Go Back   Overclockers Australia Forums > Specific Hardware Topics > Extreme and Water Cooling
Old 27th April 2017, 9:54 PM   #46
AstinGC90 Thread Starter
AstinGC90's Avatar
Thanks mate. Need to try and not compare to the better builds I guess...
I7-7700K Delided 5.2/4.8 1.42v daily OC, EKWC 360mm rad x2 UV Blue, 16GB Corsair Vengeance 3.2Ghz, Aorus Z270X-G5, SamEVO500GB, 8TB, FractalDefineS, CorsairAX1200, Gigabyte GTX 1080ti EKWB 2050/12000. AsusPG279Q 165Hz, LogiG510S, LogiG502Proteus, LogiZ906, ATHM50X.
AstinGC90 is offline   Reply With Quote
Join OCAU to remove this ad!
Old 28th April 2017, 5:21 PM   #47
terroristone
terroristone's Avatar
looks preety good from the picture. When i did mine i did screw up a few bends and remade them as i wanted it perfect. I used the Hardtube bending kit from Thermaltake and found it made things a lot easier. if you do decide to change anything id put a T in between the rad and pump and put the drain into the bottom of the case there as it would look cleaner.
T1
Originally Posted by knowskillz View Post
I'm supposed to save for a new house! fk it I'll just live in my computer case
Haswell 4790k@4.5 - MSI Z97 GAMING 5- GSKILL 2933 - MSI R9 390X - DELL 30" 2560X1600 -2xDELL 20" 1200x1600 PLP - AX1500I - CUSTOM HARD TUBE WATERCOOLED GPU&CPU - 750D - NIGHTHAWK X9
System Pic
terroristone is offline   Reply With Quote
Old 28th April 2017, 6:54 PM   #48
mad_mic3
looks good
mad_mic3 is offline   Reply With Quote
Old 28th April 2017, 7:21 PM   #49
AstinGC90's Avatar
Thanks guys. I changed the UV to an RGBW strip and have it on mild white at the moment.
Old 28th April 2017, 9:25 PM   #50
Paulie_AU
Paulie_AU's Avatar
Looking good
Paulie_AU is offline   Reply With Quote
