Old 14th May 2017, 4:27 PM   #31
fleetfeather
fleetfeather's Avatar
Originally Posted by Virtuoso X View Post
i dont get the need for 8/12/16 cores... seriously, why doesnt AMD just focus on its 6 core and get its clock up to par with intel's or surpass it
thats why i think Coffee will be atleast 4.5ghz stock
plus do programs / games even use the multi - cores properly anyway?
i remember seeing bench marks where two CPU's clocked the same, one being two core 4 threads the other being 4/8 and the results showed the 2/4 had better in-game performance (i7/i3 comes to mind)
AMD "getting it's clock up" requires access to fabs and a node process that is more mature than they have access to. It's not even AMD's R&D that's holding them back (anymore), it's the resources they have access to.
There's a special spot reserved in hell for anyone who pick-up snipes a good deal in Shop & Swap
4790k @ 4.7 | D15 | 1080Ti FE @ 2.0 | VII IMPACT | 16GB Tactical LP @ 2133 C9 | XP941 256GB | Ultra II 960GB | 460W Fanless | Nano S | X34 Predator | G303 | Artisan Hayate | A700X + D1 + Modmic
fleetfeather is offline   Reply With Quote
Join OCAU to remove this ad!
Old 14th May 2017, 9:58 PM   #32
Virtuoso X
Virtuoso X's Avatar
so instead they add extra, almost redundant cores?
X V Rig: i7 2700k 5.1Ghz @ 1.48v 24/7 | Asus Maximus IV Extreme ROG! | Ripjaws X 16GB 2133mhz | H100 | WD Blacks 4TB Vertex 3 240GB SSD | Phanteks Enthro Luxe | 1.2kW StriderGold | RX580
Gear: G9X | G15 | G35 | SCARAB /X V
Virtuoso X is offline   Reply With Quote
Old 14th May 2017, 10:27 PM   #33
mAJORD
mAJORD's Avatar
Increasing frequencies would be great - but in addition to the factors Fleetfeather mentioned, moving to a higher frequency (FMAX) target, at current IPC levels also means larger die sizes, and almost certainly decreased performance/watt. It would also blow out the development time, hence time to market.. All three of which are detrimental to the most profitable markets Zen is aimed at - Server and Notebook.
(and the later even detremental to Ryzen )
On the Bench: Ryzen 7 1700 - ASUS Prime X370 Pro - 16GB Corsair Vengance DDR4-3200
Main:
Ryzen 7 1800x - Crosshair VI Hero - 16GB G.SKill DDR4-3333 - ASUS 1080Ti FE - Custom water - Be-Quiet Silent Base
Ryzen OC / Owners Thread
Old 14th May 2017, 10:48 PM   #34
Virtuoso X
Virtuoso X's Avatar
that makes sense if theyre hitting a specific market, but alot of people are comparing the 7700k with the 1800x and the 7700k is better in most applications except heavy multicore/threaded applications, im guessing theres some tweaking on the application side that has to be done to take advantage of the extra cores?
anywho, im tossing up whether to wait for coffeelake or get a 7700k to be the successor to this 2700k @ 5.2ghz
Old 14th May 2017, 11:17 PM   #35
Azzan
Azzan's Avatar
Originally Posted by nCrypt View Post
i had a 5960x @ 4.5Ghz, i side graded to an 1800X which is running at 4.0ghz
Gaming @ 4K, the 5960x was maybe 1-2% faster. Was only able to tell once crunching numbers.
gaming at 4k no real difference between the two. 1800x in hevy multi threads beats the 5960x, but thats at stock speeds, at 4.5vs4.0 the 5960x still wins.
But 7700K would be faster than 6900K/1800X for most games, right?
i7 7700K | Noctua NH-D14 | Asus Prime Z270-P | 16GB Corsair Vengeance 3200 | 4GB MSI GTX1050Ti Gaming | 500GB Samsung 960 EVO | Fractal Define C | Corsair RM550X | 24" Samsung CFG70 | Windows 10 64bit
Azzan is offline   Reply With Quote
Old 14th May 2017, 11:19 PM   #36
mAJORD
mAJORD's Avatar
Well they're going off the two most profitable markets, (compared to Desktop) , and both by chance are performance per watt bound. Not maximum frequency/performance.
I think you'd be disappointed upgrading to a 7700K from what is obviously a very good 2700K you have there - as I said, 20% IPC avg from the Sandy bridge to skylake core (which is the same core in kabylake/coffeelake), and you'll be lucky to get over 5Ghz on a 7700K so you may have a frequency regression. This alone should be a clue as to why AMD wouldn't chase down this sort of performance goal.. It's a dead end. Do not be surprised to see Intel either stagnate, or regress in single threaded performance with future cores in order to improve MT performance.
Main:
Old 15th May 2017, 9:33 AM   #37
fleetfeather
You can buy 4C and 6C variants of Ryzen chips if you want to save money on cores you consider 'almost redundant', but that won't improve the process maturity holding all of their chips down to ~4.0ghz.
Old 15th May 2017, 12:31 PM   #38
morgala
I'm in the same boat although I've got a 4790.
morgala is offline   Reply With Quote
Old 15th May 2017, 10:47 PM   #39
Virtuoso X
Virtuoso X's Avatar
im going to hold off till coffee lake comes.
im happy enough with my 2700k @ 5.2Ghz i doubt upgrading to a 7700k will make that much of a difference right now.
and if what theyre saying is true in regards to 6c12t then coffee lake is the obvious choice.
but the cpu isnt the only thing that needs upgrading, our mobos have alot of draw backs compared to the newer 1151 boards (ddr4 support, m2 support, pcie 3.0, etc etc)
i just hope coffee lake uses the same 1151 boards/ z270 as i may be forced to upgrade really soon.
Old 16th May 2017, 9:50 AM   #40
mAJORD
mAJORD's Avatar
This is true - it's just a lot of money to outlay for those coming from overclocked SB systems, to get 20 to 30% more performance, and some new mobo features..
I think halo 6c/12t Coffeelake is an absolute given post Ryzen release. Having said that, they are seemingly releasing quad's.. even w/out HT on X299 which seems batshit crazy, so anythings possible.
Main:
Old 16th May 2017, 10:17 AM   #41
nCrypt
nCrypt's Avatar
in the past mainstream and enthusiast was two different lines, cpu and motherboard
i do believe there is still seperate cpu'S, however not a seperate socket.
No idea how they are going to implement this, as 7740k having dual channel mem, and the 7920x having hex channel.
Cant wait to see what i get to play with!!!
1.5960X@4.8Ghz 1.35V WC X99 ROG R5 E10 32GB TridentZ 3200C14 GTX1080 Ti SLI WC CaseLabs S8
2.7700K@5Ghz 1.30V WC Z270 ROG APEX 16GB TridentZ 3200C14 GTX1080 STRIX OC WC Phanteks Luxe Tempered
3.7600K@5Ghz 1.31V H115i Z270 ROG STRIX 16GB TridentZ 3200C14 HD630 Caselabs S8
nCrypt is offline   Reply With Quote
Old 16th May 2017, 2:44 PM   #42
Virtuoso X
Virtuoso X's Avatar
the upgrade will be more worth it when coffee lake comes out, its 14nm same as kabylake which makes me believe itll use the same 1151 socket/z270 chipset
also the quads without ht? whats the point? kaby already have these
im actually considering upgrading to a lower end kaby right now then upgrade to coffee when it comes out, but there no confirmation that coffee will use the 1151 just for the extra mobo goodies.
Old 18th May 2017, 10:46 PM   #43
Datsun 1600
Well they could be dropping the K series CPUs on the main stream socket going forward, otherwise why would you have the same CPU on two different sockets?
My custom window.
i5-750, Gigabyte P55-UD5, 8Gb Patriot 1866, Gainward 670 Phantom
i5-650, P55A-UD3R, 8Gb Patriot 1600, Powercolor 6950
G6950, ECS H55H-I, 8Gb G-Skill Sniper 1600
Datsun 1600 is online now   Reply With Quote
Old 18th May 2017, 10:49 PM   #44
Rockman.EXE
Rockman.EXE's Avatar
.....X299 gateway drug?
Completed successful trades with many OCAU members for over 10 years, search my post/thread history!
Main rig - https://au.pcpartpicker.com/list/VcctLD
Home Server - https://au.pcpartpicker.com/list/NPhwYr
Rockman.EXE is offline   Reply With Quote
Old 19th May 2017, 9:32 AM   #45
AstinGC90
AstinGC90's Avatar
Looking good
https://www.ocaholic.co.uk/modules/n...?storyid=16540
I7-7700K Delided 5.2/4.8 1.42v daily OC, EKWC Hard Tube, 360mm rad x2 UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, 2 x Gigabyte GTX 1080ti EKWB 2050/12000 SLi. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X. Rig Pic
AstinGC90 is offline   Reply With Quote
