Old 18th June 2017, 8:30 PM   #1
Trevstar Thread Starter
Default Ryzen Upgrade.
Howdy all,
Currently using a AMD FX-8320 system and have finally decided to do a upgrade to the Ryzen level.
The system is mainly used for gaming (mmos/overwatch/adventure/usually try most new releases) with youtube/music/occasional movie watching.
Im trying to decide between a Ryzen 5 1600 or Ryzen 7 1700? Also struggling to decide on a B350 mobo to pair with it.
Im looking at some gskill 2400mhz ram to go with the system.
Any and all suggestions would be very muchly appreciated!
Cheers.
Trevstar is offline   Reply With Quote
Old 19th June 2017, 9:29 AM   #2
Dragonfly
Dragonfly's Avatar
Look at reviews for the 1600 vs the 1700. 8 core will be better for tasks that use more cores, otherwise the 1600 would be better at its cheaper price.
With the B350 board I'd also look at reviews, but also look at the bios and see if they have the latest agesa 1.0.0.6 update.
Also with Ryzen you do get an advantage with higher mhz ram, but depends really on what you can afford.
i5 3570K @4.5Ghz | Asus Maximus V Gene | 16GB GSkill Ripjaws | Asus Strix GTX1060 | Corsair RM650X PSU | Fractal Define C | Asus VG248QE & Dell U2412M
DesignInfusion
Dragonfly is offline   Reply With Quote
Old 19th June 2017, 10:23 AM   #3
DUS x SSJ4 x
DUS x SSJ4 x's Avatar
Stay away from the Asus prime x370 board. Ive had a ton of issues not including the overclocking dramas. Currently experiencing USB problems... not sure if its windows but I am getting a little over chasing gremlins.
Build: Ryzen 1700 4.0ghz @1.35v ASUS Prime x370 Gigabyte G1 1080 32gb (2x16) m.2 960 EVO 512gb
My YouTube: https://www.youtube.com/channel/UCUS...C21GVpJi3-zRpQ
DUS x SSJ4 x is offline   Reply With Quote
Old 19th June 2017, 10:41 AM   #4
vid_ghost
vid_ghost's Avatar
When i get a new PC I'll probably be looking at 8 to 16 CORES at the lowest TDP running an i3 6100T 35w CPU at the moment .. 8 cores at 65w or 12 cores at 125w sounds good with Threadripper
Buy what you can afford and factor in heat in summer and running costs I really like the G-skill Trident RGB DDR4 ram sticks.. they look amazing .. grabbed two packs of 16GB DDR4 3000Mhz for $199 each .. running them in the intel boxes at the moment but will move all 32GB's to a Ryzen system in the future
AMD RYZEN 1700 & 1600 are the sweet spot in the CPU market by by intel i7 and i5
vid_ghost is offline   Reply With Quote
Old 19th June 2017, 11:13 AM   #5
tree86ers
tree86ers's Avatar
really depends on your budget but from your use case there would be no issue with either cpu. If your want to save some money the R5 should be fine.
as the Mobo, from all the reviews out there go with the one that fits the look to price point your willing to spend.
Main PC "Tensa Zangetsu" - MB "eVGA X99 Classified" - CPU "i7 6800k" - RAM "corsair dominator platinum 32gb" - GPU "evga GTX 1080 FTW x 2" Trans-code PC "Hyōrinmaru" - MB "ASUS P9X79" - CPU "Xeon E5 2670" - RAM "corsair LP 32gb" - GPU "eVGA GTX 960 2GB" LAN PC "Zangetsu" - MB "EVGA Z77 Stinger" - CPU "i7 3770k" - RAM "corsair LP 16gb" - GPU "eVGA GTX 980 4GB"
tree86ers is offline   Reply With Quote
Old 19th June 2017, 11:44 AM   #6
TaroT
TaroT's Avatar
i got a good deal on a 1600x so i,m grabbing the asrock b350 pro 4 for $119 from pccasegear seems to be a nice simple board that works ok but also has 4 ram slots.
what you really really want to watch for those is vrm cooling make sure it at least has some for of heat sinks.
ram wis ei would seriously suggest grabbing some of the gskill ryzen based ram like the flare x or fortis depending on what you want to spend and how much you want to tweak.
i finally gave up on corsair and team extreme and plonked down the fir the flarex 3200(way overpriced but i have had quite enough tweaking for now plus when threadripper drops i will only need to grab another one and be happy.
be sure you get an am4 based cooler as well(if you are not getting a 1600/1700 with the cooler)
AMD Threadripper 1950X@stock:corsair H115i cooler: Asrock Taichi X399Gskilll Flarex 3200 ddr4 @3200 cas14XFX Vega 64 8 gig
Old 19th June 2017, 1:21 PM   #7
gregpolk
gregpolk's Avatar
To play devils advocate, if your main use case is gaming, you'll still get better performance out of an i7 7700k for similar money in the majority of games. So consider that.
That said, I'd suggest the 1600. It'll OC the same as the 1700, it'll perform the same in the vast majority of games. It will perform better than the 7700k in games that are better multithreaded which will hopefully be increasingly common as intel also looks toward 6+ cores, and won't bottleneck your GPU on games that aren't. Plus you have a better upgrade path since you'll have zen2 and 7nm CPUs most likely still on AM4 (hopefully actually supported by current motherboards).
With that advice though and in much the same situation I bought myself a 1700. My reason:
- ePeen, dank cores bra. Seeing those 16 threads in task manager just makes me feel happy.
- More threads is useful for me as I run a lot of background tasks while I game. I want to still have torrents going, and a youtube video on the other screen, while my media server streams a movie to the TV for my wife.
I also went with x370 rather than b350 mostly for epeen reasons and because I wanted to reuse my AM3 cooler and couldn't get an AM4 bracket. Asus Crosshair VI. Running gskill flarex 3200mhz happily. Haven't tinkered with the CPU yet but will when I get the time. The rams pretty pricey and with better research than I put in I'm sure you could find an alternative to run the same speed for cheaper, but I was willing to just throw some extra cash to save me time.
gregpolk is offline   Reply With Quote
Old 19th June 2017, 5:10 PM   #8
KuNFuSHuN
KuNFuSHuN's Avatar
Hope you dont mind I post questions here too to avoid too many ryzen upgrade threads.
I am looking to upgrade from a 3570k system myself. I was wondering if anyone would consider reusing their previous systems PSU? Its nearly 5 years old and its the PSU ive been using my 3570k system (Silverstone Strider Gold Evolution ST85F-G-E 850W: https://www.mwave.com.au/product/sil...supply-aa49421)
I havent pushed my system for anything other than gaming for which is usually nearly every evening for anything upto or more than 5hours. I have only recently done a preset 4ghz overclock as well.
Would it be better that I purchase a new PSU? I am hoping to not spend too much and if I could use some previous system parts that would be great. I will for now use my R9 290 as well and hold out for vega gaming card to go on sale later at the end of the year or even just grab a 1080ti close to its end of life as I will be running this on a 3440x1440 res display.
I want to upgrade to a Ryzen 1600x or above, purely for gaming and streaming. Maybe in the future some video editing but probably just editing of recorded streams, nothing too fancy.
KuNFuSHuN is offline   Reply With Quote
Old 19th June 2017, 6:17 PM   #9
gregpolk
gregpolk's Avatar
I don't see any reason to upgrade the PSU. You'll be hard pressed to push it anywhere near 850w, its a gold rated, quality PSU. Hell your new ryzen system will probably draw less power especially when you replace the 290. Not that there's any rush for that, they've aged quite well.
The only reason to upgrade really, is if it doesn't supply the plugs that you want to use. For example, my motherboard can take the usual 8pin plug and an additional 4pin optionally. My PSU is too old to have that extra 4pin. So I guess if I really wanted to push the OC hard I'd want a new PSU. But it works fine.
Interest in streaming is where I'd consider the 1700 over the 1600. You'll use the extra cores.
Old 19th June 2017, 6:55 PM   #10
KuNFuSHuN
KuNFuSHuN's Avatar
Cheers for the reply.
I was thinking that as well but I was just wondering if it was a bad idea to reuse a 5 year old (no issues so far and working perfectly fine) PSU in a new system.
Connectors
1 x 24 / 20-Pin Motherboard connector (550mm)
1 x 8 / 4-Pin EPS / ATX 12V connector (750mm)
1 x 8 / 4-Pin EPS / ATX 12V connector (550mm)
2 x 8/6-Pin PCIE connector (550mm)
2 x 6-Pin PCIE connector (550mm)
8 x SATA connector (600mm / 150mm / 150mm/150mm)
6 x 4-Pin Peripheral connector (600mm / 150mm / 150mm)
2 x 4-Pin Floppy connector (600mm / 150mm / 150mm / 150mm)
Old 19th June 2017, 7:07 PM   #11
tree86ers
tree86ers's Avatar
existing PSU should be fine.
Old 19th June 2017, 9:09 PM   #12
gregpolk
gregpolk's Avatar
Connectors
Never know when you might need that floppy connector
Old 22nd June 2017, 9:42 AM   #13
KuNFuSHuN
KuNFuSHuN's Avatar
I am now contemplating if I should get the planned 1700 or just grab a 1600x or non-x.
I mainly will just be using it for gaming and will do some streaming. Until I get a decent connection for upload which probably will be 2020 when NBN is done here. I just from time to time stream off my mobile since I have heaps of unused data there.
Would the 6 core be more than capable of streaming and using high settings on OBS? the price difference is less than $100 though for from 6 to 8cores T_T
