OCAU News - Wiki - PC Database - QuickLinks - Job Search - Pix - Sponsors
Old 16th May 2005, 9:25 AM   #46
javascripterror
javascripterror's Avatar
Or perhaps enlist the OCAU community in a survey of the IHS particularly where excessively high CPU temps are observed at idle.
Cogito Ergo Bummer.
Folding@home 90,000 Club Member.
Folding@Home 2,596,000 Points Milestone.
Home of the Radiical X-Block www.radiical.com.au
javascripterror is offline   Reply With Quote
Old 16th May 2005, 10:36 AM   #47
ridewitme
God of English
ridewitme's Avatar
Maybe the thermal pad that is used on the bottom of the Stock HSF's might be to help the slight discression in the concave IHS's, since I would imagine that the faulty ones would be margin of error.
OCAU Extreme Cooling Club H2O Member My PCDB Entry My Trades List, 187 traders, 228 trades
http://aufalcon.com/ride
ridewitme is offline   Reply With Quote
Old 16th May 2005, 10:41 AM   #48
aresaid
aresaid's Avatar
Mass manufacturing techniques can be very good or very bad.
Required tolerances need to be met. If not met, the product is deemed unacceptable.
Cost increases dramatically as zero tolerance (not a real thing, there are always imperfections) is approached.
AMD does not want to spend $100 per CPU making sure the IHS is flat. If the IHS passes heat tolerance tests, why would they spend more than necessary to achieve this?
Regards, Anthony Hunt
DFI SLI-DR | 3000+ Venice @ 2.7GHz | 2x1GB Ballistix Z503 | Gigabyte 6800GT @ 410/550 | Sony G420 | 3x80GB, 1x200GB HDD | Audigy2 ZS & HD270's
aresaid is offline   Reply With Quote
Old 16th May 2005, 11:44 AM   #49
petfoodonly
petfoodonly's Avatar
I was just thinking a couple of things.
Firstly not every IHS would be 'heat tested'. That in itself would be very costly.
Secondly, it's probable that AMD and INTEL don't make their own IHSs, they would get someone else to do it. So it likly that the same company/factory makes IHSs for both AMD and INTEL. Thus the exact same problem for both CPU brands. No evidence for that, just an idea.
Read my blog http://ourcognitivesurplus.com/ or download my thesis
petfoodonly is offline   Reply With Quote
Old 16th May 2005, 2:24 PM   #50
Audiobuzz
Originally Posted by MR CHILLED
I just question the results after seeing lapping results over the years, and I'm talking direct cpu lapping, not IHS lapping which would presumably yeild less of a result than cpu lapping.
Again, I don't disbeleive his individual results.
I disagree! If the points of contact on a concave IHS are the outer edges then the heat has further to travel and therefore a higher degrees/watt rating. If you then lap the IHS flat you bring the contact points much closer to the heat source. Doing this on a much smaller core (ie without an IHS) will produce less results as the points of contact are already closer to the heat source.
AB
Ventrilo.Com.Au
- Quality Australian Ventrilo Hosting
Audiobuzz is offline   Reply With Quote
eXTReMe Tracker
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. - This page served to you by: surf
OCAU is hosted by Internode!
