Old 10th December 2016, 10:43 AM   #1201
Eisenhorn
Eisenhorn's Avatar
My Ghetto R9 280x, actually runs great like this. the fans wernt powering on so i added my own.
Eisenhorn is offline   Reply With Quote
Join OCAU to remove this ad!
Old 10th December 2016, 11:11 AM   #1202
shredder
shredder's Avatar
I've done the same to an old 7950. Those crappy Windforce fans and their lack of durability.
shredder is offline   Reply With Quote
Old 21st December 2016, 5:06 PM   #1203
/invariance\
/invariance\'s Avatar
You had me with the different fans, but the power cable, ooooh baby!
F@H Stats BOINC Stats
Folding: Phenom II 1100T, ASUS M5A99X EVO, 8G Patriot PG38G1600EL, Sapphire R9 270, MSI HD7870 Twin Frozr3.
The only BS I want to hear is from a Model M: IBM Model M, P/N 1391401, DOB 04FEB87.
Smooth vintage MX blacks on a Wyse 85 courtesy of Soarer's Wyse Converter.
/invariance\ is offline   Reply With Quote
Old 21st December 2016, 5:32 PM   #1204
Hive
Hive's Avatar
You've done a bit of a dodgy job, the wiring harness is not permanently and irrevocably duct taped together. This can create a mess.
Originally Posted by Luke212 View Post
stop spamming you dont know what youre talking about.
Meanwhile
both of which is why for any purpose you can throw at it, a single core always demolishes any multi core.
Hive is offline   Reply With Quote
Old 21st December 2016, 6:03 PM   #1205
MUTMAN
MUTMAN's Avatar
Duct tape enhances flexibility of stiff cables
MUTMAN is offline   Reply With Quote
Old 24th January 2017, 5:04 AM   #1206
Ratzz
Ratzz's Avatar
Not as ghetto as most of my shit, but a handy little mod I think...
Because I use drives removed from USB enclosures, my drives appear to lack something which a normal locking SATA cable is supposed to lock to, because they don't lock....
This can be an issue when you are stuffing a bunch of cables into the back of a computer.. fire it all up and fuck a drive is missing.. open the back and stick the SATA cable back where it belongs.
Of course this is less of a problem if cable management is good and you are no longer 'stuffing' cables in, but still not satisfactory.
So, killing two birds with one stone, heres my solution. Lock the cables in, and improve cable management at the same time.
I've picked up a couple of these Startech adapters. I got them from PLE, preordered for 8 bucks each, but they are no longer listing them so I've just linked to the Startech page.
When buying this type of adapter, take note that there are two sizes.. a mini and a full size. The mini is much more common and available, its for slim/slot loading ODD's. The full size adapter like this one is harder to find. Don't buy the wrong one!
Heres the Startech photo.. copied by me and uploaded to my own storage to avoid hotlinking.
Its a shame the mobo end of the SATA cables don't have locks.. why they wouldn't do so is beyond me but its far less of an issue for me than it is in the back anyway so still a big improvement.
I wanted to turn the pair of Molex connectors into a single Molex and make them a little more tidy. Its the back of the PC, I really wasn't concerned about sleeving and shit , just wanted it a bit tidy. Its only running a couple of drives so splitting one into two is no issue. Of course I also wanted to thoroughly lock down the connectors so they wouldn't shift again too. I used Molex because these are the only SATA devices in my case.. the pump is molex, the fans are PWM/Molex, and the OS drive is M.2, so I basically only use a single multi Molex cable from my PSU for peripherals. Keeps cable clutter down
I took a Molex extension lead I had lying around which was already braided, cut it, and soldered and heatshrinked the two startech Molex connectors to it, turning two short thick ugly connectors into one longer, neater one.
I've just folded up the SATA cables as they don't need the length in my case, but of course they could be a lot longer (450mm) if I needed them to.
I've then inserted the adapters into the drives, stuck a couple of bits of Primochill tube inbetween the adapters to keep them from bending, and used a couple of zip ties to lock both adapters very solidly to the drives, using the space between SATA and power on the adapter as a perfect place to run the zip tie.
The drive cage came from a Phanteks Evolv as far as I can recall, I'll be attaching it to the back of the mobo tray of my Fractal Nano S with Tarzans Grip double sided tape, which if you have never tried I highly recommend. It will remove easily when required, and absolutely never unless required.
Of course this means changing a drive is dead easy.. peel the cage from the case, cut the zip tie, change the drive, new zip tie and just stick it back where it came from..
I'll add some pix of the installed drives later
I always say 'morning' rather than 'good morning'. If it was a 'good' morning then I would be on a yacht in the West Indies smoking a 10" reefer and getting a massage from Lexa Doig...
My Rig
Ratzz is offline   Reply With Quote
Old 17th February 2017, 5:49 PM   #1207
Axe
Axe's Avatar
I never metaphor i didn't like
Axe is offline   Reply With Quote
Old 17th February 2017, 5:52 PM   #1208
Hive
Hive's Avatar
Originally Posted by Axe View Post
Now there's a mod
Meanwhile
Old 17th February 2017, 5:59 PM   #1209
MUTMAN
MUTMAN's Avatar
a drill bit and proper fence wire pliers ... bit flash if you ask me
Old 17th February 2017, 6:04 PM   #1210
Axe
Axe's Avatar
some older versions i had lying around
the advantage is you can manipulate the wire to mount to anything
Old 18th February 2017, 12:43 AM   #1211
emmjawsX
I never thought of that, the coathanger wire fitting perfectly through the fan screw holes. Cheers for the pro tip
emmjawsX is offline   Reply With Quote
Old 2nd April 2017, 11:30 PM   #1212
Matthew kane
I use cable ties.
Intel i7 3960X @ 4.7GHZ - Noctua NH-D14 | 16GB OCZ Platinum Series DDR3 1600MHZ | Asus Rampage IV Extreme (4901 bios) | 2 x Leadtek GTX680 4GB | PNY GTX465 unlocked to 470 (Physx) | Creative X-Fi Titanium Fatality Pro with LME47920's opamps | OCZ Vertex 3 240GB | OCZ Vertex Plus 120GB| 1TB WD Black, 2TB WD Green, 4 x 2TB Seagate LP | Enermax Revolution 85+ 1250watt | Antec P280 + Veris Elite | LG BD Rewriter
Matthew kane is offline   Reply With Quote
Old 4th May 2017, 8:23 AM   #1213
Aussiejuggalo
Aussiejuggalo's Avatar
Question for you guys, how would one go about securing an 1155 stock cooler to an Asus Gene V board?
All but one of the push pins is fine but I've never trusted these damn things, found they always have a habit of popping out of place and it's got a journey with Auspost to survive .
Folding Points
My baby: AMD 1800X / MSI B350M Mortar Arctic / G.Skill Trident Z 32GB 2666MHz C14 / Sapphire Radeon R9 290 Tri-X OC (Vega later) / Samsung 960 Evo 250GB / Samsung 850 EVO 1TB / WD Blue 1TB / EVGA G2 850w / Caselabs SM5 / Dell U2414H x2 & Asus VG248QE
Aussiejuggalo is offline   Reply With Quote
Old 4th May 2017, 9:02 AM   #1214
kombiman
Re-Member
kombiman's Avatar
In this thread it's expected you use cable ties, string or hot glue...
this space left intentionally blank
kombiman is offline   Reply With Quote
Old 4th May 2017, 9:05 AM   #1215
Aussiejuggalo
Yeah I know, exactly why I asked. Was thinking maybe some drops of hot glue on the clips at the back of the board, cant really see any other way.
These coolers are a pain in the ass .
Folding Points
Tags
dodgey_brothers, fire_hazard, ghetto, homeless, mod
