Old 7th March 2017, 9:58 PM   #511
LukeD_NC
Originally Posted by cbwolf View Post
Perfectly normal to have significant jumps in CPU temperature under Prime95 - it'll jump when it starts using AVX instructions. The 7700k seems to really jump around in temperature second to second under normal usage also.
Interesting ! I did not know that.
In your second screenshot at 5Ghz using Intel XTU, 95 degrees on the package is mighty high at just 1.34v. You might want to try reseating your block and reapplying your TIM. You shouldn't be at 95 degrees at that voltage.
That's what I thought. There's something wrong there. I tried reseating the AIO cooler, no difference.
Also i haven't delidded yet, this is stock TIM. So I'm wondering if that is the problem there ?
LukeD_NC is offline   Reply With Quote
Join OCAU to remove this ad!
Old 8th March 2017, 1:34 AM   #512
LukeD_NC
Ok so i just tested the 6700k vs 7700k.
The 6700k running stock on Noctua NH9Li cooler which is a tiny heatsink
The 7700k running stock on Kelvin S24 240mm AIO.
Small FTT's on Prime 95 with AVX:
6700k - temp max 70c
7700k - temp max 73c
Definitely a TIM problem i would say.
Its not tragic but .... TIM needs to go
Old 8th March 2017, 6:04 PM   #513
nCrypt
nCrypt's Avatar
just installed the Asus Strix Z270G matx
first thing i have noticed vs the Gigabyte Z270M-D3H
I can run my ram at 3200 C14-14-14-34-1T on this board, wasnt able to run 1T on the gigabyte
my idle temps at stock are 33-35, ambient temp of 25. Room im in use to be a sun room, so always bloody warm.
Will do some 5Ghz OC after dinner, see how it goes. To get a pass on XTU on the gigabyte board i needed
1.4V cpu volts, 1.2 IO and 1.25 SA, with ram 1.38V for 3200 14 14 14 34 2T
Currently 7700K at stock, IO 1.1 and SA at 1.15, ram 1.35 for 1T
1.5960X@4.8Ghz 1.35V WC X99 ROG R5 E10 32GB TridentZ 3200C14 GTX1080 Ti SLI WC CaseLabs S8
2.7700K@5Ghz 1.30V WC Z270 ROG APEX 16GB TridentZ 3200C14 GTX1080 STRIX OC WC Phanteks Luxe Tempered
3.7600K@5Ghz 1.31V H115i Z270 ROG STRIX 16GB TridentZ 3200C14 HD630 Caselabs S8
nCrypt is online now   Reply With Quote
Old 8th March 2017, 7:22 PM   #514
headin2001 Thread Starter
headin2001's Avatar
Good work man. I think you will find a good difference. Those voltages for that ram speed sound spot on.
headin2001 is online now   Reply With Quote
Old 8th March 2017, 8:10 PM   #515
nCrypt
nCrypt's Avatar
quick update. 4x8GB ddr4 tridentz 3200, 7700K @5ghz, Asus STRIX Z270G MATX
Set everything to stock.
Ram running 2133 (Auto)
Timinings running (auto)
VCCIO (auto)
VCCSA (Auto)
set LLC to level 5 (max is 7)
Set cpu ratio to 50x, and tried the following VCORE
1.25V - No boot.
1.275V - Freeze logging into windows
1.3v - BSOD running XTU
1.325V - BSOD Running XTU
1.35V - BSOD Running XTU
1.375 - XTU Passed - Score 1388
So next thing i tried, set the ram to 3200 Mhz, and left VCCIO and SA on Auto.
1.375V - BSOD During XTU
1.39 - BSOD During XTU
1.4 - BSOD During XTU
So tried uping the the IO and VCCIO
CPU 1.375 / IO 1.1 / SA 1.15 / DRAM 1.35 / LLC 5 - BSOD XTU
CPU 1.380 / IO 1.1 / SA 1.15 / DRAM 1.35 / LLC 5 - BSOD XTU
CPU 1.390 / IO 1.1 / SA 1.15 / DRAM 1.35 / LLC 5 - XTU CRASH
This is all with 4 sticks installed, so going to try same with only 2 sticks, see if that makes a difference.
MAX Temps i was getting @ 1.375V was 88-90.
1.39/1.4 temps hit 95-100
Thinking a delid would help greatly. Starting to feel like my chip is a dud!
Old 8th March 2017, 8:20 PM   #516
shane41
Don't give up man. It will be setting in there.
I always find the Load Line Calibration is pushed up too far.
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 8th March 2017, 8:32 PM   #517
nCrypt
nCrypt's Avatar
i will get there, between the 2 boards i have noticed to pass XTU @ 5Ghz, needed 1.375V on the strix, and 1.40V on the gigabyte.
Deliding the cpu this weekend, hopefully that helps!
Old 8th March 2017, 8:40 PM   #518
Supersize
Supersize's Avatar
I've just started to push mine today.
Nowhere near the 5Ghz, I start off slow.
It's doing 4.7Ghz@1.181v, temps hit 69c with a Kraken x61 running Realbench/XTU, so I thinks she may need a delid oneday.
I'm able to turn on the XMP for my ran and it's still stable.
There's some serious latency when you use HWiNFO64 and allow it to monitor the ASUS EC though..
nCrypt, try setting your IA DC and IA AC load line to 0.02
Supersize is online now   Reply With Quote
Old 8th March 2017, 8:51 PM   #519
nCrypt
nCrypt's Avatar
hmm, never heard of those settings, haha
Old 8th March 2017, 9:02 PM   #520
Supersize
Supersize's Avatar
Under here if the Strix has it..
Old 8th March 2017, 9:10 PM   #521
nCrypt
nCrypt's Avatar
ye found them,.
so had cpu at 5.0ghz, vcore 1.375, ram @ 3200 io 1.1 sa 1.15
and those two setting you said, and it would freeze on the ROG logo.
ill have a play around with them some more when i have a bit more time. !
Old 8th March 2017, 9:17 PM   #522
Supersize
Supersize's Avatar
ye found them,.
It was Raja from Asus who was talking about playing with those settings the higher the overclock you go.
Either 0.02 or 0.01, it just increases the DC and AC load line a little, sometimes that helps to stabilize the OC.
Allowed me to lower my vcore and still stay stable.
Old 8th March 2017, 9:25 PM   #523
headin2001's Avatar
Guide is in the OP for Asus. Makes no difference to me.
Old 8th March 2017, 9:38 PM   #524
Supersize
Supersize's Avatar
Worth a shot, some were having more luck, one of the veterans over there also said it helped him.
Delidding seems to be the way to go with these chips, temps a crazy low after.
I'm just making sure the cpu is fine then will do it myself, it'll be my first.
Old 8th March 2017, 9:47 PM   #525
cbwolf
cbwolf's Avatar
VCCIO (auto)
VCCSA (Auto)
1.25V - No boot.
My experience with Asus boards is that they can be really sensitive to running XMP ram profiles and definitely require VCCSA and VCCIO voltage bumps. A 1.1v IO and 1.15v SA is going to be too low to run your ram at 3200.
Jump to 1.2 IO and 1.25 SA and see if that gives you stability. If it does, work the voltages down slowly from there until you hit instability again and then bump it up a notch.
Oh, also update your BIOS if it's not latest version. I found XMP to be much more stable and require less voltage on my Strix z270E board after a bios update
i7 7700k @ 5.2 | Asus ROG Z270E Strix | MSI GTX1080 Ti Seahawk @ 2076/12000 | 32GB Trident Z 3200Mhz DDR4 | 256GB + 1TB Samsung 960 m.2 SSD | Philips 43" 4k IPS Monitor
Over $6,000 in forum trades and counting!
cbwolf is online now   Reply With Quote
