Old 23rd April 2014, 10:17 AM   #46
oculi
oculi's Avatar
Originally Posted by Bastard Child View Post
I should probably note that you can't "save as" in Edge 2D, so always keep a backup copy of your template file safe.
can you elaborate on this a bit? i'm using draftsight for my 2D at the moment but it's a bit janky, it's almost like autocad (which is horrible) but slower, considering giving solidedge2D a go.
Reality or nothing
oculi is offline   Reply With Quote
Old 23rd April 2014, 4:36 PM   #47
Bastard Child Thread Starter
Bastard Child's Avatar
From the hazy depth of my memory (I use solidworks for my stuff, not 'edge)...
When you FILE > SAVE your work in Windows it just overwrites your existing file.
What if you want to make a copy with a new name? You would go FILE > SAVE AS > NEWNAME.EXT
But from what I recall, this is disabled in the free version of 'Edge so you have to manually make duplicates of your work in Windows Explorer.
If you accidentally overwrite your original template file it's gone for good.
I'm the reason we can't have nice things
Bastard Child is offline   Reply With Quote
Old 27th February 2016, 8:56 PM   #48
AntikytheraBB
how much does it cost to get something laser / water cut like bastard child did for his harley bracket a few posts back?
I have a very basic HDD cage design I made in SketchUp. i plan to make it out of 0.95mm sheet steel. it would be much nicer if i didnt have to hand cut it.
AntikytheraBB is offline   Reply With Quote
Old 27th February 2016, 9:23 PM   #49
You'll find every place has a minimum charge, newtouch laser in Melbourne charges us $80. This seems about the typical amount.
We typically get $300-$400 worth of stuff at a time. I'll post a pic in a few days when the next delivery comes.
Also be aware if you get a few things cut of different thickness/material you'll probably get charged a change of sheet fee. Newtouch are about $20-$30 for this.
Old 19th March 2016, 5:47 PM   #50
This might be about $700 - $1k:
https://imgur.com/Q1X3m0s.jpg
Old 19th March 2016, 7:55 PM   #51
arcanic_soul
arcanic_soul's Avatar
Out of curiosity Bastard Child, do you have a Press Brake at your work or do you get your jobs bent at New Touch with their Trumpf?
arcanic_soul is offline   Reply With Quote
Old 19th March 2016, 8:18 PM   #52
We have a magnabend™ and some stuff gets bashed with a nylon or ball peen hammer.
Old 8th April 2016, 8:32 AM   #53
Several hundred dollars more in stainless brackets just arrived:
http://imgur.com/a/BcXlg
