Go Back   Overclockers Australia Forums > General Topics > Troubleshooting Help
Old 17th February 2017, 4:45 PM   #1
Phitec Thread Starter
Default 2 similar systems, 1 gets less fps
hi guys, my problem is that in overwatch, my pc runs everything on max/epic, and can sustain 60fps(vsync) easily, whilst my gfs pc will mainly fluctuate between 35-45 on ultra (can hold 60 on low). the thing is, our systems are very similar, if anything her's is slightly better. hoping someone can help me towards the right direction to troubleshoot!
my pc = i5 4570, z87, 8gb 1600mhz, 2gb evga gtx 770, HX850, ssd for os+ hdd for games
my gfs pc = i5 4690k, z97, 8gb 1600mhz, 2gb gigabyte gtx 770, CS750m, ssd for os+ hdd for games
we both run windows 10 64bit and at 1080p
our nvidia drivers are both the same (378.66), our hard drives are not near full capacity. as far as i know all other drivers/programs are upto date. my main guess, was that it was the cpu (even though her's is better) but i reset both to make sure.
i have also swapped our graphics cards, and same outcome.
i'm currently reinstalling overwatch on her pc now, but would anyone have any idea what i should be looking at?, is there a preferred graphics/cpu benchmark program that i should use to test?
any help would be greatly appreciated, as this is doing my head in >_<
thanks
Phitec is offline   Reply With Quote
Join OCAU to remove this ad!
Old 17th February 2017, 6:07 PM   #2
russkris
Thermal throttling? What temps.
Heaven Benchmark is good.
----Rusty----
OCAU Purchases
The OC
russkris is offline   Reply With Quote
Old 17th February 2017, 6:24 PM   #3
power
power's Avatar
similar but not the same....
i5 4570 vs i5 4690K
Z87 board vs Z97 based board.
this is who we are.
power is online now   Reply With Quote
Old 17th February 2017, 6:28 PM   #4
demiurge3141
Background programs?
demiurge3141 is offline   Reply With Quote
Old 17th February 2017, 7:54 PM   #5
cpu was 50deg whilst i was playing and gpu was give or take 60deg.
i will give heaven benchmark a go soon! is there a setting for that btw?
i5 4570 vs i5 4690K
yeah but the problem here is that the 4690k/z97 is performing worse than the 4570/z87, the 4570/z87 runs it all on max comfortably, whilst the 4690k/z97 atm is getting 45/50 on high
nah i've eliminated that
p.s, in overwatch, her pc will sit around 30fps in menu/character select, once the game starts it got up to 45/50ish~
Old 17th February 2017, 9:30 PM   #6
havabeer
havabeer's Avatar
Swap your ram over and see if it makes a difference, could be a dud stick
Current rig: CPU i7 5960X - Mobo MSI x99 pro carbon - GPU 2x Titan X (pascal) - Ram 16gig DDR4 2666 G*skill - Case Custom little devil V8 - Monitor Phillips 40" 4k
Cooling - Custom water loop - 360 rad x 2 - 480 x 1 - acrylic hard tube
havabeer is online now   Reply With Quote
Old 17th February 2017, 9:44 PM   #7
adr_an
adr_an's Avatar
Have you checked chipset drivers and maybe mobo and CPU compatibility with her PC?
adr_an is offline   Reply With Quote
Old 17th February 2017, 10:24 PM   #8
oo il give that a go when i get some time, that is a possibility
yeah i've checked as much as i can, to make sure its up to date. and what do you mean by mobo and cpu compatibility with her pc?, its a 4690k and a z97, they are compatitable
Old 17th February 2017, 10:25 PM   #9
dragonFLAME
it will be screen capture or what ever Nvidia call it.
dragonFLAME is online now   Reply With Quote
Old 17th February 2017, 10:32 PM   #10
Its turned off on both pcs :/
Old 18th February 2017, 4:58 AM   #11
adr_an
adr_an's Avatar
Compatibility as in if there are known bugs with that combo. Or maybe the manufacturers website to see if there is a bios update to sort any issues.
Old 18th February 2017, 5:13 AM   #12
MoonSha
MoonSha's Avatar
Some people have found ram speed has a strange effect on FPS in overwatch, maybe check if both computers have similar results in Passmark?
Antec P182 :: Samsung 840 Evo :: Asus P6T :: Intel Xeon 5650 6x4.1Ghz :: 12GB G.Skill DDR3 1600 :: GTX1070 :: Acer 165hz 27" G-Sync :: CMStorm Trigger Blue :: G400s :: X-Fi XtremeMusic :: Z-5500D
Trades: Dimtar, vine-au, Tomee, DaFugg, Stax, kung-f00-kamel, Crambo, kooliez, luke_o, cysp. Over $1800
MoonSha is offline   Reply With Quote
Old 18th February 2017, 8:58 AM   #13
hi, i jst quickly did 'passmark performance test' my pc got 3751.7, and hers got a higher score of 4174.9 =\
edit, under '3d graphics mark'
hers is a lot lower than mine
both of our gpus are 770 2gbs just different brands
her 3d graphics mark was 3511 and mine was 6897
my results in that category were also a lot higher than hers
hmmmm
edit: soon as i get some time im going to download heaven benchmark, and run them on both computers
then switch gpus and run the tests again to see if theres any difference
Old 18th February 2017, 10:13 AM   #14
shane41
Download gpu-z. Then compare the clocks
.......my guess would have been throttling in a hot case.
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 18th February 2017, 2:01 PM   #15
i have checked the clocks, they are running as per factory oc's
i have just done heaven benchmark on both pcs and her's is underperforming by a lot!
will be switching ram and gpus to benchmark again tonight!
