Go Back   Overclockers Australia Forums > Specific Hardware Topics > Electronics & Electrics
Old 21st March 2017, 1:46 PM   #1
wahid Thread Starter
wahid's Avatar
Default Flash sensing data logger
Hi, I would like to log the number of flashes, time of day, and day of week, from a permanent speed camera flash unit.
There is a low conspicuity mounting spot available a few metres in front of the flash unit, on top of a public telephone enclosure. The flash is a flood type that lights up the entire intersection so there is plenty of light.
I envisage a small data logger PCB, photo cell and coin battery in a water resistant box, capable of a one week deployment. The photo cell will have a small hood to give it some protection from the sun, lightning flashes, and sun glints off vehicle windows.
Can anyone please recommend a suitable kit or ready made board that might suit please?
Any advice appreciated.
Thanks.
Rig1: Athlon X2 6000+ | MSI K9N | TT Tsunami | CMV221D | 9600GT | 2G A-DATA | WD 80GB | Seagate 160GB | Pioneer 111D | CM 650W | MX Duo | X530 | X3D | SBG900 | GX1008 Rig2: i2500 | Z68 | 6950 | LG W2442 Lappys: IBMT23 X 2 | Eee 1001HA | D400 X 2 Voip: Zyxel 2302R 1.8-450MHz: Icom 7000 | Yaesu FT470 900MHz: Nokia 6300 | E1762 2100MHz: iPhone 12GHz: Topfield 3000 24GHz: KR10
wahid is offline   Reply With Quote
Join OCAU to remove this ad!
Old 22nd March 2017, 3:10 PM   #2
_zak
_zak's Avatar
I'd be surprised if you found a ready-made board or kit for this application - it's pretty niche. However, it wouldn't be too hard to make up a prototype. Things you'd need:The first thing (and probably the trickiest part) is to work out what 'flash' you want the Arduino to record. This is changed by the little pot on the photodiode module, and is probably going to be hard because the camera might go off during the day or at night.
After this it's pretty simple - when the photodiode sees the flash, it pulls D0 high and wakes the Arduino. After being woken up, the Arduino queries the RTC for the time and date, writes it to the SD card, then goes back to sleep.
The code should be pretty simple, and if the Arduino's asleep most of the time, won't use too much power. It definitely wouldn't be able to be powered by a coin cell, but a small LiPo should be fine for a week or more I would think (though I'm not entirely certain about the power the photodiode module needs).
hex: Jonsbo UMX1 Plus | P8Z77-I Deluxe | i5 3550 | 16 GB DDR3-1600 | GTX 1050 Ti | 750 GB SSD + 4 TB
_zak is offline   Reply With Quote
Old 22nd March 2017, 3:13 PM   #3
RobRoySyd
You'd be very unlikely to find anything off the shelf to do this. Fairly trivial task though to make something using say an Arduino that'd meet the spec.
Only slightly tricky requirement is going to be getting the power consumption as low as possible as it's to run off a battery for quite some time.
[edit] What he said ^^^^
"Those who make peaceful revolution impossible will make violent revolution inevitable." JFK
RobRoySyd is offline   Reply With Quote
