Old 10th March 2017, 10:45 PM   #12976
ginger_nuts
ginger_nuts's Avatar
Yeh I know. But one of these days I will place well.
The world will keep turning
HWBot Profile = Ginger_Nuts81 Member of Australia OC team.
ginger_nuts is offline   Reply With Quote
Join OCAU to remove this ad!
Old 10th March 2017, 10:54 PM   #12977
newlife
newlife's Avatar
Originally Posted by SiriusDragon View Post
So... what are people's thoughts on Ryzen in terms of extreme OCing?
Worth it? Not worth it? Stick to Intel?
I remember them saying XFR can actually work with 'extreme' cooling methods so it'd be fun to see someone test that.
No one on this side of the fence has run Zen cold yet although I want to and because it's based on a low power process it doesn't clock that well as in around 5.2ghz with full pot ln2
Old 11th March 2017, 9:52 AM   #12978
Sgt Bilko
Sgt Bilko's Avatar
Another question for the boys and girls.
I need some B-Die but I can only order from here: https://www.jw.com.au/products/ram-m...?price=220-560
Ideally I'd want the 3200 c14 stuff but they don't carry them so what are my options?
AMD Community Manager
Sgt Bilko is online now   Reply With Quote
Old 11th March 2017, 10:17 AM   #12979
zeropluszero
zeropluszero's Avatar
If you can only order through that store, I'd ask them to order in what you want from Gskill.
TeamAU
Old 11th March 2017, 10:19 AM   #12980
Sgt Bilko
Sgt Bilko's Avatar
I might have to do that tbh.
I have store credit with them and I need to use it up and since I need new memory I figure this is a good opportunity for it.
Old 30th March 2017, 6:39 PM   #12981
shane41
Wink
EOI before up for sale Guys who would buy my bad ass delidded 4790K & Gigabyte z97 OC Force?
Proven good clocker as a Scottie Golden.
I'm actually spending more time horizontal lately with back pain........
than anything else. 5 days straight this time.
So that's it really. No point having x2 systems if I don't even use x1
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 30th March 2017, 7:36 PM   #12982
sskmercer
sskmercer's Avatar
Hey old boy. What volts did that "HOT bastard" take to get 50X and temps? I remember you doing pretty well with it in one of the older comps we had.
sskmercer is offline   Reply With Quote
Old 30th March 2017, 7:58 PM   #12983
shane41
Never put it on 50X all cores iirc The torture rack would be for you chaps.
Either that combo OR board & G3258 << that was a bloody good one too.
Doing a cull regardless NEW & OLD parts here
Old 30th March 2017, 8:33 PM   #12984
sskmercer
sskmercer's Avatar
Can you PM me what OLD parts you might be getting rid of please. As i'm def' interested in trying some old gear.
Old 31st March 2017, 9:57 AM   #12985
SiriusDragon
SiriusDragon's Avatar
Question
What sorts of volts would a 4930K require at 5GHz?
I'm starting to doubt my own memory as I simply can't get this CPU to 5GHz even though I've done it before with the same model board and similar model ram.
It'll boot no worries but as soon as windows attempts to load it'll BSOD. Usually with 0x124 (which I assume is vcore) but I've also been getting some other BSOD codes as well. The volts are starting to get into scary levels so I've decided to stop pushing them until I consult other possible reasons for the issue.
The mobo is a P9X79 WS, memory is this G.Skill kit (2666MHz 11-13-13-35-2N): https://www.gskill.com/en/product/f3-2666c11q-16gzhd
There's still a few ideas I need to try but I thought I'd consult the brains trust on here for suggestions
SiriusDragon is offline   Reply With Quote
Old 31st March 2017, 10:37 AM   #12986
Paulie_AU
Paulie_AU's Avatar
What volts are you at? My recollection I was up around 1.45 for 49x. First thing would be ram back to stock find cpu clocks and volts then bring ram back up.
Best runs had ram near 2800c12 (not my handywork finding those particular memory timings) but it hurt core. In the end I ran 2600c12 or 2400c8 on pis for better scores.
Watch the board isnt getting over zealous in tertiary timings too. Some went too tight which hurt stability. (I struggle with asus bios for mems due to lack of experience and all my learning has been on Gigabyte and ASRock)
Paulie_AU is online now   Reply With Quote
Old 31st March 2017, 11:52 AM   #12987
SiriusDragon
I'm hitting 4.6ghz at ~1.45 volts - although it should be possible with less. I've tried as high as 1.5 for 5GHz, no luck yet.
Good idea about dialing back the memory clocks... may even try in dual channel or single channel and see if that helps until I figure out a stable clock. Memory timings are an absolute mystery to me, are there any good guides for that sort of stuff or is it just trial and error? The sticks run fine at 2666mhz in XMP mode but I don't mind dropping MHz if it helps core clocks.
Here's what I've managed so far, although I need to try and rerun this now I've fixed some of the issues with my cooling.
Old 31st March 2017, 1:22 PM   #12988
sskmercer
sskmercer's Avatar
That was also a reasonably good chip to Paulie.
Old 18th April 2017, 10:29 AM   #12989
shane41
Guys advice / links for go fast in 3DMark03
Old 18th April 2017, 12:02 PM   #12990
FatBoyNotSoSlim
FatBoyNotSoSlim's Avatar
Old windows, disable all the shit. get some LOD going. make cpu fast fast
I DONT WANT YO LIFE, MONT BLANC
ALWAYS B TROLL'N
FatBoyNotSoSlim is offline   Reply With Quote
Tags
extreme, hwbot, subzero
