Go Back   Overclockers Australia Forums > Specific Hardware Topics > Modding > Modding Worklogs
Old 26th July 2017, 7:05 PM   #256
kEv_
kEv_'s Avatar
holy crap, thats compacted nicely!
awesome job!
|Gaming: 4930k @ 4.5|RIVBE|16Gb 2800Mhz|512Gb 840 Pro|R9 290x Crossfire|AX-1200i|Custom Watercooling|LD PC-V8|
|HTPC: 4670k @ TBA|MVII Impact|16Gb 2133Mhz|256Gb 840 Pro RAID 0|GTX 780 SC|AX-1200i|H100i|Dimastech TB|
kEv_ is online now   Reply With Quote
Join OCAU to remove this ad!
Old 26th July 2017, 7:31 PM   #257
mad_mic3 Thread Starter
Thanx's Kev
mad_mic3 is offline   Reply With Quote
Old 26th July 2017, 10:57 PM   #258
Deano_20802
Deano_20802's Avatar
Originally Posted by mad_mic3 View Post
Thanx's Deano, its a group effort
Top work everyone involved then!!
awesome job!
That's what I thought!
Deano_20802 is offline   Reply With Quote
Old 30th July 2017, 3:25 PM   #259
Default End of the week
Hi Everyone
Just a couple more bits
This pic shows how the rad will sit once in place
In situ
Mark the position so it can be channelled out
Channelled out, alloy plate glassed in, i'll drill & tap it out l8tr
"Red Line" is where the cables will pass thru body
i'll put a fan grill on the rad fan so the cables cant get worn from the rad fan
allowing rad clearance on the top cover
trimmed the glass edges & started another section surface
Thanx's for looking
mad_mic3
Ps: IF anyone can help out with another 2.5" "spin drive or ssd" & 3 20cm/200mm sata cables let me know
Old 31st July 2017, 10:04 AM   #260
killersaint
Hi Everyone
Hi Mic,
I have a pile of Blue 23cm SATA cables, and a handful of 320Gb 2.5" Spin HDD's if you'd like?
Jeremy
killersaint is offline   Reply With Quote
Old 31st July 2017, 11:25 AM   #261
Hi Jeremy, that would be sweet as
Old 7th August 2017, 4:54 PM   #262
Default Flat as a tack
Hi Everyone
A Big Thankyou to “Killersaint” Jeremy, received the hdd & cables
So every now & than the camera battery goes flat, got these pics in before it happened
The cable hole/ access port received a couple of coats of glass
the red box area will have a hole tapped so the cover can be removed/ refitted as required
It don't look pretty, but will shape up good
added a couple more layers of glass, still have to drill & tap the mounting holes for the rad mount
a quick hit & lick with the 5" grinder & rotary burr
top side view
bottom view
a quick trim of the edges
showing how it looks sitting on in the raw
Well that where the battery went out, ive got the 1st coats/ layer of body filler on, next update you"ll see it
Thanx's for looking
mad_mic3
Old 7th August 2017, 5:19 PM   #263
Ma Baker
Retired
Ma Baker's Avatar
Looking great, so much care and attention to detail.
Ma Baker is offline   Reply With Quote
Old 7th August 2017, 6:21 PM   #264
Thanx's Ma
Old 12th August 2017, 8:19 PM   #265
Defyant
Defyant's Avatar
I miss modding with bog and glass , but it's great i can re-live it through your mod
Amazing work as always mate
Don't "Just Cross that bridge when you get to it" , Mod it!
Never argue with an idiot. They will drag you down to their level and beat you with experience!
Defyant is online now   Reply With Quote
Old 13th August 2017, 7:58 AM   #266
Thanx's Defyant,
i'll post up a couple of pics midweek with where its at
Old 16th August 2017, 7:00 PM   #267
Default Oh Oh from the rear
Hi Everyone
Cable access hole
mark it out, pre drill some holes,fibreglass the edges & recess, file to shape & size & recess the cutout
the 90 degree pwr chord needs to fit the hole after refiling the glassed edges
the backside recess to allow a bit extra cable clearance, all edges are rounded so no sharp edges to cut or fray the cables
recess sanded to depth to allow for some filler & the alloy plate to sit flash
trial fit for depth 1st up
filler added & sanded
plated fits flush
still need to drill the mounting hole & cutout the cable hole/slot
left out a heap of pics, but i'll give you the scoop
still need to drill & tap the mounting holes
still a couple of hours away from finishing this part off, but allot closer than last week
Well that's it for a couple of weeks, r/l needs sometime
Thanx's for looking
mad_mic3
Old 16th August 2017, 7:26 PM   #268
StreekG
StreekG's Avatar
This is really awesome, love what you're doing
Case: NZXT H630 CPU: Intel i7 990X @ 4.6Ghz. Cooling: Custom CPU Loop. Motherboard: Gigabyte G1 Assassin. RAM: Corsair Dominator Platinum 16GB @2130. GFX: MSI GTX 980 Ti Lightning . Power: Seasonic XP-1050 Platinum OS: Windows 7 Pro 64 Monitor: Asus ROG Swift PG278Q Keyboard: Ducky Shine 3 Snake Edition Cherry Red Mouse: Steelseries Sensei
Storage: Samsung 840 EVO 500GB SSD \ WD 1TB Caviar Black
StreekG is offline   Reply With Quote
Old 16th August 2017, 7:44 PM   #269
Thanx's StreekG
