Go Back   Overclockers Australia Forums > Other Topics > Other Toys/Hobbies
Old 8th March 2017, 2:18 PM   #46
Radley
Radley's Avatar
Originally Posted by Azrael View Post
The not-quite-as-cheap cheap one, $219.
There's a cheaper one than $219??
6800K | ASUS X99 ROG Strix | 32Gb G.Skill Trident Z 3200MHz | GTX1080 ROG Strix | Samsung 512Gb M.2 NVMe | Razer Leviathan | ASUS Xonar Essence STX | Seasonic X-750 PSU | Enthoo Primo | Custom water loop | 2 x Dell U2713H
[ Intel Owners Club Member [#93]
$3830 in sales on OCAU.
Radley is offline   Reply With Quote
Old 8th March 2017, 3:32 PM   #47
Azrael
Azrael's Avatar
Yeah, there was one for $159.
Also, anyone have a good source for Minwax poly and Titebond? Masters was my go to for those...
--Azrael
I never saw a wild thing sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself. - D.H.Lawrence
The Plebian Period | I'm a Christian... | Photo Gallery | avatar_takai @ Steam | takai on all other forums.
Azrael is offline   Reply With Quote
Old 8th March 2017, 3:39 PM   #48
oculi
oculi's Avatar
No idea for the poly but I bought titebond 3 from carbatec (bunnings style wallet warning) which seemed reasonably priced at the time.
Reality or nothing
oculi is offline   Reply With Quote
Old 8th March 2017, 6:07 PM   #49
Azrael
Azrael's Avatar
Yerch, Carbatec is $59 for a gallon. Masters used to be $30
--Azrael
Old 8th March 2017, 6:33 PM   #50
oculi
oculi's Avatar
I didn't know they sold it, would have bought more before they closed but i'm sure they would have sent it all back rather than sell it cheap in the closing down "sales"
I was going through it like crazy so started buying the cheapest white PVA bunnings sells instead, for things that will stay inside anwyay. I used to use a lot of fake liquid nails but it's overkill and takes to long to clean off your fingers.
Reality or nothing
Old 8th March 2017, 6:40 PM   #51
Azrael
Azrael's Avatar
Yeah, they got rid of it off the shelves pretty quickly after the announcement. Not sure if it was just people buying it up, or sending it back.
Sad though.
Seems that Wilson and Bradley have it for about $47 though: http://www.wilbrad.com.au/shop/produ...785-Lt&cid=358
--Azrael
Old 8th March 2017, 6:48 PM   #52
Radley
Radley's Avatar
Timbecon has it for cheap. Not sure what postage is like but shouldn't be too bad if you buy a few things.
Old 8th March 2017, 6:58 PM   #53
underskore
there are places that sell TB3 for way cheaper than carbatec, IIRC a place in the south east called Timbalac was where I saved a lot of money on it. I may've had to give them a company name when buying & I remember being shocked at how low the price was after coughing up for carbatec - but if Masters had it for $30 I doubt it was that cheap.
From what I can remember a generic weatherproof PVA is close enough performance wise to TB3 that the difference is barely noticeable when used for a skateboard deck (stack of veneers). I'd only worry about getting TB3 for the slightly longer working time if you're using it on more common joinery applications.
underskore is online now   Reply With Quote
Old 8th March 2017, 7:04 PM   #54
oculi
oculi's Avatar
most join failures I've had will pull wood fibres out (most likely because I use crap wood) but I'm saving the TB3 for food contact stuff and waterproof and using more white glue more often. Might step up to yellow some day, depends if I can find it really cheap.
TB3 may be better for staining over, but that's when you should use hide glue anyway I suppose.
Reality or nothing
Old 8th March 2017, 7:24 PM   #55
underskore
my understanding is that most timbers will fail before most glues (assuming it's not just a bad joint)
TB3 may be better for staining over...
it leaves a darkish glue line... haven't stained over it, haven't touched hide glue
Old 19th March 2017, 8:00 PM   #56
Radley
Radley's Avatar
Got a jigsaw and a plunge router during the week. The jigsaw is really shit for cutting in a straight line, even with a fence. I'm going to have to just get a table saw.
Old 19th March 2017, 8:58 PM   #57
clonex
clonex's Avatar
what jigsaw and what are you cutting along with what blades are you using?
Originally Posted by de_overfiend View Post
I feel a lot safer in my 20yo VS commodore than in some newer eurohatch or similar
clonex is offline   Reply With Quote
Old 20th March 2017, 7:18 AM   #58
Radley
Radley's Avatar
Some shitty Ryobi one from Bunnings. What blade should I be using for plywood or pine?
Old 20th March 2017, 7:59 AM   #59
oculi
oculi's Avatar
Try metal cutting blades and experiment with speeds. If you are cutting straight lines a circular saw with a shooting board will do it much better.
Reality or nothing
Old 27th March 2017, 2:28 PM   #60
Radley
Radley's Avatar
I love my router
