Old 28th June 2017, 1:43 PM   #16
Amfibius Thread Starter
Amfibius's Avatar
Thanks for the offer, Shane. It may be a bit difficult for a home build - materials will be aluminum, carbon fibre, and wood. It will need CNC machining.
-Amfibius
Amfibius is offline   Reply With Quote
Old 28th June 2017, 1:52 PM   #17
andurils_sheath
andurils_sheath's Avatar
I can probably get this done for you or at least the metal sections.
I would be inclined to use "carbon fibre" vinyl wrap over aluminium for the carbon fibre sections. Will be cheaper and visually as effective.
It will cost a lot for a one off though - whats your budget?
(I am a mechanical engineer with 5 years industry experience drawing and manufacturing sheet metal telecommunications enclosures.)
Bloodwork ~ i7 4770k ~ Shuttle SZ87-R6 ~ 7870 ~ 16G DDR3 2133 ~ 120G 850EVO
Trades ~ imf ~ Dufflover ~ chunksoul ~ grahamrb ~ SickZ ~ BAC :S ~ K-ONE ~ passivekid ~ slyls1 ~ rimma ~ holdenfanatic ~ blk25t ~ Irriven ~ Segression ~ sonicthemouse ~ Redferatu ~ ForneverAlone ~ WarezNimph
Last edited by andurils_sheath; 28th June 2017 at 1:56 PM. Reason: my wording was a pile of garbage.
andurils_sheath is offline   Reply With Quote
Old 28th June 2017, 2:34 PM   #18
Amfibius's Avatar
Thanks shane and anduril. This is a preliminary Sketchup drawing of what I am thinking of. I am redoing the design because I realized it will look monstrous when mounted on the rack. I am trying to make it visually a bit smaller.
The new design i'm working on will have 6cm less height and 80mm less width.
-Amfibius
Old 28th June 2017, 2:48 PM   #19
cvidler
cvidler's Avatar
you know hifi/pro audio rack gear is all standard size, and the same size as PC/sever rack gear. plenty of rack mount cases available to you, and you can cut a hole in the top to add a window easy as. much easier starting with a case designed for PC components.
what width is your 'rack'?
We might eviscerate your arguments, but we won't hurt you. Honest! - Lucifers Mentor
cvidler is online now   Reply With Quote
Old 28th June 2017, 6:08 PM   #20
Matthew kane
Horrible slim airflow for the radiators, since those full pieces act as a wall to maintain the structure of the outer panels, add some cutout holes either circle patterns or shaped patterns that way you still have the pieces upright for the top panels to go on top of and you also get better airflow for the radiator fans.
Also are you going to do any anodising, powdercoating, silkscreened or paint finish on the case?
This is definitely not a walk through the park case since it is a 'cost no object' custom case and finalised product needs to demonstrate it. The precision machining required to get all the thicker than your run of the mill pc case alu panel pieces cnc'd with less than 2% variance is beyond what regular hand and bench tools can muster. Bench and angle grinding to cut corners with the job != a perfectly completed product.
Looks easy when you visualise it in your head or on paper as an idea, doing it is completely different. Different story if it was wood though as its a lot easier to work with.
I've tried undertaking something similar to this (not for a rack) years back with my own custom designed regulated and extremely low noise pc psu with a pc motherboard silently cooled for a high end headless music server, had quotes done for my case and it was far more than I was comfortable spending it on.
Intel i7 3960X @ 4.7GHZ - Noctua NH-D14 | 16GB OCZ Platinum Series DDR3 1600MHZ | Asus Rampage IV Extreme (4901 bios) | Zotac AMP! Edition GTX 980 Ti | PNY GTX 465 unlocked to 470 | Creative X-Fi Titanium Fatality Pro with LME47920's opamps | OCZ Vertex 3 240GB | OCZ Vertex Plus 120GB| 1TB WD Black, 2TB WD Green, 4 x 2TB Seagate LP | Enermax Revolution 85+ 1250watt | Antec P280 + Veris Elite | LG BD Rewriter
Matthew kane is offline   Reply With Quote
Old 28th June 2017, 7:25 PM   #21
garfield2k
garfield2k's Avatar
carbon as well now?
let me know what you need. might be able to help there
garfield2k is offline   Reply With Quote
Old 5th September 2017, 3:24 PM   #22
vladtepes
Was there any progress on this?
My Dual System Build Thread
Members willing to do pickups for other members
successful trades: see profile.
vladtepes is online now   Reply With Quote
