Go Back   Overclockers Australia Forums > Manufacturer-specific Forums > Apple Desktop Hardware/Software
Old 27th June 2012, 11:34 PM   #1
papelboyl1 Thread Starter
(Banned or Deleted)
Default Has anyone used the built-in VPN client to connect to work (using Cisco equipment)?
Work hasn't released the latest cisco client that will work with OSX Lion so I searched the net and found a guide that lets me use the built-in one to connect to work.
I am connect at the moment and I got a new interface called utun0 and it even has an IP number that's I know is from work.
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1280
inet 129.96.140.165 --> 129.96.140.165 netmask 0xffffff00
But when I try to ssh or ping one of the servers, well I can't access it.
Does anyone know of an alternative to VPN client I can use? or maybe I need to set something so I can use the built-in client?
thanks
papelboyl1 is offline   Reply With Quote
Join OCAU to remove this ad!
Old 28th June 2012, 9:44 PM   #2
sp00nfed
I used the inbuilt VPN client to connect to Uni last year (They had Cisco 5540 as the end point). It was ridiculously simple to use, entered the details and it'd connect and route traffic without issue.
I'd check to see if there are any additional routes being added when you connect.
sp00nfed is offline   Reply With Quote
Old 28th June 2012, 11:47 PM   #3
f3n1x
f3n1x's Avatar
This.
Use:
Code:
netstat -r
f3n1x is offline   Reply With Quote
Old 1st July 2012, 12:40 AM   #4
Dogo
Dogo's Avatar
Try Shimo
Or if you aren't afraid of the terminal, try vpnc and you'll possibly need to install tuntap as well unless your existing config has already setup that interface.
I was using Shimo on my old MBP, now I use vpnc to connect to my work's Cisco VPN , it works great.
Gaming Rig:
Asrock Z68 Ex4 Gen3 | 2500k @ 4.6ghz | 8gb ram | GTX580 @ 960mhz | Titanium HD | H80 Cooler | Logi G15 K/b | Logi G500 mouse | ATH-AD700 'phones | F/Design Define R3 | 2x Noctua NF-P14 fans
Everyday laptop:
Macbook Pro 13" late 2011 2.4GHz i5 | 4gb ram | 120gb SSD
Dogo is offline   Reply With Quote
Old 2nd July 2012, 7:15 PM   #5
Clippit
Clippit's Avatar
Have I used the built in VPN client? Yes.
Eat recycled food. It's good for the environment and ok for you.
Clippit is offline   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. -
OCAU is hosted by Internode!
