Go Back   Overclockers Australia Forums > Other Topics > Other Toys/Hobbies
Old 2nd February 2013, 8:11 PM   #31
Hyena
Hyena's Avatar
Anyone in Sydney (south east) got a multirotor setup and want to meet up to do some video work ?
I tried my hand at making my own quad, did all the research and made up one with HK parts that should have been good for FPV and aerial photography. After fiddling with 1000 settings I just couldnt get it to fly stable enough though. And that was before I even dared strap my gopro on (currently on my 3rd gopro after other action related mishaps!)
I'm thinking about getting something a bit more RTF like the ideafly Ifly-4 and then upgrading if necessary. Although apparently they're take a gopro out of the box
I make hotted up electric bikes and want to do some aerial work to compliment some of the other shots I've been doing. But I've realised I cant ride and pilot at the same time so I'll need a 2nd person!
Ie stuff like this (action starts at 45 sec)
http://youtu.be/xqvFqAb05xs?t=43s
Hyena Electric Bikes.com
High performance electric bike kits
Hyena is offline   Reply With Quote
Old 2nd February 2013, 8:54 PM   #32
CQGLHyperion
CQGLHyperion's Avatar
Originally Posted by Billzilla View Post
snip
movie
So how much is your whole setup worth?
What sort of runtime and range do you get?
BIG RIG: I7-980, P6X58D-E, 6 x 2GB CM3X2G1333C9, HD7970 DCUII TOP, 240GB Evo 840 ssd, 4 x 300GB Velociraptor, Xonar D2X, Lian-Li Red Spider
Trades: Web page coming soon!
CQGLHyperion is offline   Reply With Quote
Old 2nd February 2013, 9:00 PM   #33
Hyena
Hyena's Avatar
You don't want to know!
That's an 8 grand ebike before you even start, and nothing much is standard on it any ore. But you could convert an existing good quality downhill bike (or similar) for $2-3k depending on what sort of performance you want.
Range varies from 30-80km depending on how you ride. Ride like a dirt bike = less, ride like a mountain bike with assistance = more.
Check out my youtube channel, there's a heap more vids and info on there. Or we can start another ebike thread to keep this one on topic.
Old 2nd February 2013, 10:33 PM   #34
sgtraven Thread Starter
sgtraven's Avatar
Ouch, i feel your pain....
Beaver of the Aussie Pitmasters Forum
Originally Posted by RETARD View Post
fap intensely over your uber manliness
sgtraven is offline   Reply With Quote
Old 3rd February 2013, 9:37 AM   #35
Billzilla
Billzilla's Avatar
I don't like to think about it, but it'd have to be over $1500 odd.
With the 3300 mah 4S battery it'll be good for nearly seven minutes flight time. With the 8000 mah 4S it'll go for about thirteen minutes.
The FPV gear uses 5.8 ghz and the signal gets interference from .... everything. I've had it out to nearly 400 metres in clear air and it was still pretty usable, I reckon it'd go a bit further if I had somewhere I could fly it with more space. They reckon it'll go a full kilometre but I wouldn't think so.
The RC gear is also reckoned to go a full kilometre without any trouble.
www.billzilla.org
Billzilla is offline   Reply With Quote
Old 3rd February 2013, 12:56 PM   #36
sgtraven's Avatar
I don't like to think about. it, but it'd have to be over $1500 odd.
You can go for a lower hz transmitter for more range.
There's heaps of gear you can use for getting up to 7k.
I have a guy asking me to build 5x wookong s800 with a working range of 2km. That wouldn't be impossible.
Clover leaf antenna, directional tracking base stations ect ect
Old 3rd February 2013, 1:51 PM   #37
Billzilla
Billzilla's Avatar
Yep.
I don't plan on needing a long range, but certainly less loss of signal around objects would be really nice.
www.billzilla.org
Old 3rd February 2013, 2:34 PM   #38
sgtraven's Avatar
Yep.
try a cloverleaft antenna and directional antenna on the fatsharks, theres a guy at arkrc that is getting good range with this setup.
also mount the antenna on perspex mount away from the GPS and ESC's
Old 3rd February 2013, 3:09 PM   #39
Sledge
why such poor battery life?
Is that normal time frame?
Sledge is offline   Reply With Quote
Old 3rd February 2013, 3:36 PM   #40
Hyena
Hyena's Avatar
Sounds like the power:weight ratio is starting to become unfavourable with the larger battery. Have you had a play with this calculator ?
http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
A mate and I both build quads around the same time. He went with bigger motors and ESCs and 4S higher capacity vs my 3S lower capacity battery (both nanotechs) but everything else about the same. His run time was significantly less, around 30%
A good application for those running GPS to return home or fly to set waypoints. I'd love to build one and set it off with a gopro onboard and an ambitious journey of waypoints and wait for it to return 10 minutes later but I'm sure after investing all the necessary cash to make it do it something would go wrong and I'd never see it again!
Old 3rd February 2013, 4:07 PM   #41
sgtraven's Avatar
5-15 minutes is about the normal battery time for a quad copter, remember there is no forward momentum or lift from anything other than the 3-8 props.
Old 3rd February 2013, 5:54 PM   #42
Billzilla
Billzilla's Avatar
Already got those antennas.
And that photo above is an old one, I have mounted the transmitter antenna up higher with a cardboard box, it helped a lot. I'm also trying mounting the antenna upside-down underneath to see how that goes. (not so goo so far ...)
Yep that's pretty normal.
It might be, I've never bothered to find out the optimum.
www.billzilla.org
Old 3rd February 2013, 7:27 PM   #43
CQGLHyperion
What would be the maximum wind speed that these could fly in?
Old 3rd February 2013, 7:44 PM   #44
sgtraven's Avatar
ive flown in 25-30k winds (bit hard though)
Old 7th February 2013, 9:55 AM   #45
sgtraven's Avatar
postman came today
5000 3c by Brett Robinson, on Flickr
