Go Back   Overclockers Australia Forums > Other Topics > Mobile Phones & Devices
Old 14th March 2017, 12:53 PM   #2521
AERO
AERO's Avatar
what site does everyone use to check the iv of the pokermon they have? ive almost got my 400 magikarp kandi and havnt got a gyrodos, the site ive used suggests it will vary between 95% to 65% or so
just want to check it a bit more accurately
"GO AERO CLUB MEMBER NUMBER #69"
quote from killer bee --->
"I still cant fathom it, how can pee shoot out 90 degrees from the nozzle direction."
AERO is offline   Reply With Quote
Join OCAU to remove this ad!
Old 14th March 2017, 12:55 PM   #2522
Fatmantan
Fatmantan's Avatar
What phone do you have?
| Dell 2407WFP-HC | i5 2500k | Asrock P67 Extreme 6 | 8gb Kingston HyperX 8500 | EVGA GTX770 | 4.2tb Storage |
| Canon 7D | Tokina 11-16 | Sigma 30 1.4 | Canon 15-85 | Canon 70-200 F4L | Canon 430ex |
| D3 Profile | Over $20,000 Successful Trades | GTA V Stats |
Fatmantan is online now   Reply With Quote
Old 14th March 2017, 12:55 PM   #2523
Cpt.J.Sparrow
Cpt.J.Sparrow's Avatar
Originally Posted by metalrain View Post
I know the game just recently came out there in SK, but there must be some local maps right? I'd take advantage of those before the Niantic banhammer (or next API update) rolls through. Makes targeting specific and rarer Pokemon much easier. Or if there's thriving TSR or similar community there, you might be able to find regular spawns and nests for those rares.
Apparently, there are two (Seoul and Busan). I am pretty sure there isn't any for the city where I live.
Originally Posted by Hater View Post
Has anyone ever seen an evolution of a 'mon that needs an item (Slowking, Steelix etc) in the wild?
Had this discussion on a Korean Po Go forum. As far as we know, no wild slowking, bellossom, etc.
EDIT: No wild special evo spawns, but I did catch another Dragonite. This time a whopping 46CP. That's level one if you were wondering... At least it has Dragon Tail/Outrage and again, a very easy 20 Dratini candies. Have a fair amount of them too, enough for a small squadron of Dragonites, but I'm still saving my candies.
I caught my third wild dragonite this morning as well. 50cp w/dragon tail/outrage. Used only 1 razz berry and 1 ultra ball, unlike the other two dragonites to which I threw at least one dozen ultra balls and just as many razz berries.
Addendum: IV calculator is stating 89-96% for the dragonite!
Powered up several times to get an accurate IV. It's 15/14/14! Wtf!
Last edited by Cpt.J.Sparrow; 14th March 2017 at 1:04 PM. Reason: More info on the dragonite
Cpt.J.Sparrow is offline   Reply With Quote
Old 14th March 2017, 1:33 PM   #2524
Cpt.J.Sparrow
When cp and hp are really low, it's very hard to calculate accurately, and you aren't supposed to use ones that can automatically and accurately determine IVs because those apps access the server or Po Go app (root/jailbreak necessary).
I use this. Very reliable. You might have to power up to accurately determine IVs using the advanced options. However, I have one snorax whose IV cannot be accurately determined even after 20 odd powerups; it's always between 84 to 89 no matter which IV calculator I use.
Old 14th March 2017, 2:53 PM   #2525
nibennett
I have an iPhone and so use Poke Genie. it works using a screenshot and the evaluation so no chance of a ban.
i7 5820K, 16GB DDR4, GTX 760, Corsair H100i Samsung 4K
nibennett is offline   Reply With Quote
Old 14th March 2017, 3:35 PM   #2526
metalrain
metalrain's Avatar
I use this one; https://pokeassistant.com/main/ivcalculator but if you combine it with the in-game appraisal system, it should be easy enough to narrow it down, unless it's really low level and/or low CP.
I personally use the in game appraisal first, if it's about 80% then I use the that calculator, otherwise, if it's not a rare, then straight into the trash it goes.
Have a look around, there's a bunch of non-city specific map trackers online and in app form, but they're not as reliable nor as easy to use I guess. I used to be all over Pokehuntr.com, but that's a shell of what it used to be and Pokesear.ch is ever so annoying to use most of the times and has fairly weak search radius.
But I'm lucky enough to basically have a state wide cover via several city map trackers though
Yeah I'd safely assume so. I've seen several Dragonites, Blisseys and even a couple of Tyranitars, Ampharos and Togetics pop-up on those trackers since the generation two update but none of the item evos so far.
Man, I'm not having such a hot luck even with finding a higher IV Dratini. Wouldn't think I'd bump into a Dragonite like that. Highest IV I have is an 81% Dratini, but it's only level 15, so not exactly worth evolving imho.
ASUS Z97i-PLUS|Intel i7 4790K|G.Skill F3 16GB|Samsung 850 PRO 256GB x2|Gigabyte G1 GTX 980|Seagate 4TB|Barracuda 1TB|SteelSeries 7G|Kana V2|QcK XXL|Yamakasi DS270
Canon EOS 6D|Speedlite 430EX II|90EX|50mm ƒ/1.8 STM|Sigma 35mm ƒ/1.4 ART|12-24mm ƒ/4.5-5.6 II|Tamron 24-70mm ƒ/2.8 VC|70-200mm ƒ/2.8 VC
Samsung Smart PC Pro|Galaxy Note 4|FiiO E10K|Kingston HyperX Cloud Core|Philips SHP9500|HiFiMAN HE-350
metalrain is offline   Reply With Quote
Old 14th March 2017, 7:36 PM   #2527
AERO
AERO's Avatar
that pokeassistant is what i use, went through everything i had and made fav all the ones 90% or over. maybe a couple are 85 or so.
think my dragonair is about 93% or so, the magikarp shows anywhere between 90down to 60%, think i should just power up before evolving to see what the calculator says?
Old 14th March 2017, 8:20 PM   #2528
metalrain
metalrain's Avatar
You should be able to use the appraisal system to at least narrow it down. Use this as a reference point.
If you can afford to level it up, go for it.
But give us a screen shot and some of the details about the appraisal and we can have a go.
Old 16th March 2017, 11:15 AM   #2529
metalrain
metalrain's Avatar
Yes! Snorlax is spawning for me again. Just caught a nice 13/13/7, low CP but again Pinap berried easy candies . First one I've seen and caught for about a month now. Looking forward to hunting them down again and stocking up on candies.
Old 16th March 2017, 3:16 PM   #2530
Stevros
Stevros's Avatar
Such a painful pokey to get candies for. I was walking mine for so long then i hatched one in the double candy event. Cha Ching!
Rig: i7 : 280x : 6gb
Stevros is offline   Reply With Quote
Old 16th March 2017, 3:43 PM   #2531
metalrain
metalrain's Avatar
Yeah I want to be buddying one too, but I prefer and I'm prioritizing Larvitar candies right now, just in case I manage to find another decently IV'd one to evolve/level up.
Old 16th March 2017, 5:36 PM   #2532
prezident doom
prezident doom's Avatar
Happened to me with Lapras
After investing all my candies powering it up Lapras got Nerfed
| AMD FX8320 : ASUS Sabretooth 990FX R2 : 8GB Coarsair Vengeance 1600mhz : 1TB SATAIII HDD : R9 380 4G : Samsung 2350 |
| Over 25 Successful Trades Totaling $2600+ |
prezident doom is offline   Reply With Quote
Old 16th March 2017, 6:33 PM   #2533
metalrain
metalrain's Avatar
Haha yeah I was wondering what was with that, but then I remembered that Lapras event in Japan, so I think they delayed it to make them more worthwhile to catch. I've only have two Laprases, one hatched way back in July last year and one caught a couple weeks back. Wasn't so excited that time around.
Old 16th March 2017, 9:40 PM   #2534
Hater
Hater's Avatar
7th day steak for PokeStops yielded a sun stone so now I have a Sunflora.
Waiting on: Amphrose, Unown, Bellossum, Porygon 2, Seadra and Miltank
Originally Posted by elvis View Post
Quote me in 2026, and if I'm wrong, I'll buy you a nice steak dinner.
Hater is offline   Reply With Quote
Old 17th March 2017, 12:14 PM   #2535
metalrain
metalrain's Avatar
Got an extra Dragon Scale and Upgrade yesterday (normal Pokιstop spins) so I decided to just f it and evolve and get a Kingdra, Porygon2 and as well as a Scizor and a Steelix (had 8 Metal Coats stocked up) they were all 90% IVs or so and yes, all rolled horrible movesets
Only item evo missing is Bellosom, but there's an Oddish cluster spawn in the city so I might just pick one up and just get it over and done with too.
Still missing Unown, Cleffa and Elekid as well as the regional exclusives along with the Bellosom.
