Go Back   Overclockers Australia Forums > Software Topics > PC Games > MMOs
Old 12th April 2012, 10:02 PM   #61
Zoltag
Originally Posted by Petrov View Post
I can highly, highly recommend the game - even in beta state.
Agreed
Though there are some little niggles which I hope they sort out.
Zoltag is offline   Reply With Quote
Join OCAU to remove this ad!
Old 13th April 2012, 12:16 AM   #62
sparz14
sparz14's Avatar
its a sweet game! i think its going to take alot of profit away from diablo 3.
Sooo many ppl talking in game that they are gunna keep playing PoE instead of buying d3. By the sounds of it, the only thing d3 has over poe is the graphics. Dont get me wrong, i love d2 and cant wait for d3.... but this is crazy good value for $10 pre purchase (access to beta) compared to $100 for d3
3570k // z77x-ud3h // 460GTX// 16gb 1600mhz ddr3 // CM gx750 // corsair h100 // 120gb ssd, 2tb sata3
sparz14 is offline   Reply With Quote
Old 18th April 2012, 11:17 AM   #63
Scorpion121
Scorpion121's Avatar
Just bought my closed beta key, can't wait to try it out with a couple of mates tonight.
Does anyone know if the client is on the Internode fileserver? Can't check it at work.
Originally Posted by DarkZeus
Got naked in presearing and accidentally sold my pants to the merchant.
Scorpion121 is offline   Reply With Quote
Old 4th May 2012, 7:11 PM   #64
Petrov
New beta patch coming out on 8 May - apparently quite big improvements and changes to the game. Monster AI has been mentioned specifically.
Petrov.
Petrov is offline   Reply With Quote
Old 8th May 2012, 8:31 PM   #65
RnR
Open beta this weekend apparently.
RnR is online now   Reply With Quote
Old 12th June 2012, 8:39 PM   #66
misc.
misc.'s Avatar
I've been playing so far for about 6 days and have levelled up 3 different classes to a mid range character level.
These are my initial impressions from the beta:
General
Very similar to Diablo 2, in fact if I had to sum this game up in a sentence I would say it is Diablo 2.5.
It is amazing what has been achieved from this small studio.
Graphics
Pleasing and well delivered. Very much suit the theme of the game. There are enough different areas and eye candy to keep you happy instead of just one dreary monotony.
The animations are smooth and do justice to the gameplay, i would make that comment alongside other players that the spiders in game are freaky, even after death.
Sound
Sound effects are spot on, do the job and enough diversity between enemy types to be useful.
Leaves a little to be desired in the music department. Not due to the current music that fits well but there is not enough diversity. The existing music is engaging, ambient and ethereal for the most part and upbeat when required it does suit the mood well. I think the lack of diversity is due to its stage in development and my understanding is that the proper launch soundtrack is being made now ready for launch.
Gameplay
Itemisation is pretty much spot on. There is a massive diversity of items that is pretty similar to diablo 2. The major change is with sockets in place in virtually every item that allows the use of active skills.
The in-game currency consisting of orbs used to modify/upgrade/change items also ties directly into the diversity of items.
The active skills being tied to gems that you then place into items and level up whilst on your gear makes for a very replayable and ever expanding experience. I haven't found all the skill gems yet and some are restricted by level. Many are given as quest rewards and you can get them as infrequent drops from monsters. This allows for many different types of play such as: -levelling up skill gems for one character with another higher level character
-making sure you dont level them up too quickly if u cant keep up with the mana cost
-the ability to swap/change/try different skills on the fly
-play like pokemon and try to collect them all
The second aspect central to the gameplay is the passive skill system that is a very interesting way to approach the customisation of a character. It is the only choice when you level up and combines a choice of attributes and 'skills' on the same passive skill tree (see here http://www.pathofexile.com/passive-skill-tree/)
As you can see it is basically limitless in which direction you can go with whatever class you want. There are limited respec orbs available, as quest rewards, as an infrequent drop or through trading.
The way both the active and passive skills are handled is in my opinion the best way to allow a lot of customisation whilst still allowing for meaningful choices on your character. It also gives the incentive to restart and level up again with the same class to try a different passive skill tree, a different build or playstyle. The great thing is you dont then have to start from scratch but have access to the active skills that you have acquired. But some may have been levelled up too much and you wont have met the level requirements.
Intel q9400 | Gigabyte x38-DS5 | INNO3D 8800 GTS 512MB | Kingston 4GB 800 | Many HDDs | Pioneer 215BK | Viewsonic 28" | VAF DC-X Mk.I| Logitech G15 Blue | Logitech G5 2007 | Thermaltake Armor
Asus STX > Corda Cantate > HD595/DT531/DT880
$$ Addicted to Shop & Swap
#0013 $$
misc. is offline   Reply With Quote
Old 12th June 2012, 8:44 PM   #67
Petrov
Thanks for the detailed review.
I've been playing for a couple of months and the game is fantastic. In my view, far more fun and with a great, great deal more longevity than D3.
Far more interesting customisation and gear setups. Great community. Great developers. Lots of end game interest. Not dumbed down, but not overly complicated.
Most importantly for me, THERE IS NO PAY TO WIN. NO REAL MONEY AUCTION HOUSE.
By the way, I think this should be moved to the general PC Games thread - it's no difference than D3 in terms of stlye of game. I think the game gets less exposure stuck in the MMORPG section.
I am hugely confident that any fans of D2 will enjoy this game tremendously, moreso than D2's erstwhile successor.
Petrov.
Old 12th June 2012, 8:53 PM   #68
misc.
misc.'s Avatar
(continued)
The difficulty isnt forgiving and I think this is great! This is mostly limited to your items and not your build at the early stages of the game, so that next item will help you kick monsters butt. Towards the mid game though you will need to have specialised your active skills towards something, or have done the same with your passive build otherwise you will find that the ability to kill monsters the same level starts to grind to a halt. You can always get carried by a party if necessary whilst you work towards something though, or until you find that awesome bow/sword/whatever.
I think this is the two things that made diablo 2 so great, always chasing that next great item and always chasing that next great build, and they have captured it perfectly in this game. The way that items and skills have been implemented has certainly had me coming back for more, and even with limited playtime I feel that this has the same sort of gamblers addiction that diablo 2 had that kept me coming back for more like a crack whore to blowjobs for her next fix.
The quests are very similar to a lot of others in the genre, there isnt really much innovation here or anything that is out of the ordinary. Mostly go to A, collect B, return to C or 'kill this' quests. There is also a limited amount of content, this is due to the limitations of the beta with lots more to follow upon release.
I havent touched too much on the storyline because to be honest I have been too busy trying to play the game instead of following it closely. I think the storyline is also in further development and will be improved upon release.
Partying is easy, you can name and create a party in 2 seconds. This has been great even during the short period of time I have been playing in public parties.
The community is great and the playerbase is helpful and supportive. I highly recommend further reading on the official forums.
A lot of the current complaints I have about the game are missing features that are in development and to be implemented soon. Namely a lack of chat channels, easier trading between characters, more info on game mechanics and the lack of an oceanic server.
Summary
If you really enjoyed D2/LoD and were towards the more 'hardcore' of the playerbase then this is a game I would recommend to you. I think it would be better to wait until release, or play the beta sparingly so you dont get frustrated over the lack of content and some of the missing gameplay elements.
This game with a bit of polish will certainly be taking up a lot of my time as i try to find or craft that next great item or make another character for a specialised build.
#0013 $$
Old 13th June 2012, 11:59 AM   #69
andydev
andydev's Avatar
Does anyone has a key available?
If I could choose a superpower...
I'd like to put my life under version control. Specifically I'd like to Fork multiple branches of reality, rollback anything I don't like, and switch between branches at will Merge the forked branches and resolve any merge conflicts by hand
andydev is offline   Reply With Quote
Old 14th June 2012, 12:30 AM   #70
Petrov
Come on mate - it's $10 for a beta key and I would be amazed if you didn't get value for money many times over.
Petrov.
Old 14th June 2012, 10:02 AM   #71
DNX
Just brought the $10 pack, looks interesting and downloading now.
| ASUS Prime Z270-A | i7-7700K @ 5.0GHz 1.376v (Delidded) | 32GB Corsair Vengeance LED DDR4-3200 | 500 GB Samsung 960 Evo M.2 | 480GB HyperX Predator M.2 | 2 x Samsung 850 EVO 500GB | 4TB Seagate Hybrid HDD | Corsair HX1000i PSU | MSI 1080 SeaHawk EK X | TT The Tower 900 Case | ASUS ROG Swift | ASUS PB278Q | Win10 Pro x64 | Corsair Gaming K95 RGB MX RED | Krone XTD Mouse | Full Custom Water Cooling |
DNX is offline   Reply With Quote
Old 14th June 2012, 5:59 PM   #72
Petrov
Let me know if you need a hand in-game, I'd be happy to help out. I'm generally on during Australia east coast mornings given I'm on the other side of the world.
Petrov.
Old 26th June 2012, 8:47 PM   #73
Petrov
Awesome news - new end game for PoE! Talk about innovation and longevity. These guys are just brilliant old school game designers.
http://www.pathofexile.com/news/2012...dev-diary-maps
Petrov.
Old 28th June 2012, 1:07 PM   #74
cavanor
I supported the game and have 2 free keys if anyone wants them.
cavanor is offline   Reply With Quote
Old 28th June 2012, 1:11 PM   #75
sammy_b0i
sammy_b0i's Avatar
I am!
Ryzen R7 1700, MSI X370 Gaming Pro Carbon, Noctua U14S, 16GB G.Skill TridentZ 3200MHz, eVGA GTX980 Classified, 480GB OCZ Trion150, eVGA G2 750W, Fractal Define C, BL3200PT
Originally Posted by tommodmc View Post
OCAU is a breeding ground for hyper-moralistic 13 year olds who've never stepped out of the computer room in their entire life. Young liberals, young labor, people who will grow old and die before they ever think about pulling their head out.
sammy_b0i is online now   Reply With Quote
