Go Back   Overclockers Australia Forums > Specific Hardware Topics > Extreme and Water Cooling
Old 16th February 2017, 11:45 PM   #1
mixsetup Thread Starter
Question res/pump not straight
Hi there any suggestions how to get it straight?
https://www.dropbox.com/s/obhex1jxxgud85q/res.jpg?dl=0
I thought when I put tubing in it will end up straight but what I have seen on YouTube it will just force the tube to be pushed down a bit.
Oh it will be rigid tubes.
Thanks
AMD FX-9590, ASRock 990fx Extreme9 Motherboard,MSI R9 280X GAMING 3G , GeIL 16GB Kit DDR3 Evo Potenza @ 2400MHz, Sandisk Ultra II 240GB SSD, 2 X 2TB SATA3 HDD, 2TB NAS , 1TB SATA3, 2 X 2TB external HDD, LG Blu-Ray RW
mixsetup is offline   Reply With Quote
Join OCAU to remove this ad!
Old 17th February 2017, 11:07 PM   #2
Moptimus
Moptimus's Avatar
Thanks
It is hard up against the 4 x CDRW or whatever other piece of antiquated tech that is in the bay above.
Either pack it out from where you have mounted it, get a usb dvd drive, or go all tower of pisa and shit.
Trades: koitech; bricktop; Mr DOHC; Bertross; Nerdbox87; Vantec; Rory K; i0Nic, Creepin, trash, Unr3strictable, EpicPCcases, omaraa, madaimer, pakka, mkusanagi, mrflay, illuminati, OnGsTa, doodz, interlopr.
Moptimus is offline   Reply With Quote
Old 18th February 2017, 12:45 AM   #3
Hi there no it's not hard against the Blu-Ray bay there is an inch or so gap. The bottom where it is mounted is the surround bit which holds the hard drive cradle/bays.
Think I might have to just redo it an see if it sits flat or the screw holes I drilled are flat and no bits of mettal sticking out as there has to be something I'm not seeing or thinking of. Thats all I can think of.
Thanks
Old 18th February 2017, 5:56 PM   #4
Thanks going to just pack it out.
