Old 17th January 2009, 4:19 AM   #61
Lardman Thread Starter
Lardman's Avatar
Originally Posted by flinchy View Post
dowant dowant dowant dowant dowant dowant dowant dowant dowant dowant dowant dowant dowant
it may be heavy, but whats it matter when i run my pc laying flat
mannnnnn doooo wannnttttt
The new Thermalright HT is out, will be testing sometime...
Expect an update to the OP as well, folks. Just gotta looks for some more reviews to update it in full... >_>
Blogrant! | Steam: reijin.au | PC: i5-4670 / 780Ti / Q-08B
Lardman is offline   Reply With Quote
Join OCAU to remove this ad!
Old 5th March 2009, 9:04 AM   #62
RevIt
RevIt's Avatar
Originally Posted by Lardman View Post
If the 2 dial cousin is any indication, they run fairly well.
In other news...
Ultra 120 Extreme cu limited edition coming soon [Expreview]
Will be interesting to see how this compares to the Black edition.
Well, another post that seems to have copied what i posted and my original post has vanished.. fuck the mods are busy here...
Thermaltake Armor+|Q9450 @ 3.5Ghz|Thermalright 120 Extreme|Formula Rampage X48|4Gb Geil 1066 DDR2|EVGA GTX280SC|2x320 WD RE2 HDD in 0 Raid|750Gb Seagate 7200.11|Corsair HX620|G5|G15|G25
RevIt is offline   Reply With Quote
Old 5th March 2009, 11:58 AM   #63
Lardman's Avatar
They are very quick ;p
Old 22nd March 2009, 8:58 AM   #64
Little Man
Little Man's Avatar
hey, if i have lets say a scythe 3000 rpm fan and i plug the 3 pin connector into a fan controller, am i going to loose substantial rpm speed?
can someone recommend a fan controller that will tell me have an lcd (temp monitoring is not important becase they are usually way off) but will tell me accurate rpm?
i think im going to go the U12P
but a few questions
Why does the Ultra 120 Extreme come with a lumpy base?
Do you have to lapp it?
Does the 120 beat the U12P after its been laped?
The difference between the 2 is only a few C right?
im leaning towards the u12p, the fan on there has very nice airflow, im looking at buying another but do i need to buy clips to add another fan?
Can u add another fan?
Little Man is offline   Reply With Quote
Old 27th March 2009, 12:27 AM   #65
chris87
Just purcahsed the U12P SE1366, It seems like it will only just fit in my Antec 300. Will take some picies on the weekend.
chris87 is offline   Reply With Quote
Old 6th April 2009, 12:35 PM   #66
-Cypher-
(Banned or Deleted)
Here's something new, the Prolimatech Megahalems-
http://www.pccasegear.com/index.php?...ducts_id=11125
Very similar to the TRUE although it comes with a much flatter base, a better mounting system, a 1366 backplate and is cheaper than the TRUE.
One of these with a pair of Scythe Ultra Kaze's would be very nice indeed.
-Cypher- is offline   Reply With Quote
Old 6th April 2009, 1:24 PM   #67
flinchy
looks almost exactly like it actually
and it's MORE EXPENSIVE than the true. the TRUE can be had for <$80
Originally Posted by Reaper View Post
Originally Posted by Taceo Corpus View Post
BRB - building a Faraday Cage.
Thinly veiled "I'm wrapping myself in chicken wire".
flinchy is offline   Reply With Quote
Old 6th April 2009, 2:33 PM   #68
-Cypher-
(Banned or Deleted)
The cheapest TRUE Black I could find on staticICE was $95, the Ultra 120 can be had for a fair bit less but if you want push-pull you have to buy the extra clips separately (or use some bush-mechanics).
The Prolimatech is much better value for i7 owners because it comes packaged with a 1366 mounting bracket, it's $19 for a Thermalright bracket
Old 7th April 2009, 7:14 PM   #69
Lardman's Avatar
It's been proven to perform a few degrees better than the TRUE - as well as that, it's much better for lower speed fans because of the heatpipe layout. Much less noise, much better for quiet computing.
Old 7th April 2009, 7:17 PM   #70
flinchy
why TRUE black? it performs exactly the same as the TRUE120.
that link shows the TRUE120 is still slightly slightly in front. link to the tests where it is better?
Old 7th April 2009, 7:24 PM   #71
Lardman's Avatar
Silent PC Review link for Prolimatech Megahalems
It shows that the Megahalem does better at lower fan speeds in terms of overall temperature rise.
Originally Posted by SPCR
The Prolimatech Megahalems's performance was top-notch across the board. It posted similar results to the Thermalright HR-01 Plus and Noctua NH-U12P with low airflow, and bested the entire field, even the Thermalright Ultra-120 eXtreme, when our Nexus fan was set to 12V.
Old 21st April 2009, 9:09 PM   #72
Bleemv1
Bleemv1's Avatar
Hey guys,
Can anyone tell me what the deal is with frostytech.com's heatsink reviews?
The temperature testing reveals that the TRUE is in 6th place when most other reviewers rate it as their number one. I noticed their testing method involves mounting the heatsinks to some sort of hot plate rather than testing it with a real PC system. I guess this keeps things consistent and directly comparable but then real world results don't seem to match up.
Which website should I "trust" more?
My Flickr Page
Bleemv1 is offline   Reply With Quote
Old 26th April 2009, 8:07 PM   #73
carbon_death
carbon_death's Avatar
My friend bought a TRUE copper and it came with a 1366 mounting kit.
New build in the making
carbon_death is offline   Reply With Quote
Old 4th May 2009, 6:54 PM   #74
lionman
lionman's Avatar
Prolimatech Megahalems is meant to be pretty good. Anyone used this cooler??
My PC: i7 4770 - H87M - 16GB G.Skill Ripjaws - HD7970 - 120GB 840 PRO - 500GB 850 EVO - 9TB HDDS - HX-650W - Fractal Define Mini - U2410 - K65 RGB - G502 RGB
HTPC: 6400K - 88X - 4GB 1600MHz - HVR-2200 - 120GB 840 EVO - 5TB HDDS - 550W TruePower - SG06 - 50" LED
Fujifilm X100 + X-E1 + X-T1 - 12mm F2.0 - 18-55mm F2.8-4 - 35mm F1.4 - 56mm F1.2 - 90mm F2.5
lionman is offline   Reply With Quote
Old 4th May 2009, 8:53 PM   #75
jamiefhr
I've got one. It keeps my e5200 OC 3.3ghz 15 degrees cooler than stock
jamiefhr is offline   Reply With Quote
Tags
air, cooling
