Old 19th May 2017, 10:24 AM   #706
nCrypt
nCrypt's Avatar
Originally Posted by Virtuoso X View Post
sweet
gotta wait till my liquid ultra comes before i do anything
i have delidded 7350K, 7600K and 7700K (had 3 lol)
temp decreases are absolutely worth it with kaby. also volts a bit lower as well
undelidded 7350K 1.41V for 5Ghz, temps under custom H20 High 70's
delidded 7350K 1.38V for 5Ghz, temps early 50's
Unsure on the difference with the 7600K and 7700K i have now, as i purchased these already delidded
My 2nd 7700K which i delidded was as follows
undelidded 7700K 1.35V for 5Ghz, temps under custom H20 High 80's
delidded 7700K 1.32V for 5Ghz, temps mid 60's
Also tested with a Coolermaster Hyper 212 EVO red, and a corsair h100i, and the temp range is about the same, (the custom keep temps down more at load, but at idle, little difference
the coolermaster keeps the 7350k 5ghz 1.38V @ mid 50's during XTU
delidding a must imo for kabylake (if you intend to overclock!)
1.5960X@4.5Ghz 1.25V WC X99 ROG R5 E10 32GB TridentZ 3200C14 GTX1080 Ti SLI WC CaseLabs S8
2.7700K@5Ghz 1.30V WC Z270 ROG APEX 16GB TridentZ 3200C14 GTX1080 STRIX OC WC Phanteks Luxe Tempered
3.7600K@5Ghz 1.31V H115i Z270 ROG STRIX 16GB TridentZ 3200C14 HD630 Caselabs S8
nCrypt is offline   Reply With Quote
Join OCAU to remove this ad!
Old 19th May 2017, 10:38 AM   #707
Virtuoso X
Virtuoso X's Avatar
what tim do you use on between the chip and IHS?
X V Rig: i7 2700k 5.1Ghz @ 1.48v 24/7 | Asus Maximus IV Extreme ROG! | Ripjaws X 16GB 2133mhz | H100 | WD Blacks 4TB Vertex 3 240GB SSD | Phanteks Enthro Luxe | 1.2kW StriderGold | RX580
Gear: G9X | G15 | G35 | SCARAB /X V
Virtuoso X is offline   Reply With Quote
Old 19th May 2017, 10:43 AM   #708
nCrypt
nCrypt's Avatar
https://www.pccasegear.com/products/...al-compound-1g
and between the ihs and block i use
https://www.pccasegear.com/products/...l-grease-1-5ml
Great products. The TIM between the IHS and chip is way more important then the TIM between the IHS and Block.
The kryonaught is good, but active silver 5 which is half the price, produces temps within a couple degrees.
I just got a bundle when bought both!
Old 19th May 2017, 2:30 PM   #709
Virtuoso X
Virtuoso X's Avatar
thanks
is any silicon adhesive or epoxy adequate enough to glue the IHS back to the chip?
Old 19th May 2017, 2:56 PM   #710
headin2001 Thread Starter
headin2001's Avatar
thanks
I use a sikflex, 922 I think it is. Black windscreen silicon really. Non corrosive to the PCB and sticks like the original. Some use dow corning, but I haven't really found any.
Old 19th May 2017, 3:25 PM   #711
Virtuoso X
Virtuoso X's Avatar
sweet
ill pop into bunnings and see what i can find
Old 19th May 2017, 5:36 PM   #712
Ratzz
Ratzz's Avatar
I use ordinary clear bathroom silicon. I stick a small cable tie into the tube, and just wipe it thinly across all 4 sides of the IHS. I then clamp it lightly to the CPU for about 20 minutes or so, just until it gets some grab, stick it into the socket and clamp it down. Next time its removed, its solidly attached, but actually a bit easier to remove again if desired than the original glue.
I did nCrypt's chips with bathroom silicon, and mine and a number of others. I and them have experienced no problems as yet, unless they haven't informed me.
I wouldn't use epoxy. If you mess up the TIM application, you are pretty much fucked if you've used epoxy I'd imagine. I'd be worried that delidding would take half the PCB with it...
I always say 'morning' rather than 'good morning'. If it was a 'good' morning then I would be on a yacht in the West Indies smoking a 10" reefer and getting a massage from Lexa Doig...
My Rig
Ratzz is offline   Reply With Quote
Old 19th May 2017, 5:38 PM   #713
Virtuoso X
Virtuoso X's Avatar
does anyone have a delid / relid tool like the rockit88
(https://rockitcool.myshopify.com/pro...nt=21315860033)
and willing to let me use it on my 7700k? if your interstate ill pay postage to and from
(not only a delidder but also a relidder makes life easier)
Originally Posted by Ratzz View Post
I use bathroom silicon.
I wouldn't use epoxy. If you mess up the TIM application, you are pretty much fucked if you've used epoxy.
ill pop into bunnings and get some silicon sealant with high thermal resistance instead
Old 19th May 2017, 5:49 PM   #714
Ratzz
Ratzz's Avatar
If a CPU core throttles at 100C, you would have to assume that not much in there is getting hotter than that? I don't think high thermal resistance is necessary really. Ordinary bathroom silicon works just fine.
Remember you are basically just holding it in position when its not in the socket. It's pretty solidly secured once clamped in.
Using non conductive TIM, I don't even bother gluing the IHS back down. I just feel more comfortable making it immobile before fitting with the conductive stuff. You don't want that shit getting smeared around under the IHS.
Don't forget to buy some LET (liquid electrical tape) which you can probably also buy at Bunnings. I bought mine at Jaycar. You want a dob of it on the little gold contacts near the die under the IHS, so conductive material doesn't short them out against each other.
My Rig
Old 19th May 2017, 10:43 PM   #715
Virtuoso X
Virtuoso X's Avatar
i was thinking of not gluing the IHS back down and just letting the mobo hold it together (even though first mounting on mobo might move the IHS alittle)
but i think ill be alittle more comfortable with having some sort of adhesive (no matter how minute) to keep it together and let the pressure from the socket clamp it down.
theoretically, if i leave the IHS without gluing it back, i should get better thermal performance right? because there is less thickness to the IHS / PCB
Old 19th May 2017, 11:49 PM   #716
Virtuoso X
Virtuoso X's Avatar
why not use Conductonaut for the heatsink as well?
Old 20th May 2017, 12:49 AM   #717
nCrypt
nCrypt's Avatar
Because its liquid metal.
It eats aluminum and most blocks/heatsinks are aluminum (full abd part tbereof)
It will eat and destroy fhe block.
Old 20th May 2017, 1:05 AM   #718
Ratzz
Ratzz's Avatar
You are talking about maybe .1mm instead of .2mm clearance, all of which is bridged by liquid metal. There is very little clearance between IHS and die. You only need a smear of silicon, not a thickness. No, there would be no thermal advantage in not gluing it back down.
Here's an experiment for you. After delidding, but before applying the new TIM or gluing it down, try and fit the CPU and loose IHS in the socket without allowing the IHS to move as you clamp it down.. It can be done, but you'll need to brace one end very securely with your thumb (placing uneven pressure on the socket in the process), and even then its likely that the sliding motion of the clamp will move the IHS with it, leaving the chip behind.
Its only a matter of a few mm, but it can really mess up your newly applied TIM, and with liquid metal in there you really don't want it disturbed once you drop that IHS in place.
I've never bothered gluing them down until I started with the liquid metal, and its been fine. I just don't think I'd take any chances with electrically conductive liquid being in the wrong place.
Of course this means the chip can now be removed and moved etc without disturbing the awesome new TIM too, which is handy if you switch shit around a lot like most of us.
My Rig
Old 20th May 2017, 8:12 AM   #719
glnn_23
When the IHS just sits on the die, with no tim between them, it can spin freely as it does not touch the pcb. The silicone sealant really just takes up that gap. This is ensured by having pressure on it as it dries.
glnn_23 is offline   Reply With Quote
Old 20th May 2017, 4:07 PM   #720
Virtuoso X
Virtuoso X's Avatar
thanks for the clarification guys
whats a good method of clamping down the IHS to the PCB after applying silicon? i dont have a delid tool etc
