Old 17th February 2017, 8:13 PM   #406
wraith.50
Originally Posted by AstinGC90 View Post
So 600mhz extra on the cache equates to about 12 points increase, roughly, due to slight software and hardware differences. I'll be far less worried about cache clock in future
It's only a 400mhz cache difference not 600mhz. From what I have seen of other scores, 12 points in Cinebench is a considerable difference as it takes a lot to increase your score in it.
Even going from 5.3ghz to 5.4ghz core frequency, is about a 20 point increase, so for the cache to add another 12 points is substantial for Cinebench.
wraith.50 is offline   Reply With Quote
Join OCAU to remove this ad!
Old 18th February 2017, 12:03 PM   #407
AstinGC90
AstinGC90's Avatar
Wow, that's embarrassing . 400mhz it is . I gained 97 points going from 5.3/4.8(1087) to 5.4/4.8(1184), That's why 10-20 points for a 400mhz jump on the cache clock didn't seem worth the effort.
I7-7700K Delided 5.2/4.8 1.42v daily OC, EKWC Hard Tube, 360mm rad x2 UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, 2 x Gigabyte GTX 1080ti EKWB 2050/12000 SLi. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X. Rig Pic
AstinGC90 is offline   Reply With Quote
Old 18th February 2017, 12:17 PM   #408
wraith.50
7700k 5.3 core /48-49 cache in Cinebench, gives a score of about 1150-1160 not 1087.
Even 5.2ghz gives an 1140 score. If you were getting 1087 for 5.3ghz, then there is something wrong with your setup.
Cinebench score does not jump up by almost 100 points for a 100mhz core increase alone.
Old 18th February 2017, 12:54 PM   #409
AstinGC90
AstinGC90's Avatar
It might have been the tightened ram timings then? Thanks for this info to mate, still learning here
Old 18th February 2017, 1:24 PM   #410
wraith.50
Yes tightening your ram timings does help your score. What timings were you running, do you have a screenshot of your timings ?
I am just running my XMP default timings.
Old 18th February 2017, 3:10 PM   #411
AstinGC90
AstinGC90's Avatar
In those screen shots you can see the timings in CPU z :-)
Old 18th February 2017, 4:29 PM   #412
glnn_23
A bit more testing at 5.1Ghz. AVX on 0.
Ambient 17C.
Am finding after delid that my Kabylake 7700k may run cooler than the 8 core HE and 10 core BE cpus I've used.
glnn_23 is offline   Reply With Quote
Old 19th February 2017, 9:32 AM   #413
lowdog
lowdog's Avatar
how are you guys delidding these cpu???
are you using some sort of delid tool???
lowdog is offline   Reply With Quote
Old 19th February 2017, 9:35 AM   #414
OJR
OJR's Avatar
Read back through the thread. Or at least try the first page.
OJR is offline   Reply With Quote
Old 19th February 2017, 10:00 AM   #415
lowdog
lowdog's Avatar
Ah, thanks for that
Old 19th February 2017, 10:26 AM   #416
Ratzz
Ratzz's Avatar
Thanks guys regarding my mashed board.. this is what happens when you get careless, I have nobody to blame but myself.
The DDC pump is part of an X3 combo. Its a few months old, gave no warning of its dying at all. I could probably RMA the whole thing but I CBF. I haven't tried firing it up since I removed it and put the D5 setup in there, I should probably investigate I guess.
I still don't have any more Thermal Grizzly, waiting on stock at PCCG but cooling isn't bad using my NTH1 on both inner and outer. I haven't seen temps hit 80 on any test, at any volts so far. That might change of course once I get a GPU back into the loop.. currently running a passive GT710 just to save a few resources on the CPU by avoiding IGP.
I've resigned myself to the apparent fact that my chip is ok at 51x101, but thats about all I am going to get out of it. I need about 1.4V to achieve that, more volts doesn't help but also doesn't push temps up much at all. I've even tried a run at 1.52V, temps hit 78 on some cores but I just can't get past that 5150MHz wall. At 1.45V temps are in the high 60's and the machine is utterly stable at 5150MHz, regardless of what benchmark I throw at it and for how long.
I'm thinking 50x100 @ 1.35v is going to be my 24/7 number, with temps in the 50's (Delta = ~25)
I've heard that the liquid metal can actually make a difference even if you aren't having thermal problems though, so hey, when I can get some more I *might* get lucky and manage 5.2GHz I guess.
I guess I'm disappointed when I see others hitting 5.3 and 5.4. OTOH, I have a 24/7 5GHz i7.. something I could have only dreamed about a year ago. On balance, I'm happy with my chip.
Of course, I shall continue to try and tweak it as much as I can, see how fast I can make it go.
Kaby has taken the world by surprise I think.. we all thought it would be another incremental jump but fuck these chips are good.
Originally Posted by dave_dave_dave View Post
Its like spreading peanut butter on your nipples, its so wrong but feels so right.
Originally Posted by seizium View Post
I did visit the NBN van today at Westfields North Lakes, but their internet connection wasn't working so they couldn't give me any information
My Rig
Ratzz is offline   Reply With Quote
Old 20th February 2017, 12:04 AM   #417
MortarArt
I print these tools for some people.
Mortar Art
MortarArt is offline   Reply With Quote
Old 20th February 2017, 5:39 AM   #418
Ratzz
Ratzz's Avatar
I bought one of MortarArts tools. Works very well.
My Rig
Old 20th February 2017, 11:52 AM   #419
bennyg
Seconded, the kaby lake version works fine on skylake too
P370EM 3740QM@3.9-4.1Ghz - 16Gb DDR3 - LG 1080p 120Hz - retrofitted TDP modded 1070 MXM SLI
P870DM-G 6700K delid+LM @4.5GHz 1.185V - 32Gb DDR4-2666CL18 - 4K QFHD 17" - 980M SLI @1376/2950/1.06V
Trades: >90 Complaints: <0
bennyg is offline   Reply With Quote
Old 20th February 2017, 12:01 PM   #420
DNX
Ordered a Silicon Lottery 7700k @ 5ghz + Delid yesterday to try out.
| ASUS Prime Z270-A | i7-7700K @ 5.0GHz 1.376v (Delidded) | 32GB Corsair Vengeance LED DDR4-3200 | 500 GB Samsung 960 Evo M.2 | 480GB HyperX Predator M.2 | 2 x Samsung 850 EVO 500GB | 4TB Seagate Hybrid HDD | Corsair HX1000i PSU | MSI 1080 SeaHawk EK X | TT The Tower 900 Case | ASUS ROG Swift | ASUS PB278Q | Win10 Pro x64 | Corsair Gaming K95 RGB MX RED | Krone XTD Mouse | Full Custom Water Cooling |
DNX is offline   Reply With Quote
