Old 2nd October 2010, 10:38 PM   #31
Don.0.1
Don.0.1's Avatar
Originally Posted by brayway View Post
Pix?
And those are good temps!
Well here are the pictures
The quality is bad becasue they were taken on my phone
Don.0.1 is offline   Reply With Quote
Join OCAU to remove this ad!
Old 2nd October 2010, 11:56 PM   #32
Wingo
Awaiting Email Confirmation
pix
pix
pix
That is probably one of the better looking water cooling loops I've seen in a while. Nice, clean and uncluttered with nice colours. All you need to do is track down some blue sata cables and get rid of those yellow ones.
Wingo is offline   Reply With Quote
Old 3rd October 2010, 2:23 PM   #33
Don.0.1
Don.0.1's Avatar
Thanks Wingo
I will have to look for blue sata cables I didn't think about it untill you menitoned it.
Old 3rd October 2010, 3:23 PM   #34
Wingo
Thanks Wingo
I know Frozen CPU sell them, but can't think of anyone locally off the top of my head.
Old 3rd October 2010, 4:53 PM   #35
BigDave
BigDave's Avatar
Talking
Blue
http://www.pccasegear.com/index.php?...ducts_id=13461
Blue
http://www.pccasegear.com/index.php?...ducts_id=14018
Black
http://www.pccasegear.com/index.php?...ducts_id=13462
Main: - CM690 II,ASUS P8Z68-V PRO,2500K@4.5,16g-G.Skill1600,SLI EVGA580's,1x120g SSD,1x500g VR,3x2Tb,LG 27",G19: Under Water
Server:- TJO8-E, ASRock Z77 Pro-4M, i7 2700K@4.5,8g-G.Skill 1600, GTX260, 8x3Tb,Under Water
BigDave is offline   Reply With Quote
Old 3rd October 2010, 5:26 PM   #36
Wootwagon
Wootwagon's Avatar
just did the final touches to my back plate and mid plate, off to powder coaters next week hopefully, will post up my new work log when i get it back =]
CPU:Phenom II 965BE @ 3.9ghz 1.45v GPU:6850HD xfire @ 850/1100 MOBO:GA-890FXA-UD5 RAM:G.Skill Ripjaw 4gb CL71600 kit CASE:TJ07 custom PSU:Toughpower 750w CM COOLING:Custom watercooling setup
Wootwagon is offline   Reply With Quote
Old 3rd October 2010, 5:29 PM   #37
Boneman
Boneman's Avatar
Took out a 120mm fan I had sitting on top of the blowhole, as the CPU cooler took up too much space.
I kept dropping things into it and it flicked them all over the place.
Boneman is offline   Reply With Quote
Old 3rd October 2010, 6:54 PM   #38
XST
managed to blow $20 worth of ultrabright red LED's that were meant for a window etching. During a test run, accidentally hooked the + and - to the wrong sides...
Successful Trades: mr_mordred2095 (x7), CD, Duck_Boy, comtechman911, Lem0n, Megido Flame, Volnhar, xb99, DraYTox, IceWind, MiniDisc, Leggit, Smokin Whale, dembones, JonBanez, chk, daehenoc (x2), MomijiTMO, Myst, akaminki, billet, mr_wrxman, _slappy_dn_, maarty, Raverz, Ash_Williams, Kevlarman, Euphoreia (x3), Matster, slingshotpk, WuzzA21, BigTosser, staffy007
XST is offline   Reply With Quote
Old 3rd October 2010, 7:32 PM   #39
CM96
CM96's Avatar
Swapped the HDD's between my desktop and laptop. Did the world's dodgiest HDD mounting ever (I just taped the drive to the bottom of the case ).
Also reinstalled Windows on it and fiddled with a couple of cables.
CM96 is offline   Reply With Quote
Old 4th October 2010, 12:38 AM   #40
millsy_c
millsy_c's Avatar
Do explain, afaik hooking up LED's back to front causes no damage as no current will flow, how'd they die?
Originally Posted by Luke212 View Post
You are talking like an expert beginner. Talk less and listen more.
millsy_c is online now   Reply With Quote
Old 4th October 2010, 12:55 AM   #41
XST
not 100% sure where or at what stage, but when i plugged it in, i think I bypassed the resistors. Aka 12v to 3.something volt LED's. Not a happy chappy
Old 4th October 2010, 12:10 PM   #42
Enjoi
Enjoi's Avatar
did some work on my case, lots of measuring and cutting and drilling was done.
took about 6 hours to do, mostly taken up by discussion of best placement.
pics in my worklog.
CURRENT WORKLOG
GREAT TRADERS: Kurosaki, gokurulz10000, pieceofchance, trippinonprozac, sizza, crocodaVe
---- BF3 Profile: Enjoi_AU
Enjoi is offline   Reply With Quote
Old 4th October 2010, 12:13 PM   #43
brayway Thread Starter
brayway's Avatar
pics in my worklog.
I see no pix in ur worklog
i7 950 - 3x GTX470 - 12GB Corsair Dominator - Corsair 800D | 2013 Macbook Air 13" |
'96 FTO GPX | '94 FTO GS | '92 Legacy GX | '89 Legacy RS |
brayway is offline   Reply With Quote
Old 4th October 2010, 12:20 PM   #44
chillies
chillies's Avatar
cleaned out about 2kg of dust
i7 2600k || Gigabyte z68 UD4 B3|| 16GeeBees of Corsair Vengeance 1600c8 @8-8-8-24 -1600MHz||sli 2 x evga GTX 560 SC EE ||
chillies is offline   Reply With Quote
Old 4th October 2010, 3:50 PM   #45
Wingo
If you can force enough voltage across the LED in the wrong direction it can damage the silicon inside. I'm not sure if 12v over a 3v LED is enough or not though.
