Old 9th September 2015, 8:10 AM   #76
Bullants
Bullants's Avatar
Originally Posted by sskmercer View Post
Great work and efficiency showing Bullant, love the scores your putting up mate.
Thanks Scott ,I'll delid now before I try again,you going to really like this platform man
Originally Posted by BarboneNet View Post
Bullant number1
Ahahah,I'm just thinking how I can push my memory more I want cl11 4000 bench able,is early days but I'll keep playing and testing and won't give up
Bullants is offline   Reply With Quote
Join OCAU to remove this ad!
Old 14th September 2015, 6:22 PM   #77
headin2001
headin2001's Avatar
Quick first run as a baseline. No tweaking yet.
1561 - 45x 2t xmp, everything else stock
1576 - 45x 1t xmp, everything else stock
headin2001 is online now   Reply With Quote
Old 15th September 2015, 6:23 AM   #78
headin2001
headin2001's Avatar
Add a little Cache - 1588
Fully laden Windows 8.1 Pro install too.
Old 15th September 2015, 8:04 AM   #79
Bullants
Bullants's Avatar
Looking good mate
Old 15th September 2015, 8:52 AM   #80
Paulie_AU
Paulie_AU's Avatar
pix
Nice jump there. Amusing the performance given you were gaming and on teamspeak also last night with the same setup.
Definately a fully bloated OS. Ram speed rules it seems.
Paulie_AU is offline   Reply With Quote
Old 15th September 2015, 9:34 AM   #81
headin2001
headin2001's Avatar
I'll try some with higher ram speed, same timings and see where it goes. Speed seems the biggest part of it all.
I'll also be doing a new OS sometime which might help That OS has gone from X79, to 3 different Z97 boards and now Z170
Old 16th September 2015, 7:30 AM   #82
headin2001
headin2001's Avatar
Bit more last night. Had spent a good bit of time working out what works and what doesn't with these stick, more of what doesn't though
Had these setting booting, but no cigar
Went chasing some 3600 and got there in the end. Tightening things up helped a bit, but not as much as I'd hoped with the extra speed and tighter secondaries and few tertiary's. 1.55vdimm for this, could be the OS limiting now, or the iol's which I'm still learning, and still not 100% on where the RTL's should be at this speed/latency.
Also, cracked 1600, but with the ram set to 3600, the bclk raised it to 4515 so didn't count, something to be aware of, my rookie error. The above run is with the bclk dropped to match 4500.
Few walls learnt though, originally thought TRFC was causing me problems under 300, but turned out another 2 timings, so I can drop this a bit more yet. TWRWR_dd/dr wont go lower either, which could also be a key, but I'll keep trying. Write latency is also higher than I thought, might be able to drop it to 10 or 9 yet with any luck.
Latency is still up too, around 43. Might pass at CL15 with MOARVOLTStm.
Next I think I'll go back to 3466 and tighten it up more and see where it goes.
Timing Configurator is for Bullant, we know he loves it
Old 16th September 2015, 8:02 AM   #83
Bullants
Bullants's Avatar
Awesome man,you've only had platform for few days and looks like your working it out now,yeah trfc seems big factor as all different ics types like it different and little too tight can be the difference to booting or not
Not sure if your still on old OS but wouldn't it be funny if you install fresh os over the top of it and new OS was worse haha,would be hard to replace that old OS that has seen 4-5 platforms ahah
Old 16th September 2015, 9:01 AM   #84
headin2001
headin2001's Avatar
Might need MOARSSD so I can keep this little beauty! Still same OS, gaming/cad/video fully loaded with lots running in the background, including Norton/Razor/Origin/Spybot/Nvidia
Old 16th September 2015, 2:41 PM   #85
newlife
newlife's Avatar
#noteventrying
Old 16th September 2015, 3:06 PM   #86
zeropluszero Thread Starter
zeropluszero's Avatar
#neilstyle
#ibetherunsitonln2andneverpours
#nevapour
#wildtempswings
#cpukillah
#theneil
TeamAU
Old 16th September 2015, 3:37 PM   #87
headin2001
headin2001's Avatar
Originally Posted by zeropluszero View Post
#neilstyle
#nevapour
#wildtempswings
#cpukillah
#theneil
#missedmy1595
#dontworry
#illimprovetonight
Old 16th September 2015, 3:55 PM   #88
Lol, wasnt missed, I just hadnt updated it :P
TeamAU
Old 16th September 2015, 4:23 PM   #89
headin2001
headin2001's Avatar
Originally Posted by newlife View Post
#noteventrying
#itsatweak
Old 17th September 2015, 8:22 AM   #90
Bullants
Bullants's Avatar
