Go Back   Overclockers Australia Forums > Specific Hardware Topics > Retro & Arcade
View Poll Results: What 8-bit Commodore machines do you have in your collection?
Commodore KIM-1 0 0%
Commodore PET/CBM 2 3.70%
Commodore CBM-II (B128/B256/128-80/256-80/500/600/610/700) 0 0%
Commodore MAX 0 0%
Commodore VIC-20 8 14.81%
Commodore 64 (The older brown fat model known as the "Breadbin") 30 55.56%
Commodore 64C (The newer beige slim model) 26 48.15%
Commodore 64GS 0 0%
Commodore SX-64 3 5.56%
Commodore Educator 64 0 0%
Commodore 16 3 5.56%
Commodore 116 (Cost-reduced version of the C16 sold only in Europe) 1 1.85%
Commodore Plus/4 4 7.41%
Commodore 128 7 12.96%
Commodore 128D 6 11.11%
Commodore 128DCR (Cost-reduced and bug-corrected version of the C128D) 2 3.70%
Commodore Prototype/Unreleased (C65/C900/LCD/Other) 0 0%
Commodore Emulator - I don't have real Commodore 8-bit machines anymore 9 16.67%
Commodore Emulator - I've never seen/owned real Commodore 8-bit machines, but wish I did! 1 1.85%
Commodore Remake - FPGA or similar modern day implementation 0 0%
Commodore Candy - I thought Commodore was a car model...? 1 1.85%
Multiple Choice Poll. Voters: 54. You may not vote on this poll
Old 29th March 2015, 6:00 PM   #76
callan
callan's Avatar
Just a reminder, folks about the C64C cases. If you're thinking you can convert your breadbin into a C64C using one of these cases, you'll need a C64C heatshield and a metal bracket, to hold up the keyboard. Unlike the breadbins, the keyboard is NOT held up by the top half of the case, but rather is screwed into metal mounts on the BOTTOM half of the case.
Thinking of getting me some of those cases myself, though Better get onto it!
Callan
Faith-based morality isn't morality at all. It's obedience.
"I don't like this internet thing anymore, can we have the old version back please?" - BlueRaven
callan is offline   Reply With Quote
Join OCAU to remove this ad!
Old 29th March 2015, 11:09 PM   #77
nimmers
nimmers's Avatar
Callan
Hey mate,
Do you know if there is any difference between the actual cases on the two different c64cs shown here?
https://ilesj.wordpress.com/2010/07/...and-sid-model/
nimmers is offline   Reply With Quote
Old 30th March 2015, 12:41 AM   #78
callan
callan's Avatar
I believe there is no difference to the plastic casing:it has holes for both motherboards. Different brackets are used, though.
If using a breadboard C64 in a C64C case you also need to remove the metal bracket around the Joystick ports/power switch.That's straightforwards enough, though. The actual spacing of the ports and switch/power connector is the same.
Callan
Old 31st March 2015, 8:44 PM   #79
Mickatroid
Mickatroid's Avatar
Callan
What do you mean by 'heat shield' Callan? If you mean the cardboard RF shield I thought they were best removed from a heat point of view?
I know exactly what you mean about the keyboard mounts though. I am lucky enough to have a C64C with a slightly battered case and a stuck MOBO screw (thanks to some cocacola I suspect - all totally cleaned now). Soon to have a C64C in a strangely white case...
Mickatroid is offline   Reply With Quote
Old 31st March 2015, 11:03 PM   #80
callan
callan's Avatar
No, I'm not referring to the crappy foil thinggy that wraps around breadbin boards - I'm referring to something else entirely.
I have 2 C64C's: one has the reduced count board, and an NMOS C64 full-sized board. Ths NMOS one has a pressed metal heat/RF shield, with tabs that press down on the chips to conduct heat away from them.
Here's a pikkie of it.
The left keyboard support bracket is integrated with this "heatshield" thinggy.
Callan
Old 2nd April 2015, 8:50 PM   #81
Mickatroid
Mickatroid's Avatar
The heat-sink/shield is awesome. Thanks for taking a picture of it.
I have found a crappy wrap around foil thingy in a C64C too.
I know the KB mounts, quite a nice design really.
EDIT: does the full size board have a 6581 SID?
Old 2nd April 2015, 10:23 PM   #82
callan
callan's Avatar
It's not as awesome as it looks: it takes a fair bit of effort to get all the tabs contacting the chips properly (effort that's typically not done at factory assembly). The C128 has the same arrangement, and due to the board being much larger it's even more of a pain to get right. They also seem prone to rusting, too.
This one does - yes. 6581v4-AR (Advanced Resonance), The last version before the move to HMOS.
Callan
Old 2nd April 2015, 10:39 PM   #83
nimmers
nimmers's Avatar
I grabbed a second c64 this week because of that kickstarter.
I noticed that the new one I got is like Callan's
I opened it up and its completely different to my other one, no cardboard in it. That heat shield thing had all the prongs not touching the chips and I had to bend them all down again slightly. Probably should get some new thermal paste. The top one does have a 6581 SID.
EDIT: Callan got in 20 seconds before me
Old 3rd April 2015, 1:12 PM   #84
flu!d
Ubuntu Mate 16.04 LTS
flu!d's Avatar
Guys, I'm after a C64 breadbin case and keyboard in reasonable condition, if anyone has anything for non inflated eBay prices please let me know.
Even a whole breadbin c64 for a realistic price will do.
Show us yer HTPC!
Dell T5500, Xeon X5675 Hex core @ 3.46Ghz max, 24GB RAM, GTX 670FTW, 60GB OCZ Vertex 3 SSD OS drive, 2 x 1TB home/storage drives, Dual Acer V243HQ 1920 x 1080 monitors, Ubuntu Mate 16.04 LTS and loving it!
flu!d is offline   Reply With Quote
Old 3rd April 2015, 6:57 PM   #85
Mickatroid
Mickatroid's Avatar
Interesting question about what a 'realistic price' for an original shape C64 is.
I would say that a fair non-ebay price for a working computer with a power supply and a couple of bits and bobs is around $100 (not that I have one for sale Fluid). Anyone think different?
Old 4th April 2015, 9:05 PM   #86
nimmers
nimmers's Avatar
Between $100 and $150 seems to be the going rate after shopping for a couple of weeks.
I noticed a lot of people seem to be using dell LCDs with their c64s. Is there some easy trick to getting a PAL one going? I have a Dell 2407WFP - it has the s-video and composite inputs but neither seem to want to work with the 50hz input out of the c64.
Old 5th April 2015, 12:15 AM   #87
callan
callan's Avatar
That's weird, as that's precisely the monitor that I'm using on my (PAL) C64, on SVGA. A link to a recent photo of a PAL C64 hooked up to one HERE. I'm using a made-up cable, but you can get bought ones easily enough.
Does the C64 work with anything else?
Callan
Old 5th April 2015, 7:52 AM   #88
nimmers
nimmers's Avatar
Callan
Yep my c64 works fine on my television using s-video or composite. I'm using the s-video cable on page 2 here: http://www.retrocomputershack.com/
Would love to figure out why it doesn't work, I have the same issue trying to get my PAL SNES to work on it. I actually have 2 of these monitors and it happens on both.
Old 5th April 2015, 9:18 AM   #89
lupin Thread Starter
lupin's Avatar
Lets face it C64 and a crt is the only way to go.
www.youtube.com/c/lupzvlogs
2009 Yamaha FZ1N
lupin is offline   Reply With Quote
Old 5th April 2015, 9:59 AM   #90
flu!d
flu!d's Avatar
I remember I paid $100.00 for my breadbin C64 that I bought off a schoolfriend in 1984!
Show us yer HTPC!
