Go Back   Overclockers Australia Forums > Specific Hardware Topics > Retro & Arcade
Old 19th June 2017, 10:18 AM   #241
Matthew kane
You can maybe clean them, would require a lot of elbow grease and careful use of corrosion removal/chemical cleaner to get the blocks back to its former condition.
I did this to the danger den but since the main water block was copper there was no way removing the oxidation on the copper itself unless they were re-machined.
The rubber seal is also another problem and most likely impossible to source.
Intel i7 3960X @ 4.7GHZ - Noctua NH-D14 | 16GB OCZ Platinum Series DDR3 1600MHZ | Asus Rampage IV Extreme (4901 bios) | Zotac AMP! Edition GTX 980 Ti | PNY GTX 465 unlocked to 470 | Creative X-Fi Titanium Fatality Pro with LME47920's opamps | OCZ Vertex 3 240GB | OCZ Vertex Plus 120GB| 1TB WD Black, 2TB WD Green, 4 x 2TB Seagate LP | Enermax Revolution 85+ 1250watt | Antec P280 + Veris Elite | LG BD Rewriter
Matthew kane is offline   Reply With Quote
Old 19th June 2017, 6:29 PM   #242
Matthew kane
I've used Loctite (can't remember the exact type number but it was designed for marine purposes so waterproof) for these sort of things.
TIG welding could get messy. Is the water block copper or nickel of some sort?
Old 1st July 2017, 9:46 AM   #243
atmo Thread Starter
atmo's Avatar
Originally Posted by shane41 View Post
Where's Atmo? In the dungeon
Not dead, I've just been super busy with work (changed jobs a couple of months ago) and some other projects.
atmo is offline   Reply With Quote
Old 1st July 2017, 3:23 PM   #244
Matthew kane
Welcome back atmo.
Old 15th July 2017, 6:15 PM   #245
Matthew kane
What you using for your watercooling?
Old 26th July 2017, 4:27 PM   #246
Matthew kane
Picked up a bronze Thermaltake 775watt XT psu today from an OCAU'er, going to be benching again soon.
