Go Back   Overclockers Australia Forums > Specific Hardware Topics > Retro & Arcade
Old 16th May 2017, 4:47 PM   #16
callan Thread Starter
callan's Avatar
The VIC 6561's Teutonic dispatch is now confirmed Once it's arrived and I have the mainboard nominally working I'll restore it a bit - replace dodgy caps, clean it, tidy up some of the repair solder from a previous replacement of a 6522VIA etc. etc.
So, with the chip some weeks away my attention now turned to the keyboard.
Aside from being ABSOLUTELY filthy there was also a missing MINUS (-) key and the spline for the key snapped off.
So I split the keyboard, providing access to the switch contacts, allow removal of the keyboard movement and replacement of the broken spline.
I tied the keyboard cable to the backboard, as unsupported it's individual wires are prone to fracture.
Then I turned my attention to replacing the broken spline.
It was at THIS point that I said.... "Bother". For like the donor C64 keyboard this Vic20 keyboard is made by Mitsumi, but the movement is significantly DIFFERENT from the donor keyswitch
The shaft is shorter and fatter, the spline dimensions different, the distance between the base of the key and the end of throw slightly greater - and finally the spline recess is less deep into the 2-shot cast key. They will not fit.
So now I need to precisely measure up both keys and attach a sawnoff portion of the REPLACEMENT spline and shaft onto the EXISTING shaft. Attaching it won't be difficult: I'll just drill the existing and replacement shaft , run a steel pin through both and infill with a bit of 2-part polystyrene casting goop and it'll be quite strong. Determining the dimensions of said replacement shaft, however will be quite 'interesting' - looks like I'll be digging up my vernier gauge and doing some maths tomorrow.
At least the key colours match up - gotta be happy about SOMETHING!
Callan
Faith-based morality isn't morality at all. It's obedience.
"I don't like this internet thing anymore, can we have the old version back please?" - BlueRaven
callan is offline   Reply With Quote
Old 16th May 2017, 4:54 PM   #17
underskore
it's great to see such a detailed and technical worklog ticking along.
underskore is offline   Reply With Quote
Old 16th May 2017, 5:23 PM   #18
callan's Avatar
It is tempting just to replace it with a C64 keyboard outright (they're a dropin replacement), but I wouldn't be able to get the function key colour correct.
This keyboard has actually seen a lot of action - the splines have significant scoring (which I guess is a good thing as it shows it was loved and used). The whole thing will need to be disassembled, cleaned and serviced. The painted on graphics key images are still in good nick, however.
Neat tip: Mr Sheen furniture polish is simply silicone oil in solution. Sparingly and strategically applied it lubricates plastics brilliantly - the carrier liquid evaporates off leaving a powdery silicone film which doesn't wick, spread or attract dust, lubricates well without attacking the plastic.
I'll probably do the keyboard restoration before repairing this one key, as I don't want to disturb the repaired keyswitch anymore than is necessary.
Callan
Old 17th May 2017, 12:26 PM   #19
callan's Avatar
Keyboard Day!!
Blergh!..
That dust is really gritty and abrasive, too - it's scored the keyboard shafts and bound up the shift-lock mechanism. Nasty stuff. Could be worse I suppose: at least the former owner wasn't a smoker.
Callan
Old 19th May 2017, 8:21 AM   #20
callan's Avatar
Late last night I ransacked my scrap pile and came across a very dead Rev1 Vic20 (from Girton College, Bendigo) that I'd forgotten I had. Bit of a tragedy as it's a VERY early example (16th week 1982). It's a PET keyboard with bizarre reworking in wirewrap under the backboard, but quite unsalvagable. The case is in good condition however, but more importantly it has a seemingly working VIC6561 So for now I've dropped it into the project VIC, and in the next few days I'll work on the board. Having a tooth implant and some minor face surgery tomorrow, so I might be out of commission for a bit.
When the German VICs arrive I might still have a go at repairing the Girton machine, but it seems pretty far gone. Schools are not kind to computers.
I had mixed success with the keyboard repair: still a work in progress.
Pics later.
Callan
Old 19th May 2017, 2:58 PM   #21
badmofo
badmofo's Avatar
Sounds like you're making progress with the VIC but nothing good comes easy. Thanks for the updates.
All the best with the dental work, doesn't sound like a good time. Praise be to modern drugs.
Life? Don't talk to me about life.
badmofo is offline   Reply With Quote
Old 19th May 2017, 6:51 PM   #22
flu!d
Ubuntu Mate 16.04 LTS
flu!d's Avatar
Callan, what's the make/model of your scope?
Show us yer HTPC!
Dell T5500, Xeon X5675 Hex core @ 3.46Ghz max, 24GB RAM, GTX 670FTW, 60GB OCZ Vertex 3 SSD OS drive, 2 x 1TB home/storage drives, Dual Acer V243HQ 1920 x 1080 monitors, Ubuntu Mate 16.04 LTS and loving it!
flu!d is offline   Reply With Quote
Old 19th May 2017, 9:23 PM   #23
callan's Avatar
It's a Sainsmart DS202.
The current incarnation (which is probably a lot better) is the DSO note II. Here's an Ebay link (I don't vouch for the seller: it's just someone who sells it.)
I've never quite worked out how to drive this one - the manual is an appalling chinglish translation: it can do storage and basic signal generation, apparently. But it's a portable oscilloscope, lithium battery powered, and handles the frequencies my retro gear generates and gives me the info I need.
Callan
Old 19th May 2017, 11:14 PM   #24
callan's Avatar
Originally Posted by @rt View Post
Where are you getting the signal you’re showing?
The messy one doesn’t look like the output of a clock buffered with Schmidt triggers.
How does it look on the way in to the custom chip? Straight after the buffers.
If the clocks on pins 38 & 39 are clean, can’t you then assume you’re screwed?
Found the reason that the 4.4Mhz signal is so dodgy: it's the dodgy oscilloscope I'm using: It only has a 7.5Mhz sampling rate. 4.4Mhz is above the nyquest limit (3.25Mhz), so sampling artifacts are generating the sub-harmonics/foldback you're seeing.
It told me what I needed to know, though so that's enough
Callan
Old 19th May 2017, 11:39 PM   #25
qwertylesh
qwertylesh's Avatar
Hey this is awesome stuff man.
I have a bunch of vic-20 game carts in their respective boxes, but i'm realising that I'll probably never get a vic20 to try them out them on
http://i.imgur.com/2uAedYA.png
cactus quality, but theyre in front of the game cubes
Originally Posted by Agg View Post
Smith brand ones are all shit and that Bob Smith is a jerk
:O
qwertylesh is offline   Reply With Quote
Old 21st May 2017, 6:31 PM   #26
callan's Avatar
I love it! It looks like they still have their boxes.. 👍👍
Old 22nd May 2017, 6:48 AM   #27
flu!d
flu!d's Avatar
Callan
I was gonna ask about the sampling rate, I've had issues with portable affordable scopes in the past regarding sampling rates - Without even asking you just answered my question, sadly.
Good job on the Vic my friend!
Show us yer HTPC!
Old 8th June 2017, 9:31 PM   #28
callan's Avatar
**Warning - big pikkies ahead.**
Patience is a virtue
Having cracked out my vernier gauge I worked out just how long the spline needed to be, and using my drill as a makeshift lathe turned it, parted it off & filed it to the required length.
I then surface-prepared both it and the old keyboard spline, glued them together with super-strength Araldite and set it aside. Since the Vic20 shaft is nylon, not polypropylene I ensured the Araldite filled the quadrant-hollowed shaft, making a solid "root" for the C64 key graft.
I've discovered that Araldite epoxy needs at least 10 days to become truly strong, hard and properly adhere and it does so best in a cool environment. So that's just what I did - and waited nearly 3 weeks. Patience, as I said is a virtue. I think this is a mistake that many people make when using Araldite: the guide on the back is wrong: araldite takes a really really long time to properly cure.
In the meantime I cleaned up the warzone that was my "Commodorium" amd had some Commodore plus4 fun!
I revisited the project again today. Sure enough, the Araldite is now rock hard and adhered strongly: hard enough that it is indistinguisable from the hard nylon. It sanded and polished up well (using nail buffing sticks), and looked ready for action!
Time to put it all together!! The keyboard and components had already been cleaned and prepared.
(Full-size image HERE)
In case anyone is wondering the repaired key is s the MINUS key on the top row. Got the height and location PERFECT - RESULT!. The only things to give it away is that the silkscreening of the graphics characters is printed a little higher on the new key, and the dimple is slightly more rounded - but I reckon I can live with that!.
Got some time tomorrow so I might even get the case done,and get back to the motherboard. So, yes - progress.
Callan
Old 8th June 2017, 10:10 PM   #29
callan's Avatar
Oh, just one more picture:
This is a lineup of the repaired keyboard shaft, and a healthy one. You can see here the differing shaft length due to the different key moulding.
Callan
(Original HERE)
Old 9th June 2017, 2:13 PM   #30
callan's Avatar
Default Complete!!!!!
Well I've finished it off today. Scrubbed up rather nicely I thought!
(Original HERE)
In the end the board just needed a clean, and contacts restored. The cartridge port was flaky but some cleaning restored it to good order. All I/O ports I could test worked fine, so the 6522's are good!(Tape, serial, joystick and the keyboard). I thought about re-capping it, but decided against it.
This Vic20 was clearly much loved by it's owner if the keyboard wear and previous repairs are anything to go by - and it would have been quite a shame if it was just melted down for a few cents of metal. Judging from the extensive wear on the keyboard shafts it was used for a lot more than just playing games, and the fact that it was repaired nearly 3 years after it was made showed that it was used for some years. I'll never know the owner's name. Ironically their Victorian license number is engraved on the back: yet another indication that it was a valued item.
Personally The VIC20 was the first computer I had any hands-on experience with. My cousin in Sydney had one (a PET keyboard rev1!), and we had a ball of a time playing games and trying to program the thing. My dear uncle loved playing the games too - and I have fond memories of playing them with him the day before I had to return to Adelaide for major surgery.
So you see, the VIC20 is kinda special to me.
Just a reminder of what it was like when I received it:
There were a couple of cracks in the case - the worst one on the right hand side, cracked no doubt due to the force used to push in games cartridges. It repaired very cleanly.
Despite the wear and abrasion of the keyboard movement it actually feels quite smooth. There's no difference in feeling across any of the keys, and I'm confident that my repair is a permanent one.
In rather greasy video of it running the 'Radar Ratrace" cartridge.
So all in all I'm rapt. I've a spare "Daily Driver" VIC20 that's now in good working condition. I'm also pleased in a way that this machine, much loved by it's first owner - has been given the respect it's owners would have wanted.
'Bout time I invested in a "Penultimate Cartridge!!"!!!
And a big thanks to BadMofo, for rescuing it and tossing it my way in the first place!!
Callan
