Old 22nd September 2015, 7:38 PM   #106
Bullants
Bullants's Avatar
A Quick run on Z97 LN2 board ,memory air
Bullants is offline   Reply With Quote
Old 23rd September 2015, 9:06 PM   #107
BarboneNet
BarboneNet's Avatar
Originally Posted by headin2001 View Post
Awesome runs there bullant.
Did some 2 stick today, but giving up on that. Will do a fresh install to W10 soon and see if I get an improvement, but down 180 points on Quad sticks.
pix
No idea the cause.
don't install turbov! TL's released a new version that resolve the low performance with xtu!
the version x.x.x.xxxxxxx.37 it's ok
BarboneNet is offline   Reply With Quote
Old 23rd September 2015, 9:14 PM   #108
BarboneNet
BarboneNet's Avatar
could you try with 4modules or you have a board with only 2 dimm sockets?
Old 23rd September 2015, 10:12 PM   #109
Bullants
Bullants's Avatar
This is gigga 2 dim board,I do have ocf z97,when I get time I'll try 4 dims on z97
Old 24th September 2015, 2:20 PM   #110
headin2001
headin2001's Avatar
Sorry Barebone, I'm not following, where/who is this. I have the turbov off the disc installed, but rarely use it, only for tuning voltages for stability tests. Haven't done my OC Panel yet either, so thats the only reason.
Just doing everything out of bios.
So many problems with ram right now, 4 sticks wont go over 3640, get 41/55/44 code, very repeatable. Even on auto volts for IO and SA I 55 code with 3333C16 setting. Hopefully new bios might help.
headin2001 is online now   Reply With Quote
Old 24th September 2015, 2:24 PM   #111
zeropluszero Thread Starter
zeropluszero's Avatar
he's referring to tengliang ng, aka coolice, he's an engineer with Asus
http://kingpincooling.com/forum/showthread.php?p=31049
TeamAU
Originally Posted by shane41
Another freezer's words of wisdom
Old 24th September 2015, 2:59 PM   #112
headin2001
headin2001's Avatar
Cool, I rarely look on Kingpins Forum. Thanks Matt
Old 24th September 2015, 3:02 PM   #113
Well worth a look.
Not as heavily trafficked as others, but still useful tidbits.
That and Hwbot are my go to. OCN is useless, XS pretty dead.
TeamAU
Old 25th September 2015, 9:11 PM   #114
Bullants
Bullants's Avatar
How's it going mate,you get it all working again?
Old 26th September 2015, 7:02 AM   #115
headin2001
headin2001's Avatar
Thumbs up
It's all working again, but haven't had a chance to push it again yet. Busy times. Might have a small push at it again tonight.
Just think the IMC isn't up to it, or the secondary settings are too tight at higher speeds.
Old 26th September 2015, 7:16 AM   #116
BarboneNet
BarboneNet's Avatar
on ROG board, try to use high vccio vcsa vdmi after 3333mhz!
with my Samsung ddr, i need to use vccio vcsa 1,25v and vdmi 1,3v for 3600 15-18-18-28 1t!
i don't know how much is safe in dayuse, so i prefer use 3466 15-18-18-28 with only 1.15 on vcsa vccio vdmi......
but i think there is some bios problem on ROG board....because if i use only one stick, in one slot near the cpu, i can get high frequency with tight subtimings with few volts!!!!
if i move the same module in one slot far the cpu, it needs more volt and imc aswell!!!
Old 26th September 2015, 8:56 AM   #117
Bullants
Bullants's Avatar
Yeah I've been also thinking about skylake imcs,I've only tested this one chip and have no idea if it's good bad,will need to try couple more chips myself to see the difference
Good to see its all still working ok
Old 26th September 2015, 10:23 AM   #118
headin2001
headin2001's Avatar
Yeah, VCCSA/IO both need to be 1.25v with this chip to post over 3333 with 4 sticks. No problems with 2. DMI 1.31v. Haven't looked at PLL (1.0v) or PCH (1.1v) yet.
Good news is I now have it stable at 4700 with 1.36v vcore. Cache needs more volts though to increase over 42x.
Are they 3600C17 sticks Barebone, or 3200's?
Old 26th September 2015, 10:41 AM   #119
bob(nz)
bob(nz)'s Avatar
Interesting - will have to check this out. Been doing all my mem binning furtherest slot......
Trusted Traders: Over 500 Successful trades on OCAU - PM me for details
Proud member of http://teamau.net
bob(nz) is offline   Reply With Quote
Old 26th September 2015, 7:00 PM   #120
BarboneNet
BarboneNet's Avatar
My sammy are ripjaws v black 3200 cl16....but i have only 2 sticks
