Old 15th April 2010, 6:57 PM   #121
dimofoes
this sticky is awesome...however
Q
Anyone know of a case that can fit at least 2x 200mm fans in it?
I wanna push a lot of air as QUIETLY as possible
i hate noise..problem is my tower moves around too frequently to set up WC or any other cooling....so I'm forced to stick with fans
dimofoes is offline   Reply With Quote
Join OCAU to remove this ad!
Old 15th April 2010, 11:28 PM   #122
Lardman Thread Starter
Lardman's Avatar
Q
Your best bet is to go with 120mm fans but get an adapter to run them at 7v. Have a look at the Noctua range of fans. Typically with air, volume isn't what you're after, but the ability to keep an adequate airflow throughout your case constantly moving, refreshing the coolers with colder air.
Blogrant! | Steam: reijin.au | PC: i5-4670 / 780Ti / Q-08B
Lardman is offline   Reply With Quote
Old 15th April 2010, 11:39 PM   #123
frostee
frostee's Avatar
About that Excalibur I went for it. Should be next wednesday
frostee is offline   Reply With Quote
Old 16th April 2010, 8:52 AM   #124
devilishly
No worries CM Haf932 has three 230mm fans preinstalled (or Haf9322 which has 2), not silent due to the extensive use of mesh but pretty quiet to me at least and great airflow.
devilishly is offline   Reply With Quote
Old 16th April 2010, 6:20 PM   #125
Bold Eagle
Bold Eagle's Avatar
Nice looking case there .
Another consideration is the Lancool Dragonlord PC-K60 but it only has:
1, 120mm exhaust fan @ 1500 rpm
1, 140mm front intake fan @ 1000 rpm
2, 140mm top exhaust fans @ 1000 rpm each
Lots of rubber gromits though for vibration dampening.
PC3: Cardboard Box, peanut dispenser, highly conc caffine intravenous drip, little monkey w "electro El Shocko rectal probe", 3DMarkVantage=276818768
Bold Eagle is online now   Reply With Quote
Old 17th April 2010, 8:50 AM   #126
Dux
Dux's Avatar
I'm looking for a few black/white 120mm fans for my Noctua CPU cooler.
I like the design of the Arctic Cooling fans, but was wondering if their rubber cage design didn't allow them to be clipped to a CPU cooler. I'd also like to know how they perform and what other people think of them.
http://www.arctic-cooling.com/catalo..._48_68&mID=254
http://www.arctic-cooling.com/catalo..._48_68&mID=342
Dux is offline   Reply With Quote
Old 9th June 2010, 6:11 PM   #127
stocky
I just bought a ZeroTherm Core92 heatsink and fan for my cpu. Noticed there was nothing about them on the forums so I'll post a mini review. You can pick them up for $29 at the moment which is quite a good price. After reading a few reviews, they pulled some good numbers for a budget system.
http://www.pccasegear.com/index.php?...ducts_id=13517
After installing mine, I instantly noticed a 20-25 degree drop in temperatures under load. I was getting around 65+ degrees with the stock 775 cooler on my E8400, but after installing this, its dropped to around 45, maxing out around 50 degrees when running Prime95. Doesnt help that my computer is next to a ducted heating vent, but I'm sure lower temps are possible for those with towers in cooler locations.
stocky is offline   Reply With Quote
Old 7th July 2010, 6:26 AM   #128
T0fu
i bought 2 aywun v8's for my 1156 and my htpc, for 38 bux you cant go wrong . is massive and quiet (:
i5 i750 | 2 x 2gb DDR3 1600 | 1tb WD Caviar Black | HD3850 256 | Antec Fusion MAX | P55UD3 vanilla | 500w Zalman RS | Filco Zero Tenkeyless | Realforce 103 ALL55G
T0fu is offline   Reply With Quote
Old 13th July 2010, 9:18 PM   #129
WotFun
Default Big air build
My new build is performing well;- THe CM Sniper case has 3x200mm fans with built in controller. I have them on minimum rpm and it's very quiet.
I'm also using Noiseblocker fans - 140mm bottom intake & 120mm on the Prolimatech mega shadow & these are also very quiet.
i7 CPU @ 3.8Ghz is idling @ 32c. Running Prime95 its 60c (ambient temps are around 20c).
I couldn't be happier
i7 930 ~ ASUS P6X58D-E ~ Mega Shadow ~ Noiseblocker ~ 6Gb G.Skill PI CL7T 1.5v ~ HD5850 ~
FalconII SSD ~ 1Tb WD Blue ~ 1Tb Samsung F3
CM Storm Sniper Black ~ Antec TP-750
WotFun is offline   Reply With Quote
Old 26th July 2010, 5:39 AM   #130
shanetsh
just got a venomous X
installed it in my not so very well ventilated old rig
with 2 low 50 cfm AC fans...
and guess wat? 3.4ghz i7 920 idled at 30c!! 58 full load
just imagine what it can do when i get my SanAce fans and strap them into my newer rig =)
WTS - come get some GTX690 sexiness.
http://forums.overclockers.com.au/sh....php?t=1202667
shanetsh is offline   Reply With Quote
Old 11th August 2010, 2:39 AM   #131
Indiana08
Indiana08's Avatar
I've recently purchased a Zalman CNPS10X Extreme which has its own remote, is there anyway I can connect this to a normal fan controller (I'm using a NZXT Sentry 2) instead? I will use a preset setting if it is too much of a hassle, but am just wondering if/how I can approach this?
I'm fairly new to aftermarket cooling, so any advice would be appreciated.
Indiana08 is offline   Reply With Quote
Old 28th August 2010, 10:12 AM   #132
DUO
DUO's Avatar
Silverstone Fortress FT02 is my new fav case.
doesnt have 200mm fans, but has 3x180mm fans in the bottom (interesting desgin)
review here:
http://www.hardwarecanucks.com/forum...se-review.html
LIFE ..........
Is all about Ass; you're either:
Covering it, Laughing it off, Kicking it, Kissing it, Busting it,
or trying to get a Piece of it.
DUO is offline   Reply With Quote
Old 17th November 2010, 7:51 PM   #133
tonner78
tonner78's Avatar
Hey guys, thinking that my Phenom 9850 is running too hot and causing my PC resets under load (see here). What aftermarket air cooler would you guys recommend to a guy with a budget? Not wanting to spend big $$ so after the bang for buck option
Thanks!
tonner78 is offline   Reply With Quote
Old 22nd November 2010, 3:21 PM   #134
HeXa
HeXa's Avatar
lol @ Xigmatek.... they are taking the piss with their new cooler name
Thors Hammer S126384
http://www.pccasegear.com/index.php?...ducts_id=16119
HeXa is offline   Reply With Quote
Old 22nd November 2010, 4:59 PM   #135
PAiZley
PAiZley's Avatar
Get the TT FRIO, its got great cooling for $70. just make sure it fits in your case. my TT V9 case is probly under size, as i have to kinda push on my side panel to get it back on.
great temps. i7 920 @ 4ghz 1.35vcore getting 68 degrees load and 30 degrees idle.
PAiZley is offline   Reply With Quote
Tags
air, cooling
