Old 11th August 2017, 8:16 AM   #1531
bobster
Default OCAU Ryzen Overclocking discussion/ Guide / Owners Thread
Anyone got Asrock X370 Taichi? My 1800X is too hot for my itx build so I'm getting another ATX case and board.
Need to know if there are any bugs or quirks with it
Lots and lots of Trades
Ryzen 1800X, Gigabyte AB350N, 16GB 3200mhz Corsair LPX, EVGA GTX 1080ti , Samsung 950 Pro, Evolv ITX and EVGA 750 G2
bobster is offline   Reply With Quote
Join OCAU to remove this ad!
Old 11th August 2017, 10:01 AM   #1532
mAJORD Thread Starter
mAJORD's Avatar
they seem a bit Bit over priced is about all. Especially now the Strix is available at just under 300
On the Bench: Ryzen 7 1700 - ASUS Prime X370 Pro - 16GB Corsair Vengance DDR4-3200
Main:
Ryzen 7 1800x - Crosshair VI Hero - 16GB G.SKill DDR4-3333 - ASUS 1080Ti FE - Custom water - Be-Quiet Silent Base
Ryzen OC / Owners Thread
Old 11th August 2017, 12:36 PM   #1533
lowdog
lowdog's Avatar
Got one and a Fat Pro Gaming....rocks
lowdog is offline   Reply With Quote
Old 11th August 2017, 5:14 PM   #1534
lowdog
lowdog's Avatar
So how's the 1800X - clocks n volts
Old 11th August 2017, 5:21 PM   #1535
SoulFire-Z
SoulFire-Z's Avatar
What case and cooling are you using?
I've got a 1700 with a p-state o/c of 3.8ghz and 3200mhz ram (XMP) and my temps are great (30c idle -> 65c p95 torture test)! I'm cooling it with a Corsair h100i v1 inside of a bitfenix prodigy.
SigSig?
SoulFire-Z is offline   Reply With Quote
Old 12th August 2017, 10:31 AM   #1536
mAJORD's Avatar
Originally Posted by SomeBoredGuy View Post
i like what i see
how much is the am4 cpu cooler ? hopefully gonna sell/trade my intel for am4 . might consider hard tubing but gotta get some help with doing the tubes. any good guides to it ?
Sorry man, I didn't see see your msg, just noticed it searching for another quote.
Probably a bit late, but Monoblock was $150,
As for hard tubing, was my first attempt, never really found any single decent guide to be honest, and as such I stuck to single bends, using elbows to take care of 2nd axis, and found this made it far far less painful / risky in regards to wasting tube .
Anyway it's all done and dusted. Temps from the monoblock aren't anything spectacular - peaking mid 70's at 4ghz 1.42v small FFT's,(@ a mid 30s water temp), but no VRM cooling to worry about, and it looks pretty neat I think, esp' with the crosshair logo.
So as above, like most people, struggling with the 4Ghz wall for long term viabilty. 1.42v LLC lvl 3 at the moment @ 4Ghz. but will fail prime after the loop gets too hot with combined GPU load (no point testing just CPU in a serial loop)
Will likely settle for slightly under.. 3.95Ghz is 1hr+ stable at only 1.32v! Reminds me of the old C3 stepping X2 days
Main:
Old 12th August 2017, 12:41 PM   #1537
Sgt Bilko
Sgt Bilko's Avatar
Gorgeous!!
AMD Community Manager
Comments are my own unless stated otherwise.
Sgt Bilko is offline   Reply With Quote
Old 12th August 2017, 7:31 PM   #1538
OJR
OJR's Avatar
mAJORD, tried cpu pll at 1.85v? i needed this to make my oc prine stable.
OJR is offline   Reply With Quote
Old 12th August 2017, 7:39 PM   #1539
Bertross
Bertross's Avatar
Thats sexy af
EVGA GTX 1080TI FTW3 | RYZEN 1700+H100I | ASUS ROG BIG HERO 6+SAMSUNG 950 PRO M.2 | 32GB TRIDENT Z RGB 3000 | PHANTEKS ENTHOO EVOLV TEMPERED | DELL U3415W 34"
Bertross is offline   Reply With Quote
Old 12th August 2017, 9:39 PM   #1540
mAJORD's Avatar
heh I can assure you it wasn't very attractive after the "Vinegar incident"
OJR - I've set it fixed 1.8, probably sshould revist / experiment with it again. 1.85 specifically worked for you?
Main:
Old 13th August 2017, 7:14 AM   #1541
OJR
OJR's Avatar
Yup. Unless I set this, prime would black screen evet time after about 30mins.
Old Yesterday, 3:59 PM   #1542
SomeBoredGuy
hye guys finally got my ryzen iitx hotbox together just looking to do some ocing now
i know for intel theirs a setting that gives extra voltage over the given vcore i wanna disable this for ryzen before i head in anyone know what its under in a gigabyte mobo ?
will add some more clean inside pictures when my 1080ti aio comes in and i get some shorter sata cables for management
Completed Sales List
The HotBox
Ryzen 1700 (no oc yet) stock HSF, gigabyte ab350n wifi,2400 ddr4 16gb kit,SF600 psu, gtx 660 (1080ti aio otw ) 2x 480 ssd , 1tb 7200rpm. Cougar QBX case
SomeBoredGuy is online now   Reply With Quote
Old Yesterday, 8:16 PM   #1543
bobster
Swapped my 1800X for 1700 now and everything is smooth and cool
If it wasn't the vrm it was CPU, GB itx boards are not designed for 95W CPU
Old Yesterday, 8:38 PM   #1544
SomeBoredGuy
id say it was just the cpu as joker on his review hit 4.0 on his 1700 with the gb itx board although im guessing he used a aio for it
really wish we could turn off the white amd led or change its colour
The HotBox
Old Yesterday, 10:28 PM   #1545
bobster
Joker test the VRM temps? I don't watch his video, his voice gives me the shits
