Go Back   Overclockers Australia Forums > Other Topics > Science
Old 5th June 2011, 10:51 PM   #61
Whisper
Whisper's Avatar
Cool
Originally Posted by Resident View Post
They are caused by two things
First, in those videos it is being run from a netbook (all we had available at the time of filming) so it takes longer to process the algorithm.
It also is using a microsoft lifecam HD5000, which we have discovered is quite laggy. This means we have to stop the cube for a split second, wait, then take the photo. We used to run it from a logitech camera that was a lot faster and when we go for the official record we will have put a better camera on it.
Really, it should run at full speed the entire time and you should never see any pauses.
I thought there was plenty room for improvement on the speed of solution if those pauses were removed. Cool
There's something about philosophy that is at once humanising & utterly human. It's the court of last recourse. When the oracles have failed us, when the saints have grown silent & when god has chosen not to reveal himself. Then we stand back in the dark dark shadows of confusion & fear & ask, "What sort of being am I?" "What kind of life is right for me?" "& how should I govern, or be governed?"
Whisper is offline   Reply With Quote
Old 7th June 2011, 8:20 PM   #62
Resident
Originally Posted by Cheep_Thrillz View Post
This is nifty!
Did it drop the cube much when you were still developing/debugging it?
Did the cube ever get thrown very far?
I think this answers your questions...
Resident is offline   Reply With Quote
Old 7th June 2011, 9:03 PM   #63
Whisper
Whisper's Avatar
Cool
Hey, that video shows a 6.0 solution time!!
Old 7th June 2011, 9:08 PM   #64
Resident
That was early on before we got the vision system going, so no scanning time, just passed a known solution.
Old 7th June 2011, 9:13 PM   #65
dakiller Thread Starter
(Oscillating & Impeding)
dakiller's Avatar
I just saw that today, the best part is at the 30 second mark
Kind of cheating, as the algorithm spits out 22-25 moves, we pre-programmed it with a list of moves and scrambled the cube with these moves so that it would solve back out. It was done so that we would always have the exact same list of moves to test the system with every time we ran it. If we're allowed to look at the cube before solving it and pre-program it in, we are faster than that record holding kid
dakiller is offline   Reply With Quote
Old 7th June 2011, 9:29 PM   #66
Whisper
Whisper's Avatar
Question
Are you saying the algorithm can calculate the solution for the entire puzzle from looking at 1 face, or the entire cube?
Then is it just a matter of programming the movements of the robot claws?
Old 7th June 2011, 9:38 PM   #67
dakiller's Avatar
It has to look at all 6 sides, and once it does then the algorithm that solves it spits out a list of moves in the form of the faces that it needs to turn F,B,L,R,U,D in either clockwise or anticlockwise direction. That is then passed to the embedded system and nothing else needs to be done from the PC end once that is done. As it is only a serial port for communication, you just need to connect to it via a terminal app and send the relevant characters, in a string if you wish, to control the whole thing
Old 7th June 2011, 9:53 PM   #68
Whisper
Whisper's Avatar
Question
Thanks for that
So solution time is partially a function of processing power.
What's the point where you start hitting serious diminishing returns?
Obviously the netbook doesn't cut it if you were serious about getting the fastest solution, but some how I don't think a super computer is going to help shave off massive amounts of time compared to a decent desktop computer, but I guess that is my question.
Old 7th June 2011, 10:24 PM   #69
dakiller's Avatar
Thanks for that
We ran it off just a basic desktop PC at uni, they don't have very powerful cpu's in them at all, they are a few years old the desktops and are your average specs. With this, the time to generate a solution is not at all noticeable, as you can see in the first run on the latest video linked above. This algorithm is generating ~22-25 face turn moves to solve, yet it has been shown that any Rubik's cube can be solved in 20 moves or less, just that the time to find these solutions takes the average desktop a few minutes to find. It is just too much effort to shave off those 2 or so moves, when it doesn't take much time for the robot to actually perform the extra moves.
The time to turn the grippers is as fast as 80ms, but we have variable control over this and I think that it has been slowed down slightly from that to be more reliable. The grippers open and close extremely quickly, I think it is in the order of 10ms for that . I remember we did a test that we repetitively opened and closed them about 100 times and it was about a second to do all those moves. There are sensors that tell when it is fully opened and fully closed, so that we aren't just putting delays in, we are actually waiting for it to fully close before the next move is done here.
One spot that we have room for improvement is that while the algorithm counts face turn moves, there is a complex lookup table that converts these face moves into robot gripper moves, and depending on what state the robot is in, it can be up to 7 different actions needed to be performed to make the next face turn move. So what we can do is have the solving algorithm spit out a list of different possible solutions and work out which one has the lowest total gripper move time cost and run with that one.
In looking through the project folder, I came across the step response graph for the motors, which i thought might be of some interest
Hosted by UGBox Image Store
X axis is time in seconds and Y is the encoder counts, with 2000 is 90 degrees
Old 8th June 2011, 11:33 PM   #70
Whisper
Whisper's Avatar
Question
At the 23 second mark in this video there is a noticeable pause.
That is the type of thing I was referring to.
I think I saw others as well, but cbf tracking them down, as I'm not trying to tear your efforts down, just wondering what causes those pauses?
Old 11th June 2011, 8:27 AM   #71
Resident
Looking at that video you can see that the camera side gripper from vertical when that pause occurred, which means that it was caused by the rubber on the gripper tips sticking to the cube for a split second and now allowing the gripper to open. We used to have trouble with that (when that video was taken) as we bought the most grippy rubber we could find, but it ended up acting almost like a suction cup to the surface and sometimes stuck.
We changed to less grippy rubber and it worked a lot better later on.
Problems like that were what made this project hard. There were so many things that you don't consider until it happens and trying to find away around them so they didn't derail the project was often time consuming.
Old 12th June 2011, 1:15 AM   #72
dmr
nice work, good to see we got some local smarties on OCAU.
dmr is offline   Reply With Quote
Old 24th June 2011, 9:24 PM   #73
RatcHeT-x
RatcHeT-x's Avatar
Just posting to give you a massive congrats on the record. nice work man!
OCAU // Drummer Club # [35]
RatcHeT-x is offline   Reply With Quote
Old 1st July 2011, 9:43 PM   #74
Archades
Archades's Avatar
Mechatronics looks damn awesome n fun apart from the mountains of math.
What's the next uni project?
Flickr | RedBubble
Archades is offline   Reply With Quote
Old 12th November 2016, 3:24 PM   #75
Lasmi
Default Holy Thread Revival Batman!!
A new world record has been set for solving a Rubik's cube. In just five years we've gone from 10 seconds to 0.637 seconds.
Robot breaks 'world record' for solving a Rubik's Cube in a fraction of a second
A robot has broken the world record for solving a Rubik's Cube in the fastest time ever, according to its creators.
The machine, known as "Sub1 Reloaded" took just 637 thousandths of a second to analyse the toy and make 21 moves, so that each of the cube's sides showed a single colour.
That beats a previous record of 887 thousandths of a second , which was achieved by an earlier version of the same machine using a different processor.
The record attempt was staged at the Electronica trade fair in Munich.
http://www.mirror.co.uk/tech/robot-b...olving-9228939
OP's team's achievement is still incredible, especially just using "two hands", but this is a great example of how far robotics and automation has come in just five years. A different processor alone dropped 250ms off the time. The human record is 4.6 seconds though that's just doing the moves as they get to analyse it first.
This is why there needs to be automated vehicle racing. The advances in F1 don't really filter down to consumer level but with automated vehicles many of the advances will.
Lasmi is offline   Reply With Quote
