Go Back   Overclockers Australia Forums > Other Topics > Pets & Animals
Old 25th May 2008, 4:58 PM   #76
yoda123
yoda123's Avatar
Yeah you will be happy with the Jager's I have 2x 200W heaters am over the moon with them, have kept my ~280L system at 26*C even through the coldest days this year
yoda123 is offline   Reply With Quote
Old 25th May 2008, 5:36 PM   #77
Grizz_li
Grizz_li's Avatar
Since you have one too, I need to ask a question.
Theres this button on top that according to the box is called "recalibration button". What does it do?
I've noticed I can pull it outwards a notch and it lets me set the temp. When I push it back in, the temp dial is harder to set as in, it's tighter.
Is this the same with yours or is it fully locked if you push it in?
Grizz_li is offline   Reply With Quote
Old 25th May 2008, 7:37 PM   #78
JaC
JaC's Avatar
Exact same question was asked recently on another forum (possibly even by you?)
When the recallibration button is pulled UP the temp knob spins freely *without* adjusting the temperature setting on the heaters thermostat (this is why it is easier to turn). This is so you can recallibrate the heater.
You want to leave the recallibration knob IN and adjust the heater using an accurate thermometer to tell you what temperature the tank stabilises at... this may be different to the numbers on the heater especially now that you have moved the settings from the default.
Once the tank temp has stabilised pull the recallibration button UP and then turn the heater temp knob to the setting that matches the reading on your thermometer.
Now push the button IN without turning anything.
Your heater is now callibrated to your thermometer.
JaC is offline   Reply With Quote
Old 25th May 2008, 8:54 PM   #79
Grizz_li
Grizz_li's Avatar
Yep thats me
Only 1 response.
Old 26th May 2008, 8:36 PM   #80
Vassili
Vassili's Avatar
Painted the back of my tank today, its looking sharp
Vassili is offline   Reply With Quote
Old 27th May 2008, 9:44 AM   #81
Stang1
Stang1's Avatar
When you get your tank setup with a heater, you're supposed to calibrate it to the thermometer that you're using, setting it up or down etc. I don't own a Jager, but I believe that what you're doing there is adjusting the dial so that you can make it read the same as your thermometer.
Stang1 is offline   Reply With Quote
Old 27th May 2008, 9:50 AM   #82
yoda123
yoda123's Avatar
Yeah you are supposed to calibrate them, however I didn't bother and just set them to the temps I want them to come on at.
I have a digital temp reader and my tank sits at a constant 26*C so im happy
Old 27th May 2008, 10:51 AM   #83
DanWA
DanWA's Avatar
What sort of aquarium would be needed for Oscars?
OCAU Fishing Club Member #28
DanWA is offline   Reply With Quote
Old 27th May 2008, 11:05 AM   #84
Vassili
Vassili's Avatar
I had mine in a 6x2x2.5, and they were very happy fish
Old 27th May 2008, 11:07 AM   #85
japes
japes's Avatar
At least an 18" wide 4' tank, 4x2x2 would be OK for two of them if they get along.
Minimum of 75Gal (280L) tank for a single Oscar, they grow fast, they're messy, and they get big.
Old Biotope Aquaria flickr
Hardware: 6700K, Z170 Sabretooth Mark 1, EVGA GTX 1080 FTW, Xonar ST-X, Fractal Define XL R2, AX1200i, 256GB Samsung M.2 Pro & 240GB Neutron XT.
Peripherals: Zowie EC1 EVO CL, Das Professional w/ Blues, Zowie GS-R Black, ATH-ADG1, 2x MG279Q 2K 144hz IPS on Arctic Z2
japes is offline   Reply With Quote
Old 27th May 2008, 11:11 AM   #86
Vassili
Vassili's Avatar
Gah I wouldnt put a fish that can grow 30cm+ in a 18" wide tank, but thats just me
Old 27th May 2008, 11:26 AM   #87
DanWA
DanWA's Avatar
So biggger the better? Also what sort of pump/filtering/heating setup is recommended.
Old 27th May 2008, 11:28 AM   #88
Vassili
Vassili's Avatar
If your buying a new tank id strongly recommend getting a sump setup off the bat, its good value for money, offers great filtration, and is quite easy to set up. If not, you can just get an external canister or two. I had two 2400LPH canisters on my 6', and they coped just fine
Old 27th May 2008, 11:35 AM   #89
japes
japes's Avatar
Please note the words least/minimum, I wouldn't put an Oscar into anything smaller than a 5x2x2 personally, but look at all the people who have them in 2 and 3 foot tanks that are 15" wide
In other news, my displays pH is up around the 7.4-7.5 mark, from 7.1-7.2 which was already higher than I would have liked it. Trying to find out the reason, so far I've removed the scrubbies from my sump and changed out 25% of the water and this appears to have made a slight difference as my readings last night were more around 7.6-7.8, but these test kits can be hard to decipher depending on the lighting and how you look at it (API Freshwater Master Test Kit - Liquid).
Old 27th May 2008, 12:08 PM   #90
Falkor
Falkor's Avatar
Oscars care more for lengthy tanks than wider. 18" Wide is fine although I probably would still go for a 2'. But so long as its long so 4' or 5' then 18" wide is ok. Saying that though.. Like you guys I dunno if I would be comfortable doing it still. heh
I would love to own an Oscar but I don't like the fact that you only have 1 fish in a huge tank
Save the whales, Collect the whole set! .:|:. Now faith is being sure of what we hope for and certain of what we do not see - Hebrews 11:1
Falkor is offline   Reply With Quote
Tags
aquarium, cichlids, filtration, fish, fishtanks
