Old 12th January 2017, 7:06 AM   #121
MoRpHeUs
MoRpHeUs's Avatar
Ok so mine is running 5ghz stock voltage on x41 kraken
Temps get to 90c load but does not crash. I only run it for 5 minutes at those temps as I don't like it that hot.
We need to delid the beast. Anyone point me in direction to do this? You need a tool? My practise delid didn't go to well lol
MoRpHeUs is offline   Reply With Quote
Join OCAU to remove this ad!
Old 12th January 2017, 7:36 AM   #122
AstinGC90
AstinGC90's Avatar
This my post a few pages back, should help.
Originally Posted by AstinGC90 View Post
If you plan to delid you will need to order the tool from here: http://rockitcool.myshopify.com/
(These are from Texas and take 7-14 days unless you message James directly and request express freight for an extra $20 odd bucks, 6-7 day freight)
Or here locally:
http://www.ebay.com.au/itm/Intel-Sky...UAAOSwB4NWvuRZ
If you go with the ebay seller ensure you advise him you are planing to delid a Kaby lake, I spoke to him last night and he is yet to draw up a kaby tool in CAD as he is awaiting the first order.
For a delid you will need:
Thermal Grizzly Conductonaut Thermal Compound 1g $10
Thermal Grizzly Kryonaut Thermal Grease 1g $9.00
Arctic Silver ArctiClean (60ml Kit) $12.00
I7-7700K Delided 5.2/4.8 1.42v 50c max daily OC, EKWC 360mm + 240mm rad UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, Gigabyte GTX 1080ti EKWB. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X.
AstinGC90 is offline   Reply With Quote
Old 12th January 2017, 7:46 AM   #123
MoRpHeUs
MoRpHeUs's Avatar
Champion... I am ordering these. Anyone in WA welcome to use once it gets here
Rockit 88 - Black Body
Re-Lid Kit - 1150
Old 12th January 2017, 8:18 AM   #124
AstinGC90
AstinGC90's Avatar
Re-Lid Kit - 1150
To easy man, mine is getting closer. Hoping it lets me hit 5.2Ghz 75c
Old 12th January 2017, 12:01 PM   #125
headin2001 Thread Starter
headin2001's Avatar
Second CPU is ok, but must have the worst paste job ever.
Hits 90's at 1.33v for 5GHz. Will still bench at 1.4v at 5.1/4.5.
Batch L639Fxxx
Old 12th January 2017, 1:47 PM   #126
aussie-revhead
aussie-revhead's Avatar
On that binning road ey ....
Bench 1- Asrock x99m Killer - 5960x - 32gb of Samsung E die DDR4- evga GTX 1080Ti FTW (I wish..) - Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is online now   Reply With Quote
Old 12th January 2017, 2:21 PM   #127
AstinGC90
AstinGC90's Avatar
Owners List / Results
Bench Stable
headin2001 - 7700k - L637F698 - 1.2vid - Asrock Z170M OC Formula - Galax OC LAB 4000C19 - 5200/4500 - 1.4v Bios - Geekbench
AstinGC90 - 7700k - L637F711 - 1.2vid - Gigabyte Z270X-G5 - Corsair Vengeance 3200C16 - 5200/4500 - 1.41v Bios - Geekbench
Might aswell enter that for now :-)
Old 12th January 2017, 9:20 PM   #128
perz
perz's Avatar
I see you guys are pumping out the vcore, how are your temps staying within 90C? I put in 1.3 to try and get a stable 4.6ghz (which was heaps, I'm sitting on 1.2 atm) and I was almost hitting 90C?
Do temps stop climbing as quick at those vcore ranges? Say if I wanted to push for 5ghz for the lols with my i5 7600k.
perz is offline   Reply With Quote
Old 12th January 2017, 9:31 PM   #129
AbRASiON
Some of those temps are insane. No wonder people are considering a delid.
If intel did the lid properly, surely it should add almost no heat to the thing, right?
AbRASiON is offline   Reply With Quote
Old 12th January 2017, 9:35 PM   #130
perz
perz's Avatar
Just got told by a friend to not test using the new Prime95 and use 26.6 instead. Temps look much better as they dropped 10C across all cores.
Sitting comfortably at 70C max heat test as opposed to 80C. Hopefully it'll get better with the paste settling in.
But yeah, I remember my 2500k getting better temps? Maybe it wansn't as hot outside then.
[edit] I've been able to boot with 4.6ghz @ 1.1vcore! Currently stressing it with P95 so we'll see if it holds up. Curious as to how low people have been able to go. Yeah, going for the big 5ghz is the main goal but I'm too scared of the heat.
I don't think this will last a whole night but fingers crossed.
Also temps are now at a very comfortable 60-65C which I'm much more comfortable with.
Old 12th January 2017, 10:09 PM   #131
mr_mordred2095
The biggest temperature inducer I've found so far is LinX. Shit's intense, is good
mr_mordred2095 is offline   Reply With Quote
Old 12th January 2017, 10:40 PM   #132
AstinGC90
AstinGC90's Avatar
So I finally had time to sit down and not rush things. I got a really clean 5.0Ghz @ 1.27v 74c. I set Uncore to 4.5Ghz, AVX to 3, VCCIO is at 1.15v, SA is 1.2v an the RAM is XMP1 3.2Ghz 1.35v
A/C says room is at 23c ambient. Very happy with this OC, I'd expect 50-60c after delid so am very keen to try that out. Looks like this may be my daily overclock if temps are sub 60c at load.
Old 12th January 2017, 11:36 PM   #133
perz
perz's Avatar
Wow, just got it then. Makes Prime95 look like a pansy! Hot damn! Literally.
So after a few hours on Prime and other stress tests, I'm going to call it stable at 1.15vcore for 4.6ghz. I'm pretty happy.
Old 13th January 2017, 5:53 AM   #134
roamin
roamin's Avatar
Originally Posted by defecat0r View Post
Anybody care to share their experiences coming from sandy bridge? Biggest question being is the difference perceptible without running benchmarks?
i went from a 3770k to a 6700k, went from 840 evo 500gb ssd to 2x 1tb evo 850 ssd in raid0 and 16gb to 32gb of ram and honestly it made bugger all difference in my day to day usage.
what i do need to upgrade is my 2x keplar titans.
sandy is not outdated in my opinion. i upgraded as my pc died so it was a forced situation, i didnt do because i actually wanted to. i needed to so i had my pc.
my pc is watercooled with 3x 360 rads and d5 and so on. my last pc was also watercooled.
Caselabs S8, I7 6700k @ 4.6ghz, giga Z170x Designare mobo, 32gb Corsair ddr4, 2x Evo 850 1TB in raid0, 2x kep titans in sli, Creative titanium hd sound, 3x xspc 360 rads, ek gpu blocks, ek cpu block, aquacomputer aqualis 440ml, aquacomputer D5 pump, acrlyic custom bent tubing.
roamin is offline   Reply With Quote
Old 13th January 2017, 8:26 AM   #135
wintermute000
Thanks for that. Sticking to my 4790 and 840evo*
wintermute000 is offline   Reply With Quote
