Old 30th August 2015, 12:06 PM   #61
BarboneNet
BarboneNet's Avatar
Originally Posted by Acidsys View Post
A little bit quicker
congrat my ddr are tighter, but you efficency is better!!!
i have to work on secondary-terziary timings
good job Acidsys
BarboneNet is offline   Reply With Quote
Join OCAU to remove this ad!
Old 30th August 2015, 9:44 PM   #62
Paulie_AU
Paulie_AU's Avatar
Gahhhh forgot how slow pentiums do this. Might have a result tomorrow........
Mr_McPoo
Paulie_AU is offline   Reply With Quote
Old 3rd September 2015, 3:00 PM   #63
paulbaird87
paulbaird87's Avatar
Smile XTU 2411
XTU 2411
5960x at core 4.5ghz 1.25v, cache 4.6ghz 1.25v
Corsair Dominator Platinum 2666 @ 3200mhz 16,17,1743,1t 1.35v
The cache helped alot!
Score at stock cache was 2280
Score at 4.5ghz cache was 22402
Score at 4.6ghz cache was 2411
i found this to be the case with cinebench and realbench as well, cache really helps scores, more so than memory speed and timings!
paulbaird87 is offline   Reply With Quote
Old 3rd September 2015, 3:19 PM   #64
newlife
newlife's Avatar
I guess the question is if uncore above the cap is allowed because if it was up to me it wouldn't be since very few x99 boards can do that
Old 3rd September 2015, 3:35 PM   #65
zeropluszero Thread Starter
zeropluszero's Avatar
Lets say 4.5ghz cache cap for all platforms.
/as such paul, I'll have to get you to lower it for a valid result.
TeamAU
The house that Doritos built
Old 4th September 2015, 2:53 AM   #66
paulbaird87
If that's the case take my 4.5ghz cache score. I will put another post up with a validation and try to bring the volts down a little!
Old 8th September 2015, 10:08 AM   #67
Bullants
Bullants's Avatar
Will setup and run some xtu CPU killer today ahah,will be running cold memory's and prob will run it in instalments 4.5-5.0-5.2 and so on Tested chip last night and does run @ full pot but these chips do run little hot that = more ln2,I really need to get ln2 cheap very soon if I want to test anything other then memory because it not nice looking at two flask and thinking how many dollars I'm waisting just on them that go quit quickly with CPU or gpu
Bullants is offline   Reply With Quote
Old 8th September 2015, 10:38 AM   #68
I find the venom much more efficient on ln2 than the F1, not sure whats the better pot though considering the heat output.
TeamAU
Old 8th September 2015, 10:48 AM   #69
BarboneNet
BarboneNet's Avatar
Guys im going to prepare a container for bring all my stuffs from italy.....if ln2 are so expensive here, maybe is better if i order one cascade from dimastech!!!!
Old 8th September 2015, 10:48 AM   #70
jjjc_93
jjjc_93's Avatar
Yeah the cost of LN2 is a killer.
Delidding nets 200-300mhz from what I've seen so far, and the chips don't necessarily clock their best with full pot temperatures (sometimes want higher) - that's just the bad thermal transfer.
Team.AU
jjjc_93 is offline   Reply With Quote
Old 8th September 2015, 11:29 AM   #71
Bullants
Bullants's Avatar
I don't know if this chip has been delid but this chip does like full pot now I've worked out how to by pass CB,I have passed 32m 4 core 6.3ghz,with cb -140 the chip freezes in windows @ 6ghz @ idle.The required volts to by pass cb may still see the chip scale MHz wise at -150 but think this seems to like full pot seeing these volts do bring the heat up,ill have to test that more later
I just used the Gemini fast base for that test Matt,just wanted something easy and fast to test
Old 8th September 2015, 7:59 PM   #72
Bullants
Bullants's Avatar
Will post 4.5Ghz run up later when I get it off drive,here is a 5.4hz run.Just need to delid cpu now before I push any further on this bench ahah
These memorys are little wounded and only run 3200 cl12 on air but after about 30 mins on cold they come to life ahaha what i mean is they only run @ 3600Mhz to start with on cold then 30 mins on they let me run 3733,volts cold dont change nothing until they been cold for X amount of time
Old 9th September 2015, 8:45 AM   #73
Bullants
Bullants's Avatar
I've only briefly tested z97,x99 and now z170 but this z170 responds by far the best on memory tweaking for xtu
Old 9th September 2015, 8:46 AM   #74
sskmercer
sskmercer's Avatar
Great work and efficiency showing Bullant, love the scores your putting up mate.
sskmercer is offline   Reply With Quote
Old 9th September 2015, 9:00 AM   #75
BarboneNet
BarboneNet's Avatar
Bullant number1
