Old 28th July 2017, 11:54 AM   #1501
Aussiejuggalo
Aussiejuggalo's Avatar
Originally Posted by OJR View Post
That's OK, the APUs have released as well.
The APU's are based on Excavator though, Raven Ridge are the Zen / Vega based ones.
Folding Points
My baby: AMD 1800X / MSI B350M Mortar Arctic / G.Skill Trident Z 32GB 3200MHz C14 / Sapphire Radeon R9 290 Tri-X OC (Galax EXOC 1080 soon) / Samsung 960 Evo 250GB / Samsung 850 EVO 1TB / WD Blue 1TB / EVGA G2 850w / Caselabs SM5 / Dell U2414H x2 & Asus VG248QE
Aussiejuggalo is offline   Reply With Quote
Join OCAU to remove this ad!
Old 28th July 2017, 11:54 AM   #1502
Zenskas
Zenskas's Avatar
Originally Posted by demiurge3141 View Post
Don't really like the r3's. On the low end igp actually matters, G4560 still the goto budget cpu.
Easily the G4560 is still the best lowest cost CPU (if you can find one). But the R3's really compete with the i3's and for the price they are better (depending on the task) or at least very similar (in gaming). Plus can overclock! For content creators or designers looking for a low cost quad core, and can use an existing GPU or want to buy a GPU for hardware acceleration anyway it seems the better choice, but I will admit I hoped the R3 would be faster than it is in single thread stuff.
The up and coming APU's may be the chips competing more with the Celeron/Pentiums (and the i3's if you need the IGP)...decent CPU performance combined with decent IGP performance for any basic builds Won't be amazing but will get better once they come out with a Zen based APU. Right now I'd still be buying a Pentium for builds on the tightest budget if you are using a dedicated GPU, and either the Pentium/i3 if you have no use for a dedicated GPU. If you have a little bit more $$ to spare over the Pentium and will be running a dedicated GPU the R3 is the way to go.
STFU: i7-2600S @ 4.2GHz | ASUS Maximus IV Gene-Z/GEN3 | G.Skill RipjawsX 16GB @ 1600MHz | EVGA GTX TITAN SC | Samsung 850 EVO 500GB | SilverStone HE02 | Corsair AX860 | SilverStone TJ08-EW | BenQ XL2720Z | Audio-Technica ATH-ADG1 | IBM KB-9930 | Logitech G502 | XTracGear Ripper XXL
Zenskas is offline   Reply With Quote
Old 28th July 2017, 3:22 PM   #1503
bobster
Originally Posted by pony-tail View Post
I got the mobo from NewEgg .
First ASRock mobo I have owned .
Let me know how the asrock board treats you, I have the Gigabyte but I may get an Asrock as well for HTPC build
Lots and lots of Trades
Ryzen 1800X, Gigabyte AB350N, 16GB 3200mhz Corsair LPX, EVGA GTX 1080ti , Samsung 950 Pro, Evolv ITX and EVGA 750 G2
bobster is offline   Reply With Quote
Old 28th July 2017, 6:38 PM   #1504
Dragonfly
Dragonfly's Avatar
Alienware Area-51 Threadripper first look and cinebench benchmark. Interesting they just have a small 120mm AIO cooler on it.
i5 3570K @4.5Ghz | Asus Maximus V Gene | 16GB GSkill Ripjaws | Asus Strix GTX1060 | Corsair RM650X PSU | Fractal Define C | Asus VG248QE & Dell U2412M
DesignInfusion
Dragonfly is online now   Reply With Quote
Old 28th July 2017, 8:02 PM   #1505
tuRtlez
Hi guys,
AMD Ryzen 1600
ASRock AB350M-PRO4
16GB DDR4 Corsair CMK16GX4M2B3000C15
I am looking at purchasing this combo. Has anyone had any experience with OCing with this ram and motherboard? Preferably trying to reduce price if possible
tuRtlez is offline   Reply With Quote
Old 28th July 2017, 8:41 PM   #1506
newlife
newlife's Avatar
Originally Posted by tuRtlez View Post
Hi guys,
AMD Ryzen 1600
ASRock AB350M-PRO4
For OCing you are really going to want a better board and if you OC on that board it would be a good idea to keep volts down
Edit: Also 6 caps over 9 phases seems odd given it's normally 2 per phase
Old 28th July 2017, 8:48 PM   #1507
Sgt Bilko
Sgt Bilko's Avatar
You guys should all get in on this: http://forums.overclockers.com.au/sh....php?t=1226743
AMD Community Manager
Comments are my own unless stated otherwise.
Sgt Bilko is offline   Reply With Quote
Old 28th July 2017, 9:01 PM   #1508
tuRtlez
my first time overclocking, so i really have no clue.
are there any good matx boards for overclocking?
Old 28th July 2017, 11:20 PM   #1509
bobster
Doesn't really matter, Ryzen don't oc that well its silicon lottery more than MB
Old 29th July 2017, 12:03 AM   #1510
MUTMAN
MUTMAN's Avatar
bios options and ram speeds might be important ...
MUTMAN is offline   Reply With Quote
Old 29th July 2017, 12:07 AM   #1511
newlife
newlife's Avatar
Power delivery quality is still a concern as cheap boards I imagine will struggle with 1.45v
Old 29th July 2017, 4:34 AM   #1512
eeikcud
I presume the one I bought off you wasn't?
i7 5960x 4Ghz / ASRock X99M Killer 3.1 / GSkill Ripjaws V Black 16GB 3466Mhz / EVGA SC+ ACX 2.0+ GTX980Ti / Intel730 240GB / ASUS ROG Swift PG278Q
I7 4790K / ASUS Z97 Pro Gamer / Kingston HyperX DDR3 16GB OC 1844Mhz / Galax GTX970 / 240GB PLEXTOR PX-256M5Pro
eeikcud is offline   Reply With Quote
Old 29th July 2017, 11:02 PM   #1513
pony-tail
Having issues wit Gskill 3200 mhz ram runs fine at 2400 , any higher I get a kernel panic (Linux mint 18.2 on a 4.10.0-28 kernel ). other than that fine
pony-tail is offline   Reply With Quote
Old 1st August 2017, 3:13 PM   #1514
SomeBoredGuy
finally got my case http://imgur.com/b2dQse0
gonna be using it for fileserver / rendering/ lan gaming
unsure if m gonna do a WC loop as i dont know where ill fit it all xD
Some one sell me a ryzen 1700 or 1600
Completed Sales List
The HotBox
Ryzen 1700 (no oc yet) stock HSF, gigabyte ab350n wifi,2400 ddr4 16gb kit,SF600 psu, gtx 660 (1080ti aio otw ) 2x 480 ssd , 1tb 7200rpm. Cougar QBX case
SomeBoredGuy is online now   Reply With Quote
Old 1st August 2017, 3:20 PM   #1515
Bertross
Bertross's Avatar
The Lynx effect
EVGA GTX 1080TI FTW3 | RYZEN 1700+H100I | ASUS ROG BIG HERO 6+SAMSUNG 950 PRO M.2 | 32GB TRIDENT Z RGB 3000 | PHANTEKS ENTHOO EVOLV TEMPERED | DELL U3415W 34"
Bertross is offline   Reply With Quote
