Old 31st July 2017, 10:14 PM   #751
Supersize
Supersize's Avatar
Originally Posted by aussie-revhead View Post
hahah I never wanted RGB's but it seems like every motherboard has them now and the RGB rams are great performers so RGB it is ...
Are you guys testing with Realbench? Or other?
I read that C states should be disabled for overclocking, are you guys doing this?
All C-States are off.
I'm testing with Realbench mainly, I do have a AVX/AVX512 offset of 6 bringing them back to 4Ghz so any AVX based tests wont find instabilities.
Backed the uncore off a bit back to 2.5Ghz, was pushing up the temps, have to run 1.21v for 4.6Ghz CPU/3Ghz cache.
Keeping it under 1.2v is what's needed for a AIO cooler, custom water you should be able to go higher.
Supersize is offline   Reply With Quote
Join OCAU to remove this ad!
Old 31st July 2017, 10:54 PM   #752
Court Jester Thread Starter
Court Jester's Avatar
well I finished my water loop tonight
i will start OCing properly tomorrow
Many suscessful trades over the past 11 years
Current system: i7 3820 @ 4.6ghz
Court Jester is offline   Reply With Quote
Old 1st August 2017, 6:37 AM   #753
OJR
OJR's Avatar
Why are you running the second MSI GPU out of interest?
OJR is offline   Reply With Quote
Old 1st August 2017, 7:08 AM   #754
im mostly mining on it atm, I wasn't sure If I was going to keep it as SLI support in new games is not great, so I didnt order a block for it Most games I am playing atm are running fine on the single 1080ti
The bottom card runs quite cool and at 100% fan speed the fan isnt overly loud on that card so I may not even get a block for it if I keep it.
I was hoping vega wouldn't be a big pile of crap as I would have sold both and gotten one to keep my free sync support but that is clearly not going to be the case so I have jumped ship 100% now and just ordered a gsync screen as I dont think ill be buying AMD again any time soon ( after owning AMD/ATI cards since the 4870 )
Old 1st August 2017, 7:56 PM   #755
Dr Jon
Dr Jon's Avatar
x299 Prime Deluxe; Caselabs Mercury; TridentZ 3600 32gb kit
Happy with the build so far at a stable 4.5ghz OC. Basics are 7820x, XMP 3600 profile; all-core sych@ 45; 4 & 7 AVX offset; CPU input 1.9V; adaptive voltage offsets of (-) and (+) 0.025V; Cache @3000, power @140%. GPU is a MSI 1080ti Seahawk EK because I didn't want to stuff around putting my own waterblock on it.
Cinebench score was 1921 after a few runs... I am sure I could do better, but I'm happy with this OC as my hottest CPU temp has been 63C with the Intel Tweaker CPU stress test. Mind you, it is winter, and this is Hobart, so the delta is pretty good!
Dr Jon is offline   Reply With Quote
Old 1st August 2017, 8:27 PM   #756
Supersize
Supersize's Avatar
Nice looking rig.
1921 seems a little low, I'm getting 1964 with the same settings, but 3200Mhz ram.
What sucks if I update my older version of Realbench to the latest and that uses all AVX.
So it's only testing at my AVX offsets, stupid me deleted the older version.
Old 1st August 2017, 8:36 PM   #757
Dr Jon
Dr Jon's Avatar
Originally Posted by Supersize View Post
Nice looking rig.
Yep, I think it is as well, but... I am not pushing it much really. AND I am not actually doing a heap of 'workstation' type stuff either - I mostly use it for dictation of reports, streaming music, gaming, and so on... but it's nice to have the horsepower ripping stuff, multi-tasking, etc!! Could I have gotten away with an AMD 1700 or 1800? likely so, but the RAM booted straight into XMP, the overclock was so simple, and it was just easy. The higher single/dual core speed was the main selling point really.
Old 1st August 2017, 8:48 PM   #758
Dr Jon
Dr Jon's Avatar
For info... Not huge scores, but I am using those AVX offsets - maybe that is not pushing the CPU that much either?
... AND just realised those screen clips are NOT when I was actually doing anything with the CPU either
Old 1st August 2017, 9:08 PM   #759
Supersize
Supersize's Avatar
pix
pix
All these are mine, 2008 was with 4.6Ghz/3Ghz overclock, just a little toasty with a H115i..
The highlighted score in the screen shot is 4.5Ghz/3Ghz with Chrome open.
http://imgur.com/H7v77Dr
Old 1st August 2017, 9:23 PM   #760
aussie-revhead
aussie-revhead's Avatar
Guys, what are you using to read vcore? Cpuz seems to be reading something else, no way its as low as its showing.
Bench 1- Asus Rampage 5 Extreme - Intel 5960x - 32gb of 3200c16 DDR4- 1x Galax GTX1080 Ti HOF - Samsung 960 Evo + Intel 600P m.2 512GB - Enermax Revo1250 - water cooled tech bench - QNIX 2560x1440 screen @ 100Hz - Aten 120Hz KVM
Netbox - Dell 990 SFF - 2500 - 16GB ram - gtx750Ti - 240GB SSD - 2TB green
Current vehicles- Black 2007 ZX14 - VE V8 Calais (wifes car) - VN SS (for sale)
aussie-revhead is online now   Reply With Quote
Old 1st August 2017, 9:38 PM   #761
Supersize
Supersize's Avatar
TUF Detective, it's a little bluetooth dongle that comes with the TUF Mark 1, you install the app on your phone and you can read voltages, temps, post codes, clear cmos, restart the machine, stuff like that.
Old 1st August 2017, 9:44 PM   #762
OJR
OJR's Avatar
That's actually pretty fkn cool.
Old 1st August 2017, 9:45 PM   #763
well I am having mixed feelings about this new system
the cpu I got from silicon lottery is hit and miss even booting into windows @ 4.9ghz @1.3v ( their tested voltage)
I can get it stable @ 4.8g @ 1.3v but starts thermal throttling in real bench within minutes
4.8ghz in non AVX workloads is fine (prime 95 v26.6) @ 100% load but not really happy
im going to eat the cost of the postage and send it back.
Old 1st August 2017, 9:46 PM   #764
OJR
OJR's Avatar
Try it on a decent motherboard first CJ.
Old 1st August 2017, 9:53 PM   #765
I have its called the gaming 7
they are blaming the board but I have tweaked everything I can but it locks even in the bios @4.9 ghz and if not then generally just afer loading windows I can not push volts any higher as it is hitting thermal limits as it is.
--4.8ghz it is fine but im not happy with having to off set the avx more and having it throttle thermally in avx loads its not what I pay extra for a binned chip for
they only do one replacement so I decided on a refund as I don't want to blow my one replacement on a chip that is functional but not hitting their rated speeds.
I might just buy a walletripper
