Go Back   Overclockers Australia Forums > Specific Hardware Topics > Retro & Arcade
Old 23rd November 2016, 11:19 AM   #76
Matthew kane
Well now I know why my 2 XFX and Winfast 7900gt's are artefacting. Knocked off smd capacitors near the gpu, pci express connector link and 1 behind a Samsung memory ic. Measured them all to be in the 200 to 280 pf range and look to be 0805 package.
I don't have any smd capacitors but do have polystyrene caps in those rated ranges, should I solder them away or order some appropriate smd replacements? Decisions decisions decisions....
Intel i7 3960X @ 4.7GHZ - Noctua NH-D14 | 16GB OCZ Platinum Series DDR3 1600MHZ | Asus Rampage IV Extreme (4901 bios) | Zotac AMP! Edition GTX 980 Ti | PNY GTX 465 unlocked to 470 | Creative X-Fi Titanium Fatality Pro with LME47920's opamps | OCZ Vertex 3 240GB | OCZ Vertex Plus 120GB| 1TB WD Black, 2TB WD Green, 4 x 2TB Seagate LP | Enermax Revolution 85+ 1250watt | Antec P280 + Veris Elite | LG BD Rewriter
Matthew kane is offline   Reply With Quote
Join OCAU to remove this ad!
Old 23rd November 2016, 11:29 AM   #77
shane41
May also be unrelated. Caution here unstable volts.
Could be after all this time " not checked " you need bake a pair of cookies
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 23rd November 2016, 11:58 AM   #78
Matthew kane
Have already reballed the gpu core and it still artefacts so that is out of the equation. The early 7900gt was a failure batch as they would all artefact due to the Samsung memory going bad really fast. The pcb was also the stock nvidia reference design.
To test further I flashed a lower clocked and newer bios by Asus onto the Leadtek and it reduced the artefacting by 10 fold, remaining artefacting are small dots.
Old 23rd November 2016, 5:09 PM   #79
atmo Thread Starter
atmo's Avatar
Originally Posted by shane41 View Post
Atmo come out to play......the weapons arrived
I'm still trying to source a 965 board to do a bit of a chipset comparison (single GPU).
Up for a socket A challenge?
atmo is offline   Reply With Quote
Old 23rd November 2016, 5:28 PM   #80
shane41
Watching a beauty atm ......but $100+ & the ship here
462's what benchmark? Doing the 15year limit thing?
Old 23rd November 2016, 5:35 PM   #81
atmo Thread Starter
atmo's Avatar
If we go by the 15 year rule it'll (currently) exclude nforce2.
Which benchmark would you prefer?
Old 23rd November 2016, 6:29 PM   #82
shane41
Not all that exciting for me. While the KT266/333/400/600 were OK.
Prefer bust out an Abit An7 & let loose nordish scud missile
Old 27th November 2016, 4:26 PM   #83
atmo Thread Starter
atmo's Avatar
Initial socket A result:
That's about as far as I'm willing to push this old gear, but there might be a little more to gain from different driver versions etc.
Old 28th November 2016, 9:24 PM   #84
shane41
That's a good score. How are temps? Did you try an ATI gpu?
Old 28th November 2016, 11:24 PM   #85
atmo Thread Starter
atmo's Avatar
Temps are in the safe range at ~1.8v using a TT silent tower with the stock 92mm fan. I originally planned to use a Big Typhoon, but the mounting for the VX version (which I have now) is different to the original and won't work with the bolt through brackets without modifying the brackets.
I don't have any later high end ATI AGP cards currently.
Old 28th November 2016, 11:30 PM   #86
shane41
How are you monitoring temps? Software running OR probe to board somehow?
My concern atm is ambient here......." like a desert " ha still 25deg right now.
Research on the ATI cards, they run higher core frequency......that I think is an added boost.
Old 29th November 2016, 5:13 PM   #87
atmo Thread Starter
atmo's Avatar
nTune.
The CPU sensor reads 43-45c under load at around 20c ambient. I'm certain the sensor is reading lower than the actual die temp, but even if it's 20c off it's still in the safe range.
Old 1st December 2016, 7:55 PM   #88
Datsun 1600
I am just finishing off building an Abit AN7 with the below AGP card.
http://ocau.com/pix/8gba6
My custom window.
i5-750, Gigabyte P55-UD5, 8Gb Patriot 1866, Gainward 670 Phantom
i5-650, P55A-UD3R, 8Gb Patriot 1600, Powercolor 6950
G6950, ECS H55H-I, 8Gb G-Skill Sniper 1600
Datsun 1600 is online now   Reply With Quote
Old 1st December 2016, 7:58 PM   #89
shane41
Haha you need that much Horse Power to take Atmo down
I'll have a crack at the big score one night......southerly c'mon
33 ambient
Old 3rd December 2016, 7:15 PM   #90
atmo Thread Starter
atmo's Avatar
An MSI P965 Platinum arrived yesterday.
I was able to get pretty much the same 3.8ghz overclock on my E6600, but the 3dmark01 score was around 800 points lower than the Striker with a single 8800GTX.
My theory that the intel chipset might outperform the nvidia with a single GPU is looking a little shaky.
