Go Back   Overclockers Australia Forums > Other Topics > Other Toys/Hobbies
Old 25th January 2002, 7:57 AM   #136
neolithic
neolithic's Avatar
Cool
Originally posted by Splog
Watch it man-whore!
Now THATS a remote control car!
neolithic is offline   Reply With Quote
Old 27th January 2002, 12:59 AM   #137
microsniper
microsniper's Avatar
dave's another losi complete..
microsniper is offline   Reply With Quote
Old 28th January 2002, 12:14 PM   #138
aussie7
aussie7's Avatar
Originally posted by Yoda
You will have to make shure that the .15 that you want to get is a short shaft because those kits are short shaft, not long
also the reason why it won't start is probably because your glow plugs are 3's ??? Well 3's are standard and are designed for cold-warm starting.. you are trying to start it when the engine is hot
Also your engine could be getting hot because you have your mixture screw to rich... Screw it all the way in then bring it out about 1 1/2 or 1 3/4 or so.. just have a little play with it and get it right for your car, mine runs PERFECT at 1 1/2 out.. pretty easy really
A good way to test this is to see if your engine is blowing smoke.. It NEEDS to blow smoke, also another way is after about 5 mins of running the engine (no, not at idle) and pull the car up infront of you, spit on your fingers and put it on your heatsink.. If it disappera like straight away, your engine is running to rich... if it just bubbles and doesn't go away for a little while it is just about fine. If it does nothing, your engine is running too lean
Running your engine too lean or too rich can cause severe problems.... You should re-tune your engine with every change of fuel (e.g. a new bottle) or if you are moving from say 10% - 15% Nitro. Also a good thing to do is to retune on the day if you are going to a club meeting/race.
Also you could consider getting some plugs that are 4's.. they will be a bitch to start cold.. but once running they should be right
Hopefully this can help you
Running for 10mins then having to waite for an hour means bad things... try to weed them out and you'll have much more fun
cheers. Yoda
thanks for the tips Yoda
1. - I changed 10% nitro & 18% oil (non sythetic oil)
2. - changed to a 8 glowplug (medium)
3. - turned the mixture to 2 1/2 turns out
Now I get through a whole tank of juice then let it cool for about 10mins and go another tank of juice
lending money to friends is like gambling and you should only gamble what you can afford to lose
aussie7 is offline   Reply With Quote
Old 28th January 2002, 12:28 PM   #139
Yoda
Yoda's Avatar
Yeah man.. quite amazing at the results you can now get out of them when they are tuned properly.. so is that 18% oil all up? I'm pretty shure that for the motor to function right it needs to be atleast 20% oil (either castor, or synthetic) But that is just IMO.. i'll check and find out for you though man
2 1/2 turns out sounds ok, mine is runnin gat umm ambout 2 1/4 turns as of yesterday.. best I could find for it.
Just make shure you do the spit test once or twice to check that it isn't running too hot, and you shouldn't have many problems.
Cheers,
Yoda
Admin Of AUS RC RACING An Australian Devoted RC Website
Yoda is offline   Reply With Quote
Old 28th January 2002, 2:30 PM   #140
aussie7
aussie7's Avatar
all the fuels at the shop were 18% castor or synthetic oil
It still gets really hot and I have to turn the idle up after it gets hot just so it don't stall.
this motor will be getting replaced soon hopefully
Old 28th January 2002, 2:39 PM   #141
VooDoo
Large Member
VooDoo's Avatar
Splog: what hopups did you get for the E-Maxx and also how much for those tyres and rims?
"To have more happy employees, first you must have more happy employers"
VooDoo is offline   Reply With Quote
Old 28th January 2002, 6:25 PM   #142
Yoda
Yoda's Avatar
yeah.. well I suppose if they where all 18% then.. I am running 5% Castor, and 15% Synthetic at 5% Nitro.. Iv'e had a great run with this fuel, so I think I'll just stick to it for now...
You have to turn the idle up? how do you mean.. as in to make it idle faster or slower? I think you are saying faster, but Im just making shure...
Also if your engine is still getting really hot, it can't be good for it. Have you tried the spit test on it? It may sound gross, but is one of the best ways to see how hot it really is running.. It shouldn't bubble or disapper straight away, but take say 5 or 6 secs before the spit will even start to bubble from the heat.
Even if you are repleacing the engine, would you prefer to have two working, or one dead and one working?
Old 28th January 2002, 7:41 PM   #143
aussie7
aussie7's Avatar
if I was going to keep using this Tamiya FS12 engine I would get a better heatshink as this would solve the overheating problem.
- the tamiy hopup heatsink head costs $100.00 or a another brand heatsink for around $60
- the bore is scorched and it needs replacing and a new piston $65
- not to mention I need tyres again
So I think I will just add some $ and get an OS engine
damn these little cars cost almost as much as the real thing
I could have bought myself a beatup little dihatsu 2 door handyvan for the money this hobby is already costing me.
I wonder which is the more expensive hobby R/C or OverClocking
Old 28th January 2002, 10:45 PM   #144
Splog
umm
a Hitech 645MG servo
RPM Bulkhead Braces
RPM Medium to Heavy Shock Pistons
RPM Shock Tower/Adjustable Mount
Traxxas Al Shock Caps
DuraTrax Bearing 5x8 (4 of)
Kimbrough Gas Car/Truck Servo Saver
RPM Monster Clawz 6-Spoke StableMaxx
and 2 Kyosho Atomic Force 17x2 mods
i think that's most of it
rims were about 34USD for 4 and the tyres come with the truck
----Splog----
Splog is offline   Reply With Quote
Old 28th January 2002, 10:54 PM   #145
Splog
oh and i have filled the midle of the CV's with aluminium rod and epoxy to prevent them from twisting.........just made some aluminium skid plates too
go to the www.maxxtraxx.com forum if u are interested in E/T maxx's
lotsa dense freaks there but u can find some ok info
----Splog----
Old 29th January 2002, 3:55 PM   #146
microsniper
Question 40Mhz FM crystals
Does anyone know where I can get some 40Mhz FM crystals here in OZ? even overseas is ok if I can order online...
It seems to me they are not easy to get hold of..
Old 29th January 2002, 4:23 PM   #147
DeMan
Default Re: 40Mhz FM crystals
There is some JR ones on http://www.radiomodels.com.au/ under Roadshow> Control> Crystals (Page 5)
DeMan is offline   Reply With Quote
Old 29th January 2002, 5:29 PM   #148
aussie7
aussie7's Avatar
Yoda, I have turned the idle up to stop it staling
apparently the piston and sleave are made of two different metals, so they heatup and expand differently. this could have something to do with the stalling when hot
Old 29th January 2002, 6:11 PM   #149
microsniper
I haven't been following your discussion with idling problem.
But I noticed that at the track guys normally have the idle up quite high may be even throttle open when neutral.
This seems to keep the engine running at idle even after dropping from high rev runs..obviously..since the engine is reving beyond idle..
I'm not much into nitro myself, but I use to setup my nitro so that it never stands still at idle without some brake..
They always use different types of alloy or metal so they don't bind.
I'm probably crapping on here..so take it or leave it..
Old 29th January 2002, 6:11 PM   #150
Yoda
Yoda's Avatar
Errr.. I dunno on that one man, but my piston and sleeve is made out of a diffrent metal aswell, and I don't have that problem.. god only knows on that one
antways, happy RC'ing
Tags
owners, rc
