Old 8th October 2011, 6:13 PM   #121
sammy_b0i
sammy_b0i's Avatar
Why didn't you just get a drill/wire cutters/tin snips/hacksaw/stanley knife/pliers and remove it bit by bit, then sand it down. You needn't have waited three months
Optiplex 990 SFF - i7-2600, 16GB DDR3, Galax GTX1050Ti LP O/C 4GB, 480GB OCZ Trion150, 250GB Kingston HyperX Savage, BL3200PT
Originally Posted by tommodmc View Post
OCAU is a breeding ground for hyper-moralistic 13 year olds who've never stepped out of the computer room in their entire life. Young liberals, young labor, people who will grow old and die before they ever think about pulling their head out.
sammy_b0i is online now   Reply With Quote
Join OCAU to remove this ad!
Old 8th October 2011, 6:16 PM   #122
Garido
Garido's Avatar
You can ask BlueRaven but a hacksaw couldn't do the job given the position of the piece of plastic. The plastic was too thick for a stanley knife and pliers to snap the plastic would have been too risky.
TRADE REP (50+) | CAR: TOYOTA CROWN WORKLOG | PC: WORKSTATION WORKLOG
Crown nearing the end, final stretch.
PC: Intel E6500 @ 3.7, 9600 GSO 384MB GDDR3 @ 650/1625/970, 4GB PC3-8500 @ 1346MHz
WTB: Samsung SSD/HDD, DDR3 RAM, nVidia 8600GT, Dual Monitor Stand, Lenovo S10e Battery
Garido is offline   Reply With Quote
Old 8th October 2011, 10:59 PM   #123
Mistikal
Mistikal's Avatar
Here is the second incarnation of my "Ghetto Box". I made another using the same style of storage container modified for AT-style systems, but I can't be bothered going to find it.
This one is Fullsize-ATX-spec, complete with 2 areas to mound hard drives and the optical drive on the top. Idle temps on a P4 system weren't bad, full-load was a different story thou.
The only tools used were a soldering iron (to melt the plastic) and a screwdriver to mount screws - no cutting tools at all.
This used to house my LAN system - had a whopping 200GB hard drive in it back in the day, considered massive back then.
Here is the third incarnation using an old ITX board. This one was built back in about 2004, with the aim being to only have one hole out the side for cables, and one out the bottom for cables (after installing a few feet on the bottom). The CDROM is slot load, but it's a very tight fit to get a CD in there!
I absolutely LOVE ghetto mods - some of the best modding is done on the cheap! If only I had a camera over the years to photograph some of my more ingenious creations...
Main PC: i5 3750K, GA-Z77-D3H, 256GB SSD, 2x 3TB @ RAID1, 32GB DDR3 1600, GB GTX970 4GB, Win 7 HP.
My Junker: HP ProBook 5320M, i5 450M, 840 Evo 120GB SSD, 4GB DDR3 1333, 13.3" LED, Win 7 HP.
Car #1: 04 VY Calais LS1 - 310rwhp, AP brakes, HSV 19s - cruiser! || Car #2: 95 K11 Micra Super S - paint job, engine swap, big stez - daily!
Mistikal is offline   Reply With Quote
Old 9th October 2011, 10:43 PM   #124
RyoSaeba
RyoSaeba's Avatar
Here's my contribution.
Sennheiser HD555 (dampener removed) + logitech USB headset
Dremeled away the rest of the logitech headset and only left the microphone. Then just hot glue it back onto the side of the Sennheiser. It can still rotate out of the way if I need to. Excellent for confort.
RyoSaeba is online now   Reply With Quote
Old 9th October 2011, 11:23 PM   #125
tiro_uspsss
tiro_uspsss's Avatar
CL-ASSY!
tiro_uspsss is offline   Reply With Quote
Old 10th October 2011, 7:48 PM   #126
Clippit
Clippit's Avatar
Not sure if I posted this one already - the band on my headphones was never very good, so when it fell apart I upgraded it:
Yes! Tula's finest engineering!
Also - various zero-budget things to stop it melting and make it slightly less noisy:
Also also I dun did some Bunnings Racing Team pedals a while back which are still working
Eat recycled food. It's good for the environment and ok for you.
Clippit is offline   Reply With Quote
Old 11th October 2011, 11:24 PM   #127
RSDXzec
RSDXzec's Avatar
Originally Posted by Creekin View Post
i think it's shearing time..
so allow me to contribute on his behalf for now...
also lol@ yamaha mixer! fsckin noobz!
A&H FTW
i like this... but i think it's a bit too dangerous lol, I wouldn't even put a standard wc setup on my pc, let along use a garden hose XD
Main PC: ASUS ROG Rampage III Extreme, i7 920, 12GB 1600Mhz CL7 OCZ platinum DDR3, 2x Sapphire HD695/70 CrossfireX, Corsair HX-1000, 2tb, 2tb, 640gb, 100gb HDDs
I lost 16C on my GFX card for free!
And another 13C when I put a 9800GTX hsf on an 8800GT
RSDXzec is offline   Reply With Quote
Old 11th October 2011, 11:26 PM   #128
brayway
brayway's Avatar
I Had less problems with that system that I did with my normal setup, It didn't leak or anything! Also had a tight fit into the Fittings
i7 950 - 3x GTX470 - 12GB Corsair Dominator - Corsair 800D | 2013 Macbook Air 13" |
'96 FTO GPX | '94 FTO GS | '92 Legacy GX | '89 Legacy RS |
brayway is offline   Reply With Quote
Old 11th October 2011, 11:32 PM   #129
RSDXzec
RSDXzec's Avatar
hahaha nice, I just wouldnt risk it lol, well maybe on an older system but definitely not on my gaming pc. And tubing is so cheap anyway, I guess a good improvement would be to use an old car radiator or something instead of one from pccg because they cost a bit more. I was seriously considering doing this at one stage, but then I found out how high the flow rate was through one of those
Old 11th October 2011, 11:33 PM   #130
brayway
brayway's Avatar
I was waiting for tubing etc to come, so just used what i had on hand
Old 11th October 2011, 11:36 PM   #131
RSDXzec
RSDXzec's Avatar
wow haha, must have been really impatient then I thought the original idea was to save a few bucks, but I'd rather wait. Did you end up using the tubing you bought or did you keep the hose on there? (since you said it worked so well)
Old 11th October 2011, 11:37 PM   #132
brayway
brayway's Avatar
Replaced it as soon as my new stuff got here.
It was to stiff and wouldn't bend well enough.
The new stuff being clear garden tubing from bunnings
Which about a month later, was replaced with the tube I have now.
Old 13th October 2011, 1:30 PM   #133
WishBone17
WishBone17's Avatar
Whatzz up ma wiggers!!, Here is my ghetto spoon trick.
INTEL I7-3770K @4.8GHZ (DELIDDED) | MSI BIGBANG M-POWER Z77 | 16GB CORSAIR VENGEANCE 1600MHZ DDR3 | GPU less for now (using onboard intel) | CORSAIR AX1200 PSU | LIANLI PC-Z70 | AOC 12757FH + DELL U2311H | WIN10 PRO 64BIT | ..:: PICS ::..
Originally Posted by ironized View Post
Our father who areth a lurker, creeking be your name, We are here in the most boring of times and pray for you to once again walk among us. Ahnus.
WishBone17 is offline   Reply With Quote
Old 14th October 2011, 9:22 PM   #134
SYF_Karma
SYF_Karma's Avatar
this isnt as ghetto as it could be, but there were no cable ties spared
need an interim solution to mount my rig in my rack, need the deskspace
mobo tray from MM, pedestal for ascension from MM, everything tied lol
works tho, cant complain
|| zeropluszero - the dude is a solid alcoholic ||
SYF_Karma is offline   Reply With Quote
Old 14th October 2011, 10:00 PM   #135
Protolisk
What does that do?
Protolisk is offline   Reply With Quote
Tags
dodgey_brothers, fire_hazard, ghetto, homeless, mod
