Old 26th February 2017, 2:07 AM   #16
Muzwa Kai
Muzwa Kai's Avatar
lol what a milestone, just commented a couple of days ago about the amd s939 being the last time amd beat intel, when the X2's came out being better than the Pentium d's until the core 2's came out. just seen the ryzen beating intel again, soooo good to see! wow can't believe it to be honest!!! woohoooo!!!
4690k - 4500 1.2v - 4700 1.3v - 4800 1.35v - Tt C5 - tridentX 16gb 2400mhz 10-12-12-31-1T - gigabyte WF3 R9 290 - MSI Z97
Muzwa Kai is offline   Reply With Quote
Join OCAU to remove this ad!
Old 26th February 2017, 8:02 AM   #17
ginger_nuts
ginger_nuts's Avatar
Shane41 your older cards don't need Ln2, just something cold like even icy water would get most the points. Make a chilled water setup for about -30 or DICE (if the card likes it) and you would be good. Knowing you Shane 10 cards would be the first crate of GPU's opened
But big prizes = big comp = big challenge
Join me to show what us little fishes can do
The world will keep turning
HWBot Profile = Ginger_Nuts81 Member of Australia OC team.
ginger_nuts is offline   Reply With Quote
Old 26th February 2017, 9:25 AM   #18
zeropluszero
zeropluszero's Avatar
Guys, check the hardware points you can get with a i5 6600 and the XTU benchmark.
and you can also score great in benchmarks like 3dmark06 with a modern 4 or 6 core cpu and an older graphics card like something from the Nvidia 7xxx series.
TeamAU
The house that Doritos built
Old 26th February 2017, 10:06 AM   #19
shane41
Love your enthusiasm man .........but mine is waning
http://www.dictionary.com/browse/waned
I know the Overclocker Lords in here deserve to win .... as they bust so much shit every year.
Yes you'll get more people in this comp " for the win new Amd factor "
I keep saying it every year....... fill your AU OC ranks with new members to encourage that " non frozen " prizes that they have a good chance of winning. If they are going to redline their $2K system then they must feel it is worth the risk. That's how I thought at the beginning of all this.
Originally Posted by neoprint View Post
There is a group of us that get incredibly erect over such hardware. Maybe post in the retro section?
Haha ...........might be a bit rude that picture.
Old 26th February 2017, 11:17 AM   #20
akromatic
so... non overclockers, non K have no chance?
akromatic is offline   Reply With Quote
Old 26th February 2017, 11:26 AM   #21
shane41
If your chasing hardware points. Then you look on Hwbot for what hardware you have.
ie. Hardware columb / your part / then benchmark / then rankings.
http://hwbot.org/submission/2312885_...ra_33938_marks
example. I won't go frozen. So best I can hope is watercool. But I cannot
make 5.5ghz on my processor........so a score I am aiming/hoping for 15 Harware points.
It's search with what you have got & try for your best points x10 submissions
Old 26th February 2017, 1:07 PM   #22
wraith.50
Im a bit unclear as to how this competition works exactly.
So you are meant to submit 10 scores, but 10 scores in what?
Which benchmarks, because when i look at the other competitions on hwbot they all list a set of benchmarks and the highest score for that benchmark wins.
Can you give an example of an entry in this competition with the 10 scores?
wraith.50 is offline   Reply With Quote
Old 26th February 2017, 1:21 PM   #23
ginger_nuts
So you choose what ever benchmarks and hardware you want ( I suggest picking ones with more Hardware points allocated)
Here is how HW points work:
B) Hardware Points
Hardware points are awarded based on your position in a hardware ranking. The hardware ranking is defined by the hardware item, the benchmark application, and in case the benchmark is multi-threaded, by the active CPU or GPU core count. For example, the SuperPI 1M Core i7 4770K (click) has a single hardware ranking for this specific combination of hardware and benchmark because the benchmark is single threaded. The 3DMark Fire Strike Extreme GeForce GTX 980 Ti (click) features four hardware rankings for this combination of hardware and benchmark because the benchmark is multi-threaded.
At the moment, 43 benchmark applications have Hardware Points enabled. In total, there are 44,446 hardware rankings with Hardware Points. (August 30, 2015)
Hardware Points are awarded based on two parameters: position in the hardware ranking and the weight of the hardware ranking. The position is determined by how well you rank amongst your fellow overclockers using the same benchmark and hardware. The weight of the ranking is determined by the amount of participants in the hardware ranking (all time). For more information on the algorithm, please refer to Section 8) Hardware Points Formula.
The maximum Hardware Points for first place in any hardware ranking is 50 points. The minimum Hardware Points for first place in any hardware ranking is 2 points. Currently 49568 overclockers earn 1,705,121 Hardware Points. (August 30, 2015)
The Hardware Points rankings can be found on the hardware overview page. From the front page you can access any hardware overview page by using the search bar in the top right corner. Type a part of the hardware name and click on the dropdown item. For example, this is the Core i7 4770K overview page. On this page you find a list of all hardware rankings, split up by benchmark (list) and core count (tab) in case the benchmark is multi-threaded.
On any overclocking result page (or “submission”), you can find the awarded Hardware Points under the section Points Earned. In the field next to “Hardware Points (UHP)”, you find the total amount of Hardware Points the overclocking result is worth.
You bench your hardware using the comp background (bench really hard)
You can submit more than 10 scores, but only your top 10 will be counted.
Most comps have limitations on hardware, benchmarks and or cooling, this one doesn't.
Old 26th February 2017, 1:26 PM   #24
shane41
It's up to you entirely. eg I'm useless at XTU so I'll try on 3D marks.
Hardware points matey. This is a search on Hwbot & see what you can do mission.
eg Old Agp cards had very little submissions & the scores were lower.
So little hardware points like 5 if you try that.
Big cpu's 4 cores high ghz & some of the older 9800/8800 nvidia can score well
in certain benchmarks.
It's what you search & can do.
Board + Cpu + Gpu/s + Benchmark. Find x10 that you can do well.
But you look at the rule for each benchmark
Old 26th February 2017, 1:40 PM   #25
dasa2
dasa2's Avatar
wonder if my x1900xtx cf or gtx480 still work could also get a 5770 a go in a 6700k but since it cant do over 4.8ghz on water i probably wont get far enough to be worthwhile vs all those hex core on ln2
6700k@4.7ghz 1.38v - Z170 Gene - 2x8g 3866c16-16 1.425v - GTX 1070 SC
Swiftech Apogee Drive II\EK VGA HF - 200mm Phobya - Silverstone TJ08-EW
dasa2 is offline   Reply With Quote
Old 26th February 2017, 1:56 PM   #26
shane41
Ln2 scores are the bomb.
So what can we do? Research in the Hwbot rankings & find possible points.
Non frozen prize for rest of us to aim for.......that would definitely help to try our best.
Still I'll give it a bash on a cool night. Race against myself if anything & see what some nice parts can do finally.
Old 26th February 2017, 2:04 PM   #27
ginger_nuts
Shane41 A cold night benching with a nice red wine or two. I think you will be a winner, no matter what
Old 26th February 2017, 2:15 PM   #28
shane41
Aww Ginge you are too kind Best I stick to some beers ......
that rocket fuel sends me batty. Then something will get broke
You know I have been looking forward " to re killing " this baked Ultra
Old 26th February 2017, 3:03 PM   #29
Paulie_AU
Paulie_AU's Avatar
Expecting big things from my Gigabyte mouse.
Need a PSU....
Mr_McPoo
Paulie_AU is offline   Reply With Quote
Old 26th February 2017, 3:06 PM   #30
shane41
Haha shameless Gigabyte plug.....you whore
