Go Back   Overclockers Australia Forums > General Topics > Overclocking & Hardware > PC Build Logs
Old 25th April 2017, 6:21 PM   #16
ado009 Thread Starter
New Member
Post photos of your rig and compare with others
ado009 is offline   Reply With Quote
Join OCAU to remove this ad!
Old 25th April 2017, 7:05 PM   #17
philquad
philquad's Avatar
I GOT THIS SIC am3 thing
the watercooler i stole from some kids pc
only 1 fan works but that saves power
the yellow cord, unsure what thats for?
the green pencil thing strapped to my hand, thats the start button
im looking at upgrading, any ideas?
philquad is offline   Reply With Quote
Old 25th April 2017, 7:11 PM   #18
Ratzz
Ratzz's Avatar
I think the long yellow cord is some kind of auxiliary power connection, looks like its leading from a sata port.
Zip tie an industrial Noctua fan to the Northbridge? Pencil could be a bit longer too, size really does matter no matter what they say
Originally Posted by seizium View Post
I did visit the NBN van today at Westfields North Lakes, but their internet connection wasn't working so they couldn't give me any information
My Rig
Ratzz is offline   Reply With Quote
Old 25th April 2017, 10:40 PM   #19
/invariance\
/invariance\'s Avatar
Needs MOAR air bubbles.
F@H Stats BOINC Stats
Folding: Phenom II 1100T, Sapphire R9 270, MSI HD7870 Twin Frozr3.
Buckling Spring: IBM Model M, P/N 1391401, DOB 04FEB87.
Smooth vintage MX blacks: Wyse 85 courtesy of Soarer's Wyse Converter.
Complicated Alps Whites: Mtek K104.
/invariance\ is offline   Reply With Quote
Old 26th April 2017, 12:15 PM   #20
New Member
Old 2nd May 2017, 11:47 PM   #21
New Member
Default NZXT phantom 820 home built side panel
I've been looking everywhere to buy spare side panel for my nzxt phantom 820 case but I couldn't find in anywhere so I decided to try making one. I'd like to ad big window to it but I don't feel like cutting my original one so here are some pics of my progress.
Only half of a job is done and is starting to look ok. It took 5 hours so far. Photos of adding window to it and painting are coming soon.
Let me know what you think. Thanx.
Next weekend couple more things done. [IMG][/IMG] [IMG][/IMG]
Ready for painting.
Finally got it finished.[IMG][/IMG] [IMG][/IMG] What do you think guys?
Old 3rd May 2017, 12:13 AM   #22
_slacker_
_slacker_'s Avatar
now that's sic...
**Asrock X370 Gaming K4 ** AMD Ryzen 1700@ 4Ghz ** Team Group Dark Pro 3000 @2933 C12-11-11-11-25 ** XFX RX480 @1405/2055** Samsung Evo 960 M.2 + Evo 850 ** EKWB Watercooled ** Silverstone 750w Gold**
_slacker_ is offline   Reply With Quote
Old 3rd May 2017, 11:10 AM   #23
havabeer
havabeer's Avatar
great work... what are you actually using to bend the steel?
Current rig: CPU i7 5960X - Mobo MSI x99 pro carbon - GPU 2x Titan X (pascal) - Ram 16gig DDR4 2666 G*skill - Case Custom little devil V8 - Monitor Phillips 40" 4k
Cooling - Custom water loop - 360 rad x 2 - 480 x 1 - acrylic hard tube
havabeer is offline   Reply With Quote
Old 3rd May 2017, 9:27 PM   #24
New Member
For bending...? As long as you have your measurements right and all 4 sides marked out nice and square, bending wasn't to hard. Iron that I used was 600mm x 600mm and bit les than 1mm thick. I also used 5mm thick plate with nice square edge to bend against it. Placed marked out sheet on to my work bench then I have placed 5mm plate on top of one of the marked lines and clamped it all together to a work bench so it doesn't move anywhere. 600 x 600 sheet gave me bit extra on the side so I could use both hands to push against it, up to about 45 degrees and then use one hand for applying more pressure on it and use other hand with hammer, tapping along the bottom edge till I achieved 90 degree angle. Bit of a playing around and bit of a challenge but I think it was worth it. For rest of it I'll wait till weekend when I have more spare time to finish it.
Old 12th May 2017, 9:08 PM   #25
New Member
Default Finished my side panel
Finally got it done. What do you think guys?
Old 12th May 2017, 9:31 PM   #26
Bold Eagle
Bold Eagle's Avatar
Excellent job there and looking awesome.
PC3: Cardboard Box, peanut dispenser, highly conc caffine intravenous drip, little monkey w "electro El Shocko rectal probe", 3DMarkVantage=276818768
Bold Eagle is offline   Reply With Quote
Old 15th May 2017, 7:10 PM   #27
New Member
Next I'm thinking of water culling, I just need to work out what I need but it seems that it's not that cheap either.
