Go Back   Overclockers Australia Forums > Specific Hardware Topics > Hobby Engineering
Old 13th March 2014, 8:35 AM   #151
Billzilla
Billzilla's Avatar
Blokes, FWIW I've ordered a new machine that can print a much larger object - 225 x145 x150 millimetres they reckon and it's got twin extruders so I can make objects with two colours at the same time.
www.billzilla.org
Billzilla is offline   Reply With Quote
Join OCAU to remove this ad!
Old 16th March 2014, 1:27 AM   #152
Twizzly
Twizzly's Avatar
out of curiosity what machine did you get?
and will you still be doing prints on demand?
Twizzly is offline   Reply With Quote
Old 16th March 2014, 8:38 AM   #153
Billzilla
Billzilla's Avatar
Flashforge (clone of a Makerbot 2X) and yes.
www.billzilla.org
Old 16th March 2014, 1:12 PM   #154
TERRA Operative
TERRA Operative's Avatar
Well, this makes things a bit more interesting......
I have some ideas I want to try, keep us updated.
Tereno Empireo Rapidmova Reakcii Armeo
Check out my Youtube channel for semi-awesome videos!
TERRA Operative is offline   Reply With Quote
Old 16th March 2014, 4:16 PM   #155
smork
I'm Batman
I'd love to get one of these made up if anyone can help -
http://www.thingiverse.com/thing:118972
Haven't seen 3d printing up close though, do they look smooth when done and if not can they be sanded smooth and painted?
Over $7000 in trades
Succesful trades - Blue_muppet, alba, stedyedy, =BiG_TiMMy=, Arbitrator, puh_leease, dewy, |24NG3|2, Skip, reanimator, decryption, 4ndr3w, maroun9, Monkeyx123, RXII, ICE009, mattwalker, ecstasy + way more, Never had any issue.
smork is offline   Reply With Quote
Old 16th March 2014, 7:21 PM   #156
Billzilla
Billzilla's Avatar
Erp, it's quite large.
Waaay too large for my current printer and I suspect a bit too large for the new one I haven't got yet.
Yes they can be sanded smooth.
www.billzilla.org
Old 16th March 2014, 8:53 PM   #157
mtma
Based on the comment it looks like the original author made his using a rep 2? I haven't check the STL but I would think that would fit.
mtma is offline   Reply With Quote
Old 16th March 2014, 9:39 PM   #158
Twizzly
Twizzly's Avatar
looks like rep2 and in two parts.
Old 16th March 2014, 10:18 PM   #159
Menthu_Rae
Menthu_Rae's Avatar
Hey guys,
I have a RepRapPro Huxley available to do small prints in white or black PLA
Maximum build size is 135mm [X] x 135mm [Y] x 80mm [Z] - can print down to 0.2mm Z-layer height.
I am also able to assist with taking 2D designs or concept sketches into 3D designs with CAD files provided in nearly any format you'd want.
So if anyone is interested, shoot me a PM.
P.S. I am hoping to get my Ultimaker running again soon - it can do something like 200mm x 200mm x 200mm down to 0.025mm Z-layer height.
System Specs: i7 3770S, Noctua NH-U9B SE2, 32GB Corsair Vengeance LP DDR3-1600, ASUS P8Z77M-PRO, 6GB ASUS GTX980 Ti, 512GB Samsung 840 Pro / 525GB Crucial MX300, 2x 5TB Toshiba HDDs [RAID1], Dell U3011, ASUS Xonar Essence One, Audioengine 5+, LianLi PC-A04B, 3x Noctua NF-F12-iPPC-2000, 3x Noctua NF-B9 Redux 1600PWM, 1kW Silverstone ST1000P. 50+ Trades.
Menthu_Rae is offline   Reply With Quote
Old 16th March 2014, 11:42 PM   #160
kaotic_azn
Can confirm it will fit on a Replicator 2 and possible to do in 1 print if you don't mind the risk of having it print over the edge.
kaotic_azn is offline   Reply With Quote
Old 20th March 2014, 4:26 PM   #161
Billzilla
Billzilla's Avatar
The new printer arrived - it's got two extruders so I can do two colours in the same print and the print platform is nearly twice the size.
It'll take me a few days to get it all sorted.
www.billzilla.org
Old 29th March 2014, 11:54 AM   #162
Dom.
Dom.'s Avatar
Can anyone print this?
Im after it in a Clear PET or PLA It needs to be clear as it will have LEDs inside it
Dom. is offline   Reply With Quote
Old 29th March 2014, 2:27 PM   #163
Billzilla
Billzilla's Avatar
I've got a filament in ABS that's supposed to print pretty clear.
Depending on skin thickness, etc, it'd be about $60.00
www.billzilla.org
Old 2nd April 2014, 7:50 PM   #164
DrFrag
I'm after some 3D printing, but I'm new to this so I'm mostly after some preliminary info.
I'm doing a PC case mod using the same principle as Connect-It. Plastic corner pieces that get joined up with square tube aluminium. They looks like this:
They only make them for 25mm square tubing, which is fine for furniture but a bit chunky for a PC case. So I'd like to try it with parts made for 16mm or 12mm square tubing.
The original 25mm piece is hollow with 3.5mm thick plastic. I don't know what type of plastic it is but it looks injection moulded.
Is there anything tricky I need to know before I learn Blender? Support struts, wall thickness, etc? Or is this as straightforward as it looks?
DrFrag is offline   Reply With Quote
Old 3rd April 2014, 11:18 AM   #165
akashra
akashra's Avatar
Just curious, I'm sure someone here could answer, but I'll soon need to prototype some cases for an electronics design I'm working on - for a casing that about 3.5 x 3.5 x 1.0cm, open on one side so the PCB can go in and then be filled with epoxy, roughly how much in material for a 3D printer is this going to cost?
I have no idea how much they use.
Punctuation is the difference between "Let's eat, grandma!" and "Let's eat grandma!".
akashra is offline   Reply With Quote
