Go Back   Overclockers Australia Forums > Specific Hardware Topics > Modding > Modding Worklogs
Old 20th May 2017, 11:14 AM   #16
alexciobanu Thread Starter
alexciobanu's Avatar
Hi guys,
Here's most of the piping done!
One issue I had with this is that two of the pass through fittings were way too close to each other and I only had Bitspower C47 style fittings that were a bit too large. So I ended up hand filing them down.
This was the result:
Just shaved off a few mm and they fit perfectly with a bit of tubing between them.
They're the ones at the very bottom.
Mounted the RGB LED controller for the Corsair fans in the front as well. This will be accessible from the side even with the front panel on.
And here's a look at the cable management.
And now the inside.
The red chrome tubes, with the fittings in the middle is a reference to the dual lightsaber.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
alexciobanu is offline   Reply With Quote
Join OCAU to remove this ad!
Old 20th May 2017, 4:13 PM   #17
thmrsh
thmrsh's Avatar
Absolutely loving this build.
What an inspiration
i7 5930K - X99 CLASSY- 32GB DDR4 - GTX1070 - H115i - EVGA 1000W G3- 10x4TB WD RED - 960 EVO 512GB - XL2720Z - APC 900VA PRO UPS - UNRAID SERVER 6.4
thmrsh is offline   Reply With Quote
Old 21st May 2017, 10:19 AM   #18
What an inspiration
Awesome! Thanks a lot
Old 21st May 2017, 10:43 AM   #19
Hey guys,
These were the final photos I took before getting all the panels on and finishing the build
As you can see, I went with black coolant and I also have a few red cold cathodes in there just for some more lightsaber references
Stay tuned for final pics!
Cheers,
Alex
Old 25th May 2017, 6:52 PM   #20
Hi guys,
Here are the final photos! I hope you like it, I'm really happy with this one!
The only thing that might need to be changed or improved is the light behind the Darth Maul face on the front panel. The white acrylic would need to be changed to opal and get some better lighting in there so that the front panel pops nicely in the dark.
I'd like to say a huge thanks to the companies that helped me bring this project to life!
Here we go! I'll start with the outside first!
And here's the inside!
Thanks for checking it out and stay tuned for a video once I get back from COMPUTEX!
Cheers,
Alex
Old 25th May 2017, 9:41 PM   #21
havabeer
havabeer's Avatar
the scratched up side cover looks awesome, just think its a bit over done everywhere else and looks a bit more snow camo then space battle
Current rig: CPU i7 5960X - Mobo MSI x99 pro carbon - GPU 2x Titan X (pascal) - Ram 16gig DDR4 2666 G*skill - Case Custom little devil V8 - Monitor Phillips 40" 4k
Cooling - Custom water loop - 360 rad x 2 - 480 x 1 - acrylic hard tube
havabeer is offline   Reply With Quote
Old 27th May 2017, 11:16 PM   #22
thmrsh
thmrsh's Avatar
This is exceptional. Thank you!
Old 10th July 2017, 11:22 PM   #23
Hey guys!
I just want to share the videos of the build as well for those interested.
I did a time-lapse and showcase video and also a case mod summary video!
Hope you guys enjoy them
Thanks for checking it out!
Cheers,
Alex
