Go Back   Overclockers Australia Forums > Specific Hardware Topics > Electronics & Electrics
Old 13th November 2007, 8:19 AM   #16
wabbit
wabbit's Avatar
How are you placing your electrodes?
Couple of suggestions here: http://rnceus.com/ekg/ekglead.html
I started out with nothing and I still have most of it.
wabbit is offline   Reply With Quote
Join OCAU to remove this ad!
Old 13th November 2007, 8:32 AM   #17
mhgarage Thread Starter
mhgarage's Avatar
Electrodes are placed correctly - the noise persists regardless of the lead i'm using.
mhgarage is offline   Reply With Quote
Old 13th November 2007, 8:47 AM   #18
wabbit
wabbit's Avatar
If this is the schematic you actually used
http://static.flickr.com/46/136265424_8781c4ef38_o.jpg
there is an error.
Ground should connect to the sleeve of the output jack, not the ring.
Old 13th November 2007, 8:56 AM   #19
moscoe
If you're not having any luck with the hardware you could always implement a band-stop filter in software.
moscoe is offline   Reply With Quote
Old 13th November 2007, 9:49 AM   #20
mhgarage's Avatar
there is an error.
Sorry, what's the output jacket? Do you mean the audio cable outer shielding for the cable between ecg & computer? Hence also, what's the ring? Do you mean the - battery connection?
Old 13th November 2007, 10:25 AM   #21
wabbit
wabbit's Avatar
I meant the 3.5 mm output socket on your ECG. The sound card uses a 3.5 mm stereo input plug also known as a TRS (for Tip, Ring, Sleeve) connector. The body of the plug is called the sleeve and is connected to ground. The tip of the plug is left channel in and the ring in between is right channel in. If you connect it as shown in the schematic, you'll have the ECG ground on the right channel in, which is incorrect.
I can't tell from the photo of the box interior but have you connected the lid of the box to the circuit board ground.
Hosted by UGBox Image Store
Old 13th November 2007, 2:41 PM   #22
mhgarage's Avatar
Thanks for that. Ground _is_ connected to the sleeve, correctly. The ring isn't connected to anything at all.
Any other ideas as to how to reduce the interference? Would a low pass filter help? I'm assuming the frequency of the QRS is lower than 50hz!
Old 13th November 2007, 3:38 PM   #23
wabbit
wabbit's Avatar
Quote from "The Biomedical Engineering Handbook", second edition, chapter 13, "Principles of
Electrocardiography", section 13.2, "Instrumentation":
"The general instrumentation requirements for the ECG have been addressed by professional societies through the years. Briefly, they recommend a system bandwidth between 0.05 and 150 Hz. Of great importance in ECG diagnosis is the low-frequency response of the system, because shifts in some of the low-frequency regions, e.g., the ST segment, have critical diagnosis value. While the heart rate may only have a 1-Hz fundamental frequency, the phase responses of typical analog high-pass filters are such that the system corner frequency must be much smaller than the 3-dB corner frequency where only the amplitude response is considered."
If your intended application is general interest and non-clinical, you could probably get away with low-pass filtering with a cutoff of 15-20 Hz.
The sound card low frequency response would certainly not go anywhere near the recommended minimum.
Old 13th November 2007, 10:00 PM   #24
mhgarage's Avatar
My ECG is definitely for personal use - you'd never get away with trying to hook up a patient to a home made ecg in a chocolate milk tin
Thanks for that information. I'll definitely investigate low pass filters - although they're quite past my current electronics expertise. I assume i would be filtering the audio cable core (i.e. tip)?
EDIT: I've put together a schematic for this:
This is applied to the core of the audio cable connecting the ECG to the computer. The GND is the shielding of the audio cable, connected to case ground.
Is this likely to work?
Old 14th November 2007, 2:25 AM   #25
LethalCorpse
LethalCorpse's Avatar
here's a 50Hz notch filter that should help. It will reject the 50Hz hum, whilst not drastically affecting the shape of the wave for other frequencies.
the 193k can be made with a 150k in series with a 43k. The 9.65k can be made with a 15k in parallel with a 27k.
This one is a 150Hz low pass filter, which will give much better results than your passive filter. It can go right after the notch filter, which can go right after the input amplifier.
component substitutions:
160n = 150n || 10n
240n = 120n || 120n
68n = 68n
43n = 10n || 33n
2k79 = 2k4 --- 390R
18k1 = 13k --- 5k1
2k57 = 3k || 18k
16k5 = 33k || 33k
These two filters can be built with a single 4-opamp IC, like the TL074 or the OPA4134, and a handful of passive components which should be readily available at your local electronics shop.
I'm with odje, your input amplifier really ought to be a quality instrumentation amplifier, like the INA114, or the AD627, both available from RS components for <$20.
Sig Of Shame removed.
LethalCorpse is offline   Reply With Quote
Old 14th November 2007, 3:45 AM   #26
2xCPU
2xCPU's Avatar
Originally Posted by mhgarage View Post
I've earthed all the circuit earths to the main earth. I've even earthed the tin box to my computer's case. The noise persists.
You don't have 'too many' earth's causing a loop do you?
Try disconnecting the earth going to the the sound card and see how it goes.
2.
Absolute truth is a very rare and dangerous commodity in the context of professional journalism. Hunter S. Thompson
The universe is made up of atoms and empty space, the rest is mere opinion. Democritus, 400 BC.
2xCPU is offline   Reply With Quote
Old 14th November 2007, 7:57 AM   #27
mhgarage's Avatar
Originally Posted by LethalCorpse View Post
snip
That's all great information thankyou! It's a actually a more complex circuit to filter the output than to build the ECG in the first place - which seems a little odd.
Unfortunately, i have very little experience working with op amps, so i don't actually know which pins do what - unless that information is answered somewhere else. With the symbol for amplifier (The triangle), what do each of the inputs/outputs mean? Which pins do they correspond to?
(now you see my problem).
I'm trying isolation today - and hopefully that'll solve the problem. If not, filter time.
Old 14th November 2007, 9:13 AM   #28
Odje
Odje's Avatar
The notch filter may need to be trimmed or use high precision components. The notch filter I made for my ECG at uni had its centre freq at 47Hz instead of 50Hz But the quality of the filter was very good, heap of attenuation at the centre frequency and it was very fairly narrow too.
FOR SALE: unRAID Server Pro Registration Key $75
There are only 2 reasons why you should run,
1. If you are being chased or
2. If you are on fire
Odje is offline   Reply With Quote
Old 14th November 2007, 9:15 AM   #29
LethalCorpse
It's pretty easy, once you look at it. The datasheet for the op-amp tells you which pins are which. It'll have a diagram showing the IC with one or several of those same triangle shapes, and the pins they connect to. The IC will also have Vcc and Vss, just positive and negative supply. You connect your circuit's power rails to Vcc and Vss, and connect the op-amps in exactly the same way as they're connected in the circuit, ie + to +, - to - and output (the other end of the triangle) to output. So long as the op-amp IC you pick has enough op-amps on it to do the job (or you get enough of them) and your IC can use the supply voltage that the rest of your circuit is using, it'll just work.
NB: in your circuit, i believe you've got a VDD/2 point? Connect to this in place of the ground symbol on my circuits.
Old 14th November 2007, 10:25 AM   #30
mhgarage's Avatar
There is a VDD/2 point, but it's connected to the normal ground i think. I'll have to check that though.
I tried the ECG on a laptop, and got a much clearer trace. There is still a little bit of interference, but it's greatly reduced. I'll certainly investigate the low pass filter - will it work without the notch filter?
