Go Back   Overclockers Australia Forums > General Topics > Troubleshooting Help
Old 24th April 2017, 2:44 PM   #16
cvidler
cvidler's Avatar
Originally Posted by im late View Post
Unfortunately this tends to be a free "get out of jail card" for vendors.
If your ram is not on the QVL list, then they may turn you away.
People bag it (cause they don't understand it), but it's entirely fair. You can't expect any manufacturer to support absolutely every combination of every device that can plug into a motherboard.
If you want it to absolutely work, buy from the QVL (or buy a HP/Dell/etc*). If you're willing to risk it, buy what you want - knowing you're on your own if it doesn't work.
*and it why their prices are higher, because they have tested everything they sell will work together, and have drivers for it all.
We might eviscerate your arguments, but we won't hurt you. Honest! - Lucifers Mentor
cvidler is online now   Reply With Quote
Old 24th April 2017, 4:46 PM   #17
bananabryan Thread Starter
Originally Posted by VirtualNinja View Post
To clarify have you tried both sticks in single channel mode and both worked?
Thanks for responses everyone. In reference to this, I've tried both sticks in single channel BY THEMSELVES and they work. Once you try put in more than one stick in either single or dual channel the computer won't boot up at all. I just get a DRAM LED warning light.
bananabryan is offline   Reply With Quote
Old 24th April 2017, 5:19 PM   #18
Xenon
Shīrāzī
Xenon's Avatar
Try re-seating your CPU, and check to ensure you haven't bent any pins.
Xenon is offline   Reply With Quote
Old 24th April 2017, 10:02 PM   #19
Bold Eagle
Bold Eagle's Avatar
Install each RAM module and then boot into the OS using CPU-Z review the SPD and take note of the Part Number of each stick (take a screenshot and save to desktop to compare them both) - do they match?
Review the timing tables - do they match?
Being a budget kit you may find they have not been binned correctly.
I suspect you are going to need to manually set the voltages and timings of one stick and save in the BIOS and then add the other.
PC3: Cardboard Box, peanut dispenser, highly conc caffine intravenous drip, little monkey w "electro El Shocko rectal probe", 3DMarkVantage=276818768
Bold Eagle is online now   Reply With Quote
Old 25th April 2017, 1:46 AM   #20
havabeer
havabeer's Avatar
Only other thing to do is take the ram to a mates PC and install them, if it doesn't work you know the ram is stuffed, if it works fine you know your Mobo isn't great
Current rig: CPU i7 5960X - Mobo MSI x99 pro carbon - GPU 2x Titan X (pascal) - Ram 16gig DDR4 2666 G*skill - Case Custom little devil V8 - Monitor Phillips 40" 4k
Cooling - Custom water loop - 360 rad x 2 - 480 x 1 - acrylic hard tube
havabeer is offline   Reply With Quote
