/sound card thingo, 3x xspc 360 rads, ek cpu block, aquacomputer aqualis 440ml, aquacomputer D5 pump, acrlyic custom bent tubing.
roamin is offline   Reply With Quote
Old 14th September 2017, 12:57 PM   #65
shazbot83 Thread Starter
It runs fine on the 750w, maxed settings in all games and it pumps, PUBG still has its issues because its about as optimized as a coalfire power plant. Now just waiting for 6+8 cable combs to arrive so I can make it sexy again.
shazbot83 is offline   Reply With Quote
