Go Back   Overclockers Australia Forums > Specific Hardware Topics > Retro & Arcade
Old 4th November 2015, 1:19 AM   #121
Kafoopsy
Kafoopsy's Avatar
Originally Posted by shaneb74 View Post
I think the issue is unless it has on-board video which I doubt it does not have a video card
The Cyrix MediaGX cpu has video built in. That board is a MediaGX board, while the socket is physically a socket 7, a standard Pentium or K6-2 would not work in it.
Edit: Unless he has tried to put a Cyrix MediaGX cpu in a standard socket 7 board. That wouldn't work either.
I was a member of the THE SLOT-T PARTY!
I did have a: Tualatin Celeron 1.2 on MSI 6163 Slot 1
My motto: Latest version of software is not always best.
Kafoopsy is offline   Reply With Quote
Old 6th November 2015, 6:41 PM   #122
shaneb74
Thanks for not bidding against me, I like the case regardless if the voodoo 2's don't work, so the midi tower I have my p133 in will go into it as the case it's in has no cover. Worst case I've spent $15 on a decent midi case that I can put working parts in
Cheers,
Shane.
shaneb74 is offline   Reply With Quote
Old 7th November 2015, 9:11 AM   #123
cavanor
GoG.com is having their Autumn Sale
cavanor is offline   Reply With Quote
Old 8th November 2015, 12:23 PM   #124
pfrcom
Any other BX tragics ?
If so, I found irresistible http://www.ebay.com.au/itm/Intel-Pen.../271954663454?
Asking price for a Celeron 900 or lesser P3 is much higher, even from the same vendor
And postage charge is the same for two
pfrcom is offline   Reply With Quote
Old 8th November 2015, 1:00 PM   #125
Relentless
Relentless's Avatar
I have a 5 x spare P3 1000Mhz Socket 370's CPU's here if anyone in Adelaide is after some.
Relentless is offline   Reply With Quote
Old 8th November 2015, 5:52 PM   #126
shaneb74
Ok picked it up, doesn't look like it has any video out at all, no on-board that I could see, no port on the motherboard for a vga connector. The 2 3dfx cards are Diamond Monster 3D II 12 meg cards, look in great condition chances are and I'm hopeful that they are perfectly fine. Pretty happy for $15
Cheers,
Shane.
Old 8th November 2015, 6:37 PM   #127
gambo
Cheers,
Shane.
Great purchase! chances are they will work fine. fingers crossed
Dual PIII-S 1.4Ghz | GA-6VTXD | 2gb | 7900gs 512mb | 128gb ssd | Win 7 & XP
K6-III+ @ 600Mhz | GA-5AX | 512mb | Fx5700ultra / Voodoo2 SLI | 128gb ssd | Win2000
Pentium 200 mmx | GA-5AX | 128mb | Voodoo3 3000 | 20gb HDD |Win98se
gambo is offline   Reply With Quote
Old 8th November 2015, 11:33 PM   #128
pfrcom
If it's the same as here ...
http://www.blackknightpinball.com/rf...it-596-gxm.pdf
... shows a VGA/Audio connector and what looks like a proprietary header cable
Maybe a VGA header cable from an AT board with on-board VGA will work on some of that connector's pins - the few I've had through my hands seemed to be interchangeable
Old 9th November 2015, 11:18 AM   #129
shaneb74
Yeah I remember seeing a header there but for some reason I seem to think it didn't list VGA on it, I'll check again when I get home. Either way it has a dead PSU.
On the upside the 2 12 meg Voodoo 2 cards appear to be in perfect working order. The only problem is unless I move up to an ATX machine I don't seem to have a socket 7 board that I can fit the two cards in lol all my boards have the CPU placed directly in front of the PCI slots. At least one of them though a single card fits missing the p200mmx heatsink by about 5mm
Now to get a passthrough cable so I can use it without swapping the monitor cable over everytime it uses the voodoo 2. Wish I had kept my original voodoo 1 card and cable but that went missing probably 15 or so years ago lol
EDIT: Checked the motherboard and yep it does have the vga/audio header there, it's a slightly different version as it has 3 ISA slots but it's the same.
Cheers,
Shane.
Old 11th November 2015, 11:40 AM   #130
shaneb74
Kinda retro and bargain, picked up one of these, it says flash sale ending today but I actually bought it on Monday and it still is the same price, it's a VGA splitter but works perfectly as a vga passthrough cable for $5.44;
http://www.dicksmith.com.au/computer...-y-dsau-xh4242
Tested it last night and must say I'm impressed with the quality of the signal, I remember back when I had a voodoo 1 I wasn't that happy with the loss of quality with the passthrough.
Cheers,
Shane.
Old 11th November 2015, 3:05 PM   #131
BuuBox
BuuBox's Avatar
This seller has a few bulk lots of CPUs:
http://www.ebay.com.au/itm/7-x-Gold-...-/381463264152
http://www.ebay.com.au/itm/5-x-AMD-C...-/321917317357
http://www.ebay.com.au/itm/6-x-Intel...-/321917318084
http://www.ebay.com.au/itm/15-x-486-...-/321917315664
There's more, but I chose the more interesting ones.
I quite like this complete system for sale:
http://www.ebay.com.au/itm/Cyrix-IBM...-/321916824358
Desktop: Gigabyte GA-990FX-Gaming, AMD FX-8350, 16GB DDR3, Sapphire Radeon R9 290, Plextor M8Pe(G) 512GB M.2 SSD, 2TB WD Black, EVGA 850W, Kogan 27"
Blast from the past: Shuttle HOT-591P, Cyrix MII-400GP, 64MB PC133, Voodoo Banshee, 16GB SSD, Creative Sound Blaster AWE64
Trades: Too many to list. Hundreds.
BuuBox is offline   Reply With Quote
Old 13th November 2015, 12:18 PM   #132
BuuBox
BuuBox's Avatar
Another complete system from that seller:
http://www.ebay.com.au/itm/Pentium-2...-/321918785878
I like the case!
Old 19th November 2015, 10:45 PM   #133
breech
breech's Avatar
http://www.ebay.com.au/itm/201468427401
Saw a $5 broadcast monitor for pickup in Vic. Should be good for consoles / Amiga / Atari etc. May need mods to support your format.
breech is offline   Reply With Quote
Old 26th November 2015, 12:59 PM   #134
DonutKing
DonutKing's Avatar
Whole heap of stuff on the gold coast, but the buyer won't split:
http://www.gumtree.com.au/s-ad/neran...ot-/1095197996
Might be a job for Shane and his trailer :P
DonutKing is offline   Reply With Quote
Old 26th November 2015, 1:39 PM   #135
neoprint
neoprint's Avatar
If you do, go for a casual drive north and let me have a go through it :P
Xeon X5650 @ 4.4GHz | Asus P6T-Deluxe V2 | 24GB Mushkin Blackline Ridgeback @ 1683MHz CL8 | Samsung 850 Evo 250GB | 2x Seagate 3TB RAID0 | MSI Radeon R9 290
neoprint is offline   Reply With Quote
