Go Back   Overclockers Australia Forums > Specific Hardware Topics > Hobby Engineering
Old 17th June 2013, 7:20 PM   #16
Billzilla
Billzilla's Avatar
Originally Posted by TERRA Operative View Post
Printing in two halves is fine. I can slice it myself and send two files (I think it is symmetrical). I can finish the parts no worries. I just need the shape to start from.
Here are the dimensions and volumes of the parts (weights for ABS, 100% fill)
- Yellow trigger - 30 x 12 x 40 mm, 6 cm^3, 6.5 grams
- Orange horseshoe - 115 x 80 x 30 mm, 50 cm^3, 54 grams
- Green handle - 110 x 135 x 20, 90 cm^3, 96 grams
- Orange star - 70 x 80 x 40mm, 71 cm^3, 76 grams
Okay flick me the STL's and I'll have a better look at them.
www.billzilla.org
Billzilla is offline   Reply With Quote
Join OCAU to remove this ad!
Old 17th June 2013, 10:07 PM   #17
TERRA Operative
TERRA Operative's Avatar
Just sent you an email to the Billzilla email on your website.
Tereno Empireo Rapidmova Reakcii Armeo
Check out my Youtube channel for semi-awesome videos!
TERRA Operative is offline   Reply With Quote
Old 17th June 2013, 10:16 PM   #18
Billzilla
Billzilla's Avatar
Got 'em.
Replying in a few minutes.
www.billzilla.org
Old 18th June 2013, 10:31 PM   #19
ugotdan
ugotdan's Avatar
Default 3D Printing Request
I have a request!! Can you please quote me prices (x10) for these TrackIR frames and posted to postcode 4814??? Color black plz -can you do glow-in-dark??
I made one for myself and a mate in Sydney printed it at work then sent it up, but I can't keep asking him to do that lol - just a prototype. Now my friends want some and I'd like to make them
Below is a file with the specs for anyone to use and quote on pleeeeeeaze
www dot thingiverse.com/thing:62827
This is my finished DIY TrackIR
*If you cannot get the file from the site please PM me and I'll email it direct.
Thanks to the originator of this clip for sharing it with me!!
Building your own TrackIR is explained in all its glory on Free-Track.net. Worth a look!
Cheers.
ugotdan is offline   Reply With Quote
Old 19th June 2013, 6:32 AM   #20
Billzilla
Billzilla's Avatar
Yeah I can print that, but I'll have to separate the two pieces of that STL so I can do one piece at a time as it's a little large to do in one go. I'm pretty new to Solidworks but I'll give it a go in the next couple of days.
I also only have white ABS sorry but you can blow some black paint on it.
www.billzilla.org
Old 19th June 2013, 6:46 AM   #21
ugotdan
ugotdan's Avatar
Awesome! No problems with color, I was just throwing it out there. Could you PM me with a quote when you can?
Anyone else do any 3d printing in color??
Cheers
Old 19th June 2013, 8:11 PM   #22
Billzilla
Billzilla's Avatar
Cheers
I can print in a few different colours, but I have to fit a different colours roll of ABS into the machine. Not cheap for a one-off.
I'm having trouble cutting the STL into two pieces .... 'cause I have NFI how to work a lot of Solidworks yet sorry.
www.billzilla.org
Old 19th June 2013, 8:54 PM   #23
ugotdan
ugotdan's Avatar
Don't worry about colour, white is fine. Mine is white and looks good. I just want to see what's available.
Can't you just print each half? I then glue it together when I've installed the wiring.. I've never even seen solidworks. I don't know what the file contains.
If it's too much pain I'll see if someone with some knowledge of solidworks can figure it out. NP. I don't want you wasting time and money on something you're not familiar with. Thanks for trying though
Old 20th June 2013, 6:20 AM   #24
Billzilla
Billzilla's Avatar
The problem is that the way the parts in the file are set out, they are too far apart and won't fit on the print platform. I can shrink them up so they fit okay but then I guess it won't be any good for you.
I just need to get each of the two parts separated into one file each so I can print one part at a time, that'll be very easy then.
www.billzilla.org
Old 20th June 2013, 8:55 AM   #25
ugotdan
ugotdan's Avatar
Oh I see. I have no idea how solidworks works. bummer.
Old 20th June 2013, 10:54 AM   #26
Billzilla
Billzilla's Avatar
Okay got a mate to separate them for me.
6 grams for each piece so 12 in total, so a mighty $7.20 plus postage.
www.billzilla.org
Old 20th June 2013, 7:40 PM   #27
ugotdan
ugotdan's Avatar
wow that's a great price What is the finish like? Smooth like Crysis or grainy like Minecraft or in between like Arma the one I have looks smooth but you can feel the steps with a fingernail.
Old 20th June 2013, 10:19 PM   #28
Billzilla
Billzilla's Avatar
More like the latter.
It's a layer deposition machine - 0.15 mm layers - so it'll have a small grain to it. You can smooth that off pretty well by wiping the surface with a clean rag dipped in acetone.
www.billzilla.org
Old 21st June 2013, 8:53 AM   #29
ugotdan
ugotdan's Avatar
Will PM you shortly. Thanks for you effort!
Old 1st July 2013, 1:47 AM   #30
QuakeDude
ooooh weeee ooooh
QuakeDude's Avatar
A question guys - if I wanted to print a ring, with the following dimentions, how much would it cost me?
Outside radius - 70.8mm
inside radius - 58.4mm
thickness: 11.4mm
It doesn't have to be solid, but it does need to be thick enough to not warp / bend under a little pressure.
QuakeDude is offline   Reply With Quote
