Old 5th March 2017, 1:22 AM   #136
shane41
shane41's Avatar
Not unhappy with this .........very rough. Not submitted, figure I'll do better
Still to do. Make a lean OS. Flash another bios. Work on timings
Nothing to see here So I'm told often
Old 5th March 2017, 6:37 AM   #137
shane41
shane41's Avatar
I've been messing with 3D2001se a fair bit on the 775's .......learning as best I can. Done a 72K in sli with q6600 x2 cores @ 3800mhz iirc
But it's never enough is it
So bought a e8600, 100K is it doable? x2 8800 Ultra's on a 790i Ultra Sli.
I like this sub. Ignore processor........his gpu's are not run hard here
http://hwbot.org/submission/711941_m...ra_99697_marks
Old 5th March 2017, 8:01 AM   #138
macsbeach98
macsbeach98's Avatar
Shane I would be dropping the SLI idea the No.1 sub for 8800Ultra x2 is worth about 12 HWpoints there are not a enough subs on the board to make it worth while.
The No. 1 sub for a single card is worth 39 points so if you score fair you will get a lot more points for the comp with a single card.
macsbeach98 is offline   Reply With Quote
Old 5th March 2017, 8:59 AM   #139
newlife Thread Starter
newlife's Avatar
Been added to the OP
Old 5th March 2017, 9:03 AM   #140
ginger_nuts
ginger_nuts's Avatar
Nice work Zero
The world will keep turning
HWBot Profile = Ginger_Nuts81 Member of Australia OC team.
ginger_nuts is offline   Reply With Quote
Old 5th March 2017, 9:30 AM   #141
jordanhyde99
How would I submit an Aquamark run? :/
| i7-7700k at 5.1GHZ | 980Ti at 1560MHz | ASRock Z170M OC Formula |
jordanhyde99 is offline   Reply With Quote
Old 5th March 2017, 9:40 AM   #142
newlife's Avatar
For am3 you need to save a datafile which includes the screen shot and be sure to include cpu-z cpu tap, cpu-z memory tabs and Gpu-z before saving datafile (check zeropluszero's score if unsure)
Old 5th March 2017, 9:58 AM   #143
jordanhyde99
Ahhh! Thanks! Didn't realise the saving if the score took a screenshot... Now I just need to get my PB again.
HWPoints aren't counting for me either :/ had some subs up since last night.
Old 5th March 2017, 10:03 AM   #144
Sgt Bilko
Sgt Bilko's Avatar
It's been happening for others as well, seems the site isn't updating as they should.
I've had 4 subs sitting there for over 10 hours now and 1 & 1/2 have been updated
AMD Community Manager
Comments are my own unless stated otherwise.
Sgt Bilko is offline   Reply With Quote
Old 5th March 2017, 10:25 AM   #145
jordanhyde99
http://hwbot.org/submission/3477551_
http://hwbot.org/submission/3477490_
http://hwbot.org/submission/3477559_
http://hwbot.org/submission/3477554_
One set of points... Think I will be able to get quite a bit more.
Old 5th March 2017, 10:57 AM   #146
cheddle
cheddle's Avatar
http://hwbot.org/submission/3477585_
one
Happy traders: too many to list...
Boycot: NeVeSiNS
PC: i9-7900x / 2xgtx1080ti - Bike: MT09 Tracer - Car: ST215w Caldina
cheddle is offline   Reply With Quote
Old 5th March 2017, 11:23 AM   #147
newlife's Avatar
Added and those are some nice results
Originally Posted by cheddle View Post
Unfortunately I can't accept that because it requires the background to be present so you'll have to manually add one if using XTU
Old 5th March 2017, 11:58 AM   #148
AG-TAS
AG-TAS's Avatar
http://hwbot.org/submission/3474654_
http://hwbot.org/submission/3474588_
http://hwbot.org/submission/3474578_
Originally Posted by t8y View Post
or when we do get it on short notice, it occasionally still has the cow semen sticks still in the dewar
i7-4770K@4,2GHz - Corsair H110 - XFX HD7990+Sapphire HD7970 - Asus Maximus VI Extreme - 4x4G Corsair Dominator 2133C9 - Enermax 1250W Platinum -Fractal Design DEFINE XL R2
Australia OC HWBOT MemberJoin us and have fun pushing your gear to the limits.
AG-TAS is offline   Reply With Quote
Old 5th March 2017, 1:04 PM   #149
newlife's Avatar
Added and those are some nice sandy scores
Oh and why you using old background because it looks crap vs the new one that took an hour to turn the white in gigabyte logo transparent because I was using gimp and ended up moving to Photoshop which took 2 seconds
Old 5th March 2017, 1:16 PM   #150
Paulie_AU
Paulie_AU's Avatar
Nice work.
Looking back at HW my points I am saddened by the death of my Z77 and subsequent ditching of all 1155 CPU's...... many cold points I can no longer chase.
Mr_McPoo
Paulie_AU is offline   Reply With Quote
